MMM-WifiPassword, oudated ?
@sdetweil well, I tried, your suggestion but the Wifi QR won´t appear, can you help me to debug the config, or can you tell me where I can find the debug protocol ?
Jochen
@Jben1969 because the module is all in browser., all the logging will be found in the browser developers console tab
ctrl-shift-i
select the console tab
and add some unique part of the module name to the filter fieldwifi
in this case
Load script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
:8080/modules/MMM-Wi…M-WiFiPassword.js:1
Failed to load resource: the server responded with a status of 404 (Not Found)
localhost/:1 Refused to execute script from ‘http://localhost:8080/modules/MMM-WiFiPassword/MMM-WiFiPassword.js’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.
loader.js:168 Error on loading script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js -
Hi Sam,
I send the message from browser in a separate post, because.
It´s seems that there ios a bug in my configuration.Look at my other answer please.
thanks
Jochen
@Jben1969 very interesting. We added checks for missing files in this release, so this type error should not occur
Can you do
cd ~/MagicMirror/modules ls -laF cd MMM-WifiPassword ls -laFAnd post the results, maybe it’s a permissions problem
raspberry@MagicMirror2:~/MagicMirror/modules $ ls -laF
insgesamt 76
drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 ./
drwxr-xr-x 17 raspberry raspberry 4096 27. Aug 00:23 …/
drwxr-xr-x 10 raspberry raspberry 4096 4. Mai 17:58 default/
drwxr-xr-x 6 raspberry raspberry 4096 4. Mai 17:10 MMM-CalendarExt3/
drwxr-xr-x 5 raspberry raspberry 4096 24. Feb 2024 MMM-CalendarExt3Agenda/
drwxr-xr-x 8 raspberry raspberry 4096 22. Mär 15:27 MMM-Fuel/
drwxr-xr-x 13 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleAssistant/
drwxr-xr-x 5 raspberry raspberry 4096 21. Mär 16:39 MMM-GoogleCalendar/
drwxr-xr-x 5 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleMapsTraffic/
drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-GooglePhotos/
drwxr-xr-x 3 raspberry raspberry 4096 27. Aug 00:12 MMM-GuestWifiQR/
drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-MQTT/
drwxr-xr-x 4 raspberry raspberry 4096 10. Feb 2024 MMM-OpenmapWeather/
drwxr-xr-x 6 raspberry raspberry 4096 16. Jun 17:44 MMM-OpenWeatherMapForecast/
drwxr-xr-x 10 raspberry raspberry 4096 21. Mär 17:14 MMM-Pir/
drwxr-xr-x 4 raspberry raspberry 4096 23. Feb 2024 MMM-PIR-Sensor/
drwxr-xr-x 10 raspberry raspberry 4096 22. Mär 17:00 MMM-soccer/
drwxr-xr-x 4 raspberry raspberry 4096 18. Feb 2024 MMM-Wallpaper/
drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 MMM-WifiPassword/
raspberry@MagicMirror2:~/MagicMirror/modules $ cd MMM-WifiPassword
raspberry@MagicMirror2:~/MagicMirror/modules/MMM-WifiPassword $ ls -laF
insgesamt 80
drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 ./
drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 …/
drwxr-xr-x 8 raspberry raspberry 4096 30. Aug 23:43 .git/
drwxr-xr-x 3 raspberry raspberry 4096 30. Aug 14:22 .github/
-rw-r–r-- 1 raspberry raspberry 6 30. Aug 14:22 .gitignore
-rw-r–r-- 1 raspberry raspberry 1061 30. Aug 14:22 LICENSE
-rw-r–r-- 1 raspberry raspberry 266 30. Aug 14:22 MMM-WiFiPassword.css
-rw-r–r-- 1 raspberry raspberry 4482 5. Sep 12:57 MMM-WiFiPassword.js
-rw-r–r-- 1 raspberry raspberry 13901 30. Aug 14:22 mm.png
-rw-r–r-- 1 raspberry raspberry 19927 30. Aug 14:22 qrcode.min.js
-rw-r–r-- 1 raspberry raspberry 2697 30. Aug 14:22 README.md
-rw-r–r-- 1 raspberry raspberry 804 30. Aug 14:22 WifiPasswordModal.njk -
@Jben1969 is MagicMirror running under the raspberry userid?
if using pm2 do
pm2 stop allthen
cd ~/Magicmirror
npm start -
@Jben1969 also, what are the MM config.js settings for
address: port: ipWhitelist: -
@Jben1969 did you get this resolved
today I have tried your suggestions and I have got an error about the WifiModule:[2024-09-22 14:05:39.718] [LOG] Loading module helpers …
[2024-09-22 14:05:39.722] [WARN] No /home/raspberry/MagicMirror/js/…/modules/MMM-WiFiPassword/MMM-WiFiPassword.js found for module: MMM-WiFiPassword.
[2024-09-22 14:05:39.723] [LOG] No helper found for module: MMM-WiFiPassword.
[2024-09-22 14:05:39.726] [LOG] No helper found for module: alert.
[2024-09-22 14:05:39.754] [LOG] Initializing new module helper …
[2024-09-22 14:05:39.757] [LOG] Module helper loaded: updatenotification
[2024-09-22 14:05:39.760] [LOG] No helper found for module: clock.
[2024-09-22 14:05:40.214] [LOG] Initializing new module helper …
[2024-09-22 14:05:40.215] [LOG] Module helper loaded: calendar
[2024-09-22 14:05:40.217] [LOG] No helper found for module: weather.
[2024-09-22 14:05:41.114] [LOG] Initializing new module helper …
[2024-09-22 14:05:41.115] [LOG] Module helper loaded: MMM-Wallpaper
[2024-09-22 14:05:41.117] [LOG] No helper found for module: MMM-CalendarExt3.
[2024-09-22 14:05:41.118] [LOG] All module helpers loaded.
[2024-09-22 14:05:41.135] [LOG] Starting server on port 8080 …
[2024-09-22 14:05:41.177] [WARN] You’re using a full whitelist configuration to allow for all IPs
[2024-09-22 14:05:46.656] [LOG] Server started …adress : localhost
port: 8080
ipWhitelist: []Jochen
@Jben1969
No /home/raspberry/MagicMirror/js/…/modules/MMM-WiFiPassword/MMM-WiFiPassword.js found for module: MMM-WiFiPassword.this sounds like a permissions problem
can you do
cd ~/MagicMirror/modules ls MMM-WiFiPassword -laF -
Shame on me, the name of the folder was not right, the capital F of WiFi was a small f.
Now everthing is allright, it shows a nice QR-Code of my Guest WiFi.Thank you so much.
Jochen
J Jben1969 has marked this topic as solved on
@Jben1969 awesome
