    iFrame blank when displaing http://<ipaddress LMS server>:9000/material
    27 Posts 3 Posters 3.5k Views 3 Watching
      stephanvdplas
      I have used the iFrame (as well as MMM-iFrame) module(s) for showing the material skin interface of the Lyrion Media Server, formerly know as SqueezeServer or Logitech Media Server.
      But since the latest MMM update (2.28.0), the iFrame show completely blank.
      There are no (mpm) log errors or warnings when restarting MM2. Other websites, e.g. nu.nl as well as http://<ipaddress LMS server>:9000 (so the standard skin) are working.
      How can I troubleshoot this?
        stephanvdplas
        O, to add this probably important information: This issue only exists on the mirror (Rpi Electron app) itself, not when browsing from another device to http://<ip address mirror>:8080. In that case it works perfectly well.
        S S 2 Replies Last reply Reply Quote 0
          sdetweil @stephanvdplas
          @stephanvdplas this module runs all in browser, so no messages in the npm start console
          open the developers window, ctrl-shift-i, select the console tab
          add a unique part of the module name to the filter field.
          my guess is a cors error, or a reject due to our UserAgent name
            stephanvdplas @sdetweil
            @sdetweil ok I’ll have to attach a kb and mouse to the pi then. Will try this tonight.
              @stephanvdplas you can do debug from a different system if you configured MagicMirror config.js to allow remote system access
                stephanvdplas @stephanvdplas
                @stephanvdplas no errors at all! Only a deprecation warning but it is about a different module .
                Please help me to further troubleshoot. All other web content I tried is working fine and the content I want to show is working fine when browsing the mirror in a different browser via http://<ip address mirror>:8080.
                So it must be some strange thing in electron or jsnode.
                  @stephanvdplas in the network tab I see errors:
                  This Set-Cookie header didn’t specify a “SameSite” attribute and was defaulted to “SameSite=Lax”, and was blocked because it came from a cross-site response which was not the response to a top-level navigation. The Set-Cookie had to have been set with “SameSite=None to enable cross-site usage.”
                  S karsten13K S 3 Replies Last reply Reply Quote 0
                    @stephanvdplas said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
                    Ok, I don’t KNOW for certain, but our cors proxy might work there
                    change the url in the iframe config to
                    http://localhost:MM_PORT/cors?
                    the rest like this
                    // the url
                    url=http://www.test.com/path?param1=value1 // example
                    // if there are headers, skip if not
                    &sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2
                    make sure quotes around the url string
                    • karsten13K Offline
                      karsten13 @stephanvdplas
                      @stephanvdplas
                      mm has a simple internal cors proxy you could try.
                      So instead using the <original-url> in the iframe you could try http://localhost:8080/cors?url=<original-url>.
                      E.g. if your <original-url> is https://example.com try http://localhost:8080/cors?url=https://example.com
                        karsten13 @karsten13
                        ups, sam was quicker …
