    Mirror not starting after update
    33 Posts 4 Posters 10.0k Views 4 Watching
    • X
      xIExodusIx @sdetweil
      the installers folder is still there.
      should I delete it?
      or should run the script without delete the installers folder?
      • X
        if I do npm start
        I get this error at the end:
        [2024-10-02 16:13:22.616] [LOG] All module helpers loaded.
        [2024-10-02 16:13:22.627] [LOG] Starting server on port 8181 …
        [63161:1002/161323.449087:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
        [63161:1002/161323.449298:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          sdetweil @xIExodusIx
          @xIExodusIx said in Mirror not starting after update:
          nodejs is still the same: 18.19.0
          this version like last requires node 20 or 22 (not 21)
          this is the ‘problem’
          magicMirror will not upgrade nodejs… only my upgrade script will do that
          npm run install-mm should have failed as there is a test for the correct node version(s)…
          can you show me the part of
          ~/MagicMirror/installers/upgrade.log
          from one of your upgrade runs?
          or open an issue on my scripts repo and attached the log there
          no personal info is present in the log
          X 1 Reply Last reply Reply Quote 0
          • X
            Upgrade started - Wed Oct 2 15:47:21 CEST 2024
            system is Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
            user requested to force apply changes
            doing test run = false
            the os is PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)” NAME=“Debian GNU/Linux” VERSION_ID=“12” VERSION=“12 (bookworm)” VERSION_CODENAME=bookworm ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
            Minimum Node version: v20.9.0
            Installed Node version: v20.9.0
            Check current Node installation …
            No Node.js upgrade necessary.
            Check current NPM installation …
            Minimum npm version: V10.1.0
            Installed npm version: V10.8.3
            No npm upgrade necessary.
            increasing swap space
            saving custom.css
            remote name = origin
            upgrading from version 2.29.0 to 2.29.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up to date with ‘origin/master’.
            (use “git add …” to update what will be committed)
            (use “git restore …” to discard changes in working directory)
            modified: package-lock.json
            modified: package.json
            Untracked files:
            (use “git add …” to include in what will be committed)
            core
            installers/
            run-start.sh
            splashscreen/
            no changes added to commit (use “git add” and/or “git commit -a”)
            there are 2 local files that are different than the master repo
            package-lock.json
            package.json
            save/restore files selection = y
            erasing lock files
            Saved working directory and index state WIP on master: 94c3c69 Release 2.29.0 (#3568)
            test merge result rc=‘’ , if empty, no conflicts
            executing merge, apply specified
            merge result rc= 0
            Already up to date.
            processor architecture is aarch64
            magicmirror@2.29.0 postinstall
            npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            magicmirror@2.29.0 install-vendor
            echo "Installing vendor files …
            " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 3s
            magicmirror@2.29.0 install-fonts
            echo "Installing fonts …
            " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            Installing fonts …
            up to date in 1s
            magicmirror@2.29.0 prepare
            [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
            no husky installed.
            added 466 packages in 35s
            112 packages are looking for funding
            run npm fund for details
            npm install completed - Wed Oct 2 15:48:06 CEST 2024 on base
            fixing sandbox permissions
            downloading dumpactivemodules script
            updating dependencies for active modules with package.json files
            processing for module MMM-mmpm please wait
            up to date, audited 1 package in 1s
            found 0 vulnerabilities
            processing complete for module MMM-mmpm
            processing for module MMM-pages please wait
            processing complete for module MMM-pages
            processing for module MMM-FlipClock please wait
            added 1 package, and audited 2 packages in 5s
            processing complete for module MMM-FlipClock
            processing for module MMM-GoogleCalendar please wait
            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
            added 52 packages, and audited 53 packages in 26s
            17 packages are looking for funding
            processing complete for module MMM-GoogleCalendar
            processing for module MMM-DynamicWeather please wait
            processing complete for module MMM-DynamicWeather
            processing for module MMM-Bring please wait
            added 3 packages, and audited 4 packages in 3s
            1 package is looking for funding
            1 moderate severity vulnerability
            To address all issues (including breaking changes), run:
            npm audit fix --force
            Run npm audit for details.
            processing complete for module MMM-Bring
            processing for module MMM-PublicTransportHafas please wait
            mmm-publictransporthafas@2.1.1 prepare
            [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
            added 51 packages, and audited 52 packages in 9s
            16 packages are looking for funding
            processing complete for module MMM-PublicTransportHafas
            processing for module MMM-Autobahn please wait
            added 1 package, and audited 2 packages in 2s
            processing complete for module MMM-Autobahn
            processing for module MMM-Globe please wait
            processing complete for module MMM-Globe
            processing for module MMM-FRITZ-Box-Callmonitor-py3 please wait
            added 11 packages, and audited 12 packages in 5s
            processing complete for module MMM-FRITZ-Box-Callmonitor-py3
            processing for module MMM-Fuel please wait
            added 17 packages, and audited 18 packages in 4s
            8 packages are looking for funding
            processing complete for module MMM-Fuel
            processing for module MMM-NINA please wait
            processing complete for module MMM-NINA
            processing for module MMM-network-signal please wait
            added 1 package, and audited 2 packages in 4s
            processing complete for module MMM-network-signal
            restoring custom.css
            removing git alias
            we stashed a set of files that appear changed from the latest repo versions. you should review them
            Upgrade ended - Wed Oct 2 15:49:22 CEST 2024
              @xIExodusIx
              https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
              you are on node 20.9.
              package-lock.json
              package.json
              sorry, you cannot save/restore those two files…
              they are the KEY files for each release
              so, do
              git diff package.json >somefile.txt
              git checkout package.json
              git checkout package-lock.json
              rm -rf node_modules
              npm run install-mm
              any changes you made to package.json are shown in the
              somefile.txt if you need to re-apply them to the new package.json file
              generally first rule, NEVER edit any files we ship.
              1 it breaks upgrades
              2 YOU are RESPONSIBLE for remembering WHAT and WHY you did it and how to fix it for next time.
              this is why my upgrade script is TWO passes… to detect changes to critical files and warn you … help you remember (before we whack them)
              • X
                Sorry I didn’t know that, I thought that it were better to save/restore these files. Next time i will answer that question with no.
                  @xIExodusIx BUT their presence in the list SHOULD have made you think…
                  what did I change? and is it still important…
                  that is why I recommend running the test pass to find those things…
                  my hope is to never break a running mirror…
                  • X
                    Sorry, I thougt they were important so thought it were better to save/restore them.
                    I never changed anything in them, I can not code, I’m too stupid for coding!
                    The question will you save tells me they are important otherwise they were maybe orverwritten so it is better to save them.
                    I did not know that they were KEY-files for each new versions of MM and had (must) to be replaced by new ones.
                    I never will answer that quesion with yes again.
                    Now I will start to install my MM from scratch again for get it work. This will be my last attemp. When this does not work this time I will give up my MagicMirror project.
                    Thanks for helping.
                      @xIExodusIx you do not need to start over…
                      jut use the command I gave to restore the 2 files and do the npm install again
                      all will be well…
                      X 2 Replies Last reply Reply Quote 0
                      • X
                        I did that, but my MM won’t show up!
                        And now it’s to late I already killed my USB-Boot-Stick by writing the working MM-Image from yesterday to it.
                          chrisfr1976 @sdetweil
                          Mirror is running now. I used
                          rm -rf node_modules
                          npm run install-mm
                          I didn‘t change anything there but this fixed my main problem.
                          But I still have this error message when I use pm2 start whatever. But it may be cosmetics…
                          Thanks for your help one again!
                          Chris
                          Regards, Chris.
                          • X
                            So it’s up and running with MM 2.29.
                            I think I will never touch it again, only make OS updates/upgrades and nothing else.
