    MMM-WifiPassword, oudated ?
    25 Posts 2 Posters 2.4k Views 2 Watching
      Jben1969 @sdetweil
      @sdetweil I don’t know the mistake I made when I install the module, but now I have another problem, the instalation was alright, but I can’t see the QR Code anywhere. I have no special characters or something in my password or SSID. I copied the array from the README.md into my config.
      Any idea ?
      Jochen
        sdetweil @Jben1969
        @Jben1969 can you show me that part of your config.js
          Jben1969
          		module: 'MMM-WiFiPassword',
              //See 'Configuration options' for more information.
              network: "FRITZBoxGzugang",
              password: "Xxxxxxxxxxx",
          		*this I tried before*
          // module: “MMM-WiFiPassword”,
          // position: “top_right”,
          // header: “Gastzugang”,
          // config: {
          // qrSize : 100,
          // authType: “WPA”,
          // network: “FRITZBoxGzugang”,
          // password: “Xxxxxxxxxxx”,
          // debug: true,
            sdetweil @Jben1969
            @Jben1969 I used your config above and see this
            one question… each area is a stack, top down,
            if there are too many modules in a position, it will be clipped at the bottom of the screen
            I put the module as the first in the modules list. try that
              Jben1969 @sdetweil
              @sdetweil well, I tried, your suggestion but the Wifi QR won´t appear, can you help me to debug the config, or can you tell me where I can find the debug protocol ?
              Jochen
                sdetweil @Jben1969
                @Jben1969 because the module is all in browser., all the logging will be found in the browser developers console tab
                ctrl-shift-i
                select the console tab
                and add some unique part of the module name to the filter field
                wifi
                in this case
                  Jben1969
                  Load script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
                  :8080/modules/MMM-Wi…M-WiFiPassword.js:1
                  Failed to load resource: the server responded with a status of 404 (Not Found)
                  localhost/:1 Refused to execute script from ‘http://localhost:8080/modules/MMM-WiFiPassword/MMM-WiFiPassword.js’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.
                  loader.js:168 Error on loading script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
                    Jben1969
                    Hi Sam,
                    I send the message from browser in a separate post, because.
                    It´s seems that there ios a bug in my configuration.
                    Look at my other answer please.
                    thanks
                    Jochen
                      sdetweil @Jben1969
                      @Jben1969 very interesting. We added checks for missing files in this release, so this type error should not occur
                      Can you do
                      cd ~/MagicMirror/modules
                      ls -laF
                      cd MMM-WifiPassword
                      ls -laF
                      And post the results, maybe it’s a permissions problem
                        Jben1969
                        raspberry@MagicMirror2:~/MagicMirror/modules $ ls -laF
                        insgesamt 76
                        drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 ./
                        drwxr-xr-x 17 raspberry raspberry 4096 27. Aug 00:23 …/
                        drwxr-xr-x 10 raspberry raspberry 4096 4. Mai 17:58 default/
                        drwxr-xr-x 6 raspberry raspberry 4096 4. Mai 17:10 MMM-CalendarExt3/
                        drwxr-xr-x 5 raspberry raspberry 4096 24. Feb 2024 MMM-CalendarExt3Agenda/
                        drwxr-xr-x 8 raspberry raspberry 4096 22. Mär 15:27 MMM-Fuel/
                        drwxr-xr-x 13 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleAssistant/
                        drwxr-xr-x 5 raspberry raspberry 4096 21. Mär 16:39 MMM-GoogleCalendar/
                        drwxr-xr-x 5 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleMapsTraffic/
                        drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-GooglePhotos/
                        drwxr-xr-x 3 raspberry raspberry 4096 27. Aug 00:12 MMM-GuestWifiQR/
                        drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-MQTT/
                        drwxr-xr-x 4 raspberry raspberry 4096 10. Feb 2024 MMM-OpenmapWeather/
                        drwxr-xr-x 6 raspberry raspberry 4096 16. Jun 17:44 MMM-OpenWeatherMapForecast/
                        drwxr-xr-x 10 raspberry raspberry 4096 21. Mär 17:14 MMM-Pir/
                        drwxr-xr-x 4 raspberry raspberry 4096 23. Feb 2024 MMM-PIR-Sensor/
                        drwxr-xr-x 10 raspberry raspberry 4096 22. Mär 17:00 MMM-soccer/
                        drwxr-xr-x 4 raspberry raspberry 4096 18. Feb 2024 MMM-Wallpaper/
                        drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 MMM-WifiPassword/
                        raspberry@MagicMirror2:~/MagicMirror/modules $ cd MMM-WifiPassword
                        raspberry@MagicMirror2:~/MagicMirror/modules/MMM-WifiPassword $ ls -laF
                        insgesamt 80
                        drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 ./
                        drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 …/
                        drwxr-xr-x 8 raspberry raspberry 4096 30. Aug 23:43 .git/
                        drwxr-xr-x 3 raspberry raspberry 4096 30. Aug 14:22 .github/
                        -rw-r–r-- 1 raspberry raspberry 6 30. Aug 14:22 .gitignore
                        -rw-r–r-- 1 raspberry raspberry 1061 30. Aug 14:22 LICENSE
                        -rw-r–r-- 1 raspberry raspberry 266 30. Aug 14:22 MMM-WiFiPassword.css
                        -rw-r–r-- 1 raspberry raspberry 4482 5. Sep 12:57 MMM-WiFiPassword.js
                        -rw-r–r-- 1 raspberry raspberry 13901 30. Aug 14:22 mm.png
                        -rw-r–r-- 1 raspberry raspberry 19927 30. Aug 14:22 qrcode.min.js
                        -rw-r–r-- 1 raspberry raspberry 2697 30. Aug 14:22 README.md
                        -rw-r–r-- 1 raspberry raspberry 804 30. Aug 14:22 WifiPasswordModal.njk
                          sdetweil @Jben1969
                          @Jben1969 is MagicMirror running under the raspberry userid?
                          if using pm2 do
                          pm2 stop all
                          then
                          cd ~/Magicmirror
                          npm start
                            @Jben1969 also, what are the MM config.js settings for
                            address:
                            port:
                            ipWhitelist:
                              sdetweil @Jben1969
                              @Jben1969 did you get this resolved
                                Jben1969
                                today I have tried your suggestions and I have got an error about the WifiModule:
                                [2024-09-22 14:05:39.718] [LOG] Loading module helpers …
                                [2024-09-22 14:05:39.722] [WARN] No /home/raspberry/MagicMirror/js/…/modules/MMM-WiFiPassword/MMM-WiFiPassword.js found for module: MMM-WiFiPassword.
                                [2024-09-22 14:05:39.723] [LOG] No helper found for module: MMM-WiFiPassword.
                                [2024-09-22 14:05:39.726] [LOG] No helper found for module: alert.
                                [2024-09-22 14:05:39.754] [LOG] Initializing new module helper …
                                [2024-09-22 14:05:39.757] [LOG] Module helper loaded: updatenotification
                                [2024-09-22 14:05:39.760] [LOG] No helper found for module: clock.
                                [2024-09-22 14:05:40.214] [LOG] Initializing new module helper …
                                [2024-09-22 14:05:40.215] [LOG] Module helper loaded: calendar
                                [2024-09-22 14:05:40.217] [LOG] No helper found for module: weather.
                                [2024-09-22 14:05:41.114] [LOG] Initializing new module helper …
                                [2024-09-22 14:05:41.115] [LOG] Module helper loaded: MMM-Wallpaper
                                [2024-09-22 14:05:41.117] [LOG] No helper found for module: MMM-CalendarExt3.
                                [2024-09-22 14:05:41.118] [LOG] All module helpers loaded.
                                [2024-09-22 14:05:41.135] [LOG] Starting server on port 8080 …
                                [2024-09-22 14:05:41.177] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                [2024-09-22 14:05:46.656] [LOG] Server started …
                                adress : localhost
                                port: 8080
                                ipWhitelist: []
                                Jochen
                                  sdetweil @Jben1969
                                  @Jben1969
                                  this sounds like a permissions problem
                                  can you do
                                  ls MMM-WiFiPassword -laF
                                    Jben1969 @sdetweil
                                    Shame on me, the name of the folder was not right, the capital F of WiFi was a small f.
                                    Now everthing is allright, it shows a nice QR-Code of my Guest WiFi.
                                    Thank you so much.
                                    Jochen
                                    • J Jben1969 has marked this topic as solved on
                                      sdetweil @Jben1969
                                      @Jben1969 awesome
