    iFrame blank when displaing http://<ipaddress LMS server>:9000/material
    27 Posts 3 Posters 4.8k Views 3 Watching
    • karsten13K Offline
      karsten13 @stephanvdplas
      @stephanvdplas
      mm has a simple internal cors proxy you could try.
      So instead using the <original-url> in the iframe you could try http://localhost:8080/cors?url=<original-url>.
      E.g. if your <original-url> is https://example.com try http://localhost:8080/cors?url=https://example.com
        karsten13 @karsten13
        ups, sam was quicker …
          stephanvdplas @sdetweil
          @sdetweil said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
          @stephanvdplas said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
          Set-Cookie header didn’t specify a “SameSite” attribute and was defaulted to “SameSite=Lax”
          Ok, I don’t KNOW for certain, but our cors proxy might work there
          change the url in the iframe config to
          http://localhost:MM_PORT/cors?
          the rest like this
          // the url
          url=http://www.test.com/path?param1=value1 // example
          // if there are headers, skip if not
          &sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2
          make sure quotes around the url string’’
          It doesn’t work. Now there are no errors, but it only shows an empty frame.
          In the Preview tab, it shows {{snackbar.msg}}
          [24-09-18 22:33:38.8839] Slim::Utils::Misc::msg (1319) Warniing : [22:33:38.8838] “my” variable $mobile masks earlier declaration in same scope at (eval 5777) line 46.
          This warning is also seen in the debug log of LMS server, also when I open the 192.168.3.8/material on a browser on a windows machine (where the site is loading correctly).
            stephanvdplas @stephanvdplas
            @stephanvdplas There is another thing:
            In the preview tab of the content it shows: Failed to load response data: Connection is closed, can’t dispatch pending call to Network.getResponseBody
              sdetweil @stephanvdplas
              @stephanvdplas now I am out of my knowledge range.
              @karsten13 maybe has more skill here…
                karsten13 @sdetweil
                sorry, no. Maybe google has some findings.
                karsten13K S 2 Replies Last reply Reply Quote 0
                  you could try adding
                          electronOptions: {
                                  webPreferences: { webSecurity: false },
                  in config.js
                    stephanvdplas @karsten13
                    @karsten13 good option. I tried it (actually I placed the option directly in the electron.js script) but it doesn’t change the situation at all.
                      @stephanvdplas
                      I can only guess without having the debug case …
                      You can google and try changing electronOptionsDefaults and/or electronSwitchesDefaults in js/electron.js if you find something …
                        @karsten13 I am quite sure about having the config right:
                        	let electronSwitchesDefaults = ["autoplay-policy", "no-user-gesture-required"];
                        	app.commandLine.appendSwitch(...new Set(electronSwitchesDefaults, config.electronSwitches));
                        	let electronOptionsDefaults = {
                        		width: electronSize.width,
                        		height: electronSize.height,
                        		icon: "mm2.png",
                        		x: 0,
                        		y: 0,
                        		darkTheme: true,
                        		webPreferences: {
                        			contextIsolation: true,
                        			nodeIntegration: false,
                        			zoomFactor: config.zoom,
                        			webSecurity: false
                        		backgroundColor: "#000000"
                        	// DEPRECATED: "kioskmode" backwards compatibility, to be removed
                        	// settings these options directly instead provides cleaner interface
                        	if (config.kioskmode) {
                        		electronOptionsDefaults.kiosk = true;
                        	} else {
                        		electronOptionsDefaults.show = false;
                        		electronOptionsDefaults.frame = false;
                        		electronOptionsDefaults.transparent = true;
                        		electronOptionsDefaults.hasShadow = false;
                        		electronOptionsDefaults.fullscreen = true;
                        	const electronOptions = Object.assign({}, electronOptionsDefaults, config.electronOptions);
                        	// Create the browser window.
                        	mainWindow = new BrowserWindow(electronOptions);
                        So the webSecurity line is the only thing I added/changed.
                          sorry, my point is you have to google the error with the keyword “electron” and check if you find something which you can test
                            @karsten13 sorry to report that there is no other possibility than to revert back to electron 30.0.0
                            After this, the iFrame works again. After re-installing 31.0.0, it is broken again.
                            So no I have implemented this workaround.
                            sudo npm install electron@30.0.0
                            this command saved my life mirror
                              @stephanvdplas unrelated to your problem is your solution technique.
                              we provide access to these settings in config.js so you DON’T edit our code, as this causes update problems.
                                ok understood. But but both ways don’t work. Only thing that helps is reverting the installation of electron to 30.0.0.
                                  @stephanvdplas i understand, looks like something changed in 31, which can be a bug as well.
                                  you’ve got a workaround in the near term.
                                  id open an issue on the MagicMirror github page with the error and a link to this topic so we don’t lose it.
                                  finding a test environment will be the tough thing
                                    karsten13 @sdetweil
                                    no, we don’t need another issue we cannot solve.
                                    The problem is chromium which is becoming stricter with every release and with every new electron version you get a new chromium version:
                                    electron	Chromium
                                    31.4.0		126.0.6478.23
                                    31.3.1		126.0.6478.185
                                    31.3.0		126.0.6478.183
                                    31.2.0		126.0.6478.127
                                    31.1.0		126.0.6478.114
                                    31.0.2		126.0.6478.61
                                    31.0.0		126.0.6445.0
                                    30.1.0		124.0.6367.243
                                    30.0.9		124.0.6367.233
                                    30.0.8		124.0.6367.230
                                    30.0.7		124.0.6367.221
                                    30.0.5		124.0.6367.207
                                    30.0.4		124.0.6367.201
                                    30.0.3		124.0.6367.119
                                    30.0.2		124.0.6367.91
                                    30.0.1		124.0.6367.60
                                    30.0.0		124.0.6323.0
                                    Maybe related to this changed in Chromium 125.
                                    We have to deal with this and downgrading chromium (indirect by downgrading electron) is no real solution.
                                      sdetweil @karsten13
                                      @karsten13 said in iFrame blank when displaing http://<ipaddress LMS server>:9000/material:
                                      and how do you proose we do that with all the other things on our plate.
                                      documenting the issue so we can work on ‘dealing’ with it. is the only way in my opinion
                                        karsten13 @sdetweil
                                        I won’t stop you from opening an issue …
                                        • S stephanvdplas has marked this topic as solved on
                                          Off course I’m willing to help with that. Just PM if you need to test something or if I can help set up a test environment.
