    iFrame blank when displaing http://<ipaddress LMS server>:9000/material
    27 Posts 3 Posters 3.6k Views 3 Watching
      stephanvdplas
      O, to add this probably important information: This issue only exists on the mirror (Rpi Electron app) itself, not when browsing from another device to http://<ip address mirror>:8080. In that case it works perfectly well.
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @stephanvdplas
        @stephanvdplas this module runs all in browser, so no messages in the npm start console
        open the developers window, ctrl-shift-i, select the console tab
        add a unique part of the module name to the filter field.
        my guess is a cors error, or a reject due to our UserAgent name
          stephanvdplas @sdetweil
          @sdetweil ok I’ll have to attach a kb and mouse to the pi then. Will try this tonight.
            @stephanvdplas you can do debug from a different system if you configured MagicMirror config.js to allow remote system access
              stephanvdplas @stephanvdplas
              @stephanvdplas no errors at all! Only a deprecation warning but it is about a different module .
              Please help me to further troubleshoot. All other web content I tried is working fine and the content I want to show is working fine when browsing the mirror in a different browser via http://<ip address mirror>:8080.
              So it must be some strange thing in electron or jsnode.
                @stephanvdplas in the network tab I see errors:
                This Set-Cookie header didn’t specify a “SameSite” attribute and was defaulted to “SameSite=Lax”, and was blocked because it came from a cross-site response which was not the response to a top-level navigation. The Set-Cookie had to have been set with “SameSite=None to enable cross-site usage.”
                S karsten13K S 3 Replies Last reply Reply Quote 0
                  @stephanvdplas said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
                  Ok, I don’t KNOW for certain, but our cors proxy might work there
                  change the url in the iframe config to
                  http://localhost:MM_PORT/cors?
                  the rest like this
                  // the url
                  url=http://www.test.com/path?param1=value1 // example
                  // if there are headers, skip if not
                  &sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2
                  make sure quotes around the url string
                  • karsten13K Offline
                    karsten13 @stephanvdplas
                    @stephanvdplas
                    mm has a simple internal cors proxy you could try.
                    So instead using the <original-url> in the iframe you could try http://localhost:8080/cors?url=<original-url>.
                    E.g. if your <original-url> is https://example.com try http://localhost:8080/cors?url=https://example.com
                      karsten13 @karsten13
                      ups, sam was quicker …
                        @sdetweil said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
                        the rest like this
                        // the url
                        make sure quotes around the url string’’
                        It doesn’t work. Now there are no errors, but it only shows an empty frame.
                        In the Preview tab, it shows {{snackbar.msg}}
                        [24-09-18 22:33:38.8839] Slim::Utils::Misc::msg (1319) Warniing : [22:33:38.8838] “my” variable $mobile masks earlier declaration in same scope at (eval 5777) line 46.
                        This warning is also seen in the debug log of LMS server, also when I open the 192.168.3.8/material on a browser on a windows machine (where the site is loading correctly).
