    MMM-WifiPassword, oudated ?
    25 Posts 2 Posters 2.6k Views 2 Watching
      Jben1969
      Hi Sam,
      I send the message from browser in a separate post, because.
      It´s seems that there ios a bug in my configuration.
      Look at my other answer please.
      thanks
      Jochen
        sdetweil @Jben1969
        @Jben1969 very interesting. We added checks for missing files in this release, so this type error should not occur
        Can you do
        cd ~/MagicMirror/modules
        ls -laF
        cd MMM-WifiPassword
        ls -laF
        And post the results, maybe it’s a permissions problem
          Jben1969
          raspberry@MagicMirror2:~/MagicMirror/modules $ ls -laF
          insgesamt 76
          drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 ./
          drwxr-xr-x 17 raspberry raspberry 4096 27. Aug 00:23 …/
          drwxr-xr-x 10 raspberry raspberry 4096 4. Mai 17:58 default/
          drwxr-xr-x 6 raspberry raspberry 4096 4. Mai 17:10 MMM-CalendarExt3/
          drwxr-xr-x 5 raspberry raspberry 4096 24. Feb 2024 MMM-CalendarExt3Agenda/
          drwxr-xr-x 8 raspberry raspberry 4096 22. Mär 15:27 MMM-Fuel/
          drwxr-xr-x 13 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleAssistant/
          drwxr-xr-x 5 raspberry raspberry 4096 21. Mär 16:39 MMM-GoogleCalendar/
          drwxr-xr-x 5 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleMapsTraffic/
          drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-GooglePhotos/
          drwxr-xr-x 3 raspberry raspberry 4096 27. Aug 00:12 MMM-GuestWifiQR/
          drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-MQTT/
          drwxr-xr-x 4 raspberry raspberry 4096 10. Feb 2024 MMM-OpenmapWeather/
          drwxr-xr-x 6 raspberry raspberry 4096 16. Jun 17:44 MMM-OpenWeatherMapForecast/
          drwxr-xr-x 10 raspberry raspberry 4096 21. Mär 17:14 MMM-Pir/
          drwxr-xr-x 4 raspberry raspberry 4096 23. Feb 2024 MMM-PIR-Sensor/
          drwxr-xr-x 10 raspberry raspberry 4096 22. Mär 17:00 MMM-soccer/
          drwxr-xr-x 4 raspberry raspberry 4096 18. Feb 2024 MMM-Wallpaper/
          drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 MMM-WifiPassword/
          raspberry@MagicMirror2:~/MagicMirror/modules $ cd MMM-WifiPassword
          raspberry@MagicMirror2:~/MagicMirror/modules/MMM-WifiPassword $ ls -laF
          insgesamt 80
          drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 ./
          drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 …/
          drwxr-xr-x 8 raspberry raspberry 4096 30. Aug 23:43 .git/
          drwxr-xr-x 3 raspberry raspberry 4096 30. Aug 14:22 .github/
          -rw-r–r-- 1 raspberry raspberry 6 30. Aug 14:22 .gitignore
          -rw-r–r-- 1 raspberry raspberry 1061 30. Aug 14:22 LICENSE
          -rw-r–r-- 1 raspberry raspberry 266 30. Aug 14:22 MMM-WiFiPassword.css
          -rw-r–r-- 1 raspberry raspberry 4482 5. Sep 12:57 MMM-WiFiPassword.js
          -rw-r–r-- 1 raspberry raspberry 13901 30. Aug 14:22 mm.png
          -rw-r–r-- 1 raspberry raspberry 19927 30. Aug 14:22 qrcode.min.js
          -rw-r–r-- 1 raspberry raspberry 2697 30. Aug 14:22 README.md
          -rw-r–r-- 1 raspberry raspberry 804 30. Aug 14:22 WifiPasswordModal.njk
            sdetweil @Jben1969
            @Jben1969 is MagicMirror running under the raspberry userid?
            if using pm2 do
            pm2 stop all
            then
            cd ~/Magicmirror
            npm start
              @Jben1969 also, what are the MM config.js settings for
              address:
              port:
              ipWhitelist:
                sdetweil @Jben1969
                @Jben1969 did you get this resolved
                  Jben1969
                  today I have tried your suggestions and I have got an error about the WifiModule:
                  [2024-09-22 14:05:39.718] [LOG] Loading module helpers …
                  [2024-09-22 14:05:39.722] [WARN] No /home/raspberry/MagicMirror/js/…/modules/MMM-WiFiPassword/MMM-WiFiPassword.js found for module: MMM-WiFiPassword.
                  [2024-09-22 14:05:39.723] [LOG] No helper found for module: MMM-WiFiPassword.
                  [2024-09-22 14:05:39.726] [LOG] No helper found for module: alert.
                  [2024-09-22 14:05:39.754] [LOG] Initializing new module helper …
                  [2024-09-22 14:05:39.757] [LOG] Module helper loaded: updatenotification
                  [2024-09-22 14:05:39.760] [LOG] No helper found for module: clock.
                  [2024-09-22 14:05:40.214] [LOG] Initializing new module helper …
                  [2024-09-22 14:05:40.215] [LOG] Module helper loaded: calendar
                  [2024-09-22 14:05:40.217] [LOG] No helper found for module: weather.
                  [2024-09-22 14:05:41.114] [LOG] Initializing new module helper …
                  [2024-09-22 14:05:41.115] [LOG] Module helper loaded: MMM-Wallpaper
                  [2024-09-22 14:05:41.117] [LOG] No helper found for module: MMM-CalendarExt3.
                  [2024-09-22 14:05:41.118] [LOG] All module helpers loaded.
                  [2024-09-22 14:05:41.135] [LOG] Starting server on port 8080 …
                  [2024-09-22 14:05:41.177] [WARN] You’re using a full whitelist configuration to allow for all IPs
                  [2024-09-22 14:05:46.656] [LOG] Server started …
                  adress : localhost
                  port: 8080
                  ipWhitelist: []
                  Jochen
                    sdetweil @Jben1969
                    @Jben1969
                    this sounds like a permissions problem
                    can you do
                    ls MMM-WiFiPassword -laF
                      Jben1969 @sdetweil
                      Shame on me, the name of the folder was not right, the capital F of WiFi was a small f.
                      Now everthing is allright, it shows a nice QR-Code of my Guest WiFi.
                      Thank you so much.
                      Jochen
                      • J Jben1969 has marked this topic as solved on
                        sdetweil @Jben1969
                        @Jben1969 awesome
