    Mirror not starting after update
    33 Posts 4 Posters 9.2k Views 4 Watching
    • X Offline
      xIExodusIx @sdetweil
      if I do npm start
      I get this error at the end:
      [2024-10-02 16:13:22.616] [LOG] All module helpers loaded.
      [2024-10-02 16:13:22.627] [LOG] Starting server on port 8181 …
      [63161:1002/161323.449087:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
      [63161:1002/161323.449298:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        sdetweil @xIExodusIx
        @xIExodusIx said in Mirror not starting after update:
        nodejs is still the same: 18.19.0
        this version like last requires node 20 or 22 (not 21)
        this is the ‘problem’
        magicMirror will not upgrade nodejs… only my upgrade script will do that
        npm run install-mm should have failed as there is a test for the correct node version(s)…
        can you show me the part of
        ~/MagicMirror/installers/upgrade.log
        from one of your upgrade runs?
        or open an issue on my scripts repo and attached the log there
        no personal info is present in the log
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          Upgrade started - Wed Oct 2 15:47:21 CEST 2024
          system is Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
          user requested to force apply changes
          doing test run = false
          the os is PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)” NAME=“Debian GNU/Linux” VERSION_ID=“12” VERSION=“12 (bookworm)” VERSION_CODENAME=bookworm ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
          Minimum Node version: v20.9.0
          Installed Node version: v20.9.0
          Check current Node installation …
          No Node.js upgrade necessary.
          Check current NPM installation …
          Minimum npm version: V10.1.0
          Installed npm version: V10.8.3
          No npm upgrade necessary.
          increasing swap space
          saving custom.css
          remote name = origin
          upgrading from version 2.29.0 to 2.29.0
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is up to date with ‘origin/master’.
          (use “git add …” to update what will be committed)
          (use “git restore …” to discard changes in working directory)
          modified: package-lock.json
          modified: package.json
          Untracked files:
          (use “git add …” to include in what will be committed)
          core
          installers/
          run-start.sh
          splashscreen/
          no changes added to commit (use “git add” and/or “git commit -a”)
          there are 2 local files that are different than the master repo
          package-lock.json
          package.json
          save/restore files selection = y
          erasing lock files
          Saved working directory and index state WIP on master: 94c3c69 Release 2.29.0 (#3568)
          test merge result rc=‘’ , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
          Already up to date.
          processor architecture is aarch64
          magicmirror@2.29.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.29.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 3s
          magicmirror@2.29.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          up to date in 1s
          magicmirror@2.29.0 prepare
          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          added 466 packages in 35s
          112 packages are looking for funding
          run npm fund for details
          npm install completed - Wed Oct 2 15:48:06 CEST 2024 on base
          fixing sandbox permissions
          downloading dumpactivemodules script
          updating dependencies for active modules with package.json files
          processing for module MMM-mmpm please wait
          up to date, audited 1 package in 1s
          found 0 vulnerabilities
          processing complete for module MMM-mmpm
          processing for module MMM-pages please wait
          processing complete for module MMM-pages
          processing for module MMM-FlipClock please wait
          added 1 package, and audited 2 packages in 5s
          processing complete for module MMM-FlipClock
          processing for module MMM-GoogleCalendar please wait
          npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
          added 52 packages, and audited 53 packages in 26s
          17 packages are looking for funding
          processing complete for module MMM-GoogleCalendar
          processing for module MMM-DynamicWeather please wait
          processing complete for module MMM-DynamicWeather
          processing for module MMM-Bring please wait
          added 3 packages, and audited 4 packages in 3s
          1 package is looking for funding
          1 moderate severity vulnerability
          To address all issues (including breaking changes), run:
          npm audit fix --force
          Run npm audit for details.
          processing complete for module MMM-Bring
          processing for module MMM-PublicTransportHafas please wait
          mmm-publictransporthafas@2.1.1 prepare
          [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
          added 51 packages, and audited 52 packages in 9s
          16 packages are looking for funding
          processing complete for module MMM-PublicTransportHafas
          processing for module MMM-Autobahn please wait
          added 1 package, and audited 2 packages in 2s
          processing complete for module MMM-Autobahn
          processing for module MMM-Globe please wait
          processing complete for module MMM-Globe
          processing for module MMM-FRITZ-Box-Callmonitor-py3 please wait
          added 11 packages, and audited 12 packages in 5s
          processing complete for module MMM-FRITZ-Box-Callmonitor-py3
          processing for module MMM-Fuel please wait
          added 17 packages, and audited 18 packages in 4s
          8 packages are looking for funding
          processing complete for module MMM-Fuel
          processing for module MMM-NINA please wait
          processing complete for module MMM-NINA
          processing for module MMM-network-signal please wait
          added 1 package, and audited 2 packages in 4s
          processing complete for module MMM-network-signal
          restoring custom.css
          removing git alias
          we stashed a set of files that appear changed from the latest repo versions. you should review them
          Upgrade ended - Wed Oct 2 15:49:22 CEST 2024
            @xIExodusIx
            https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
            you are on node 20.9.
            package-lock.json
            package.json
            sorry, you cannot save/restore those two files…
            they are the KEY files for each release
            so, do
            git diff package.json >somefile.txt
            git checkout package.json
            git checkout package-lock.json
            rm -rf node_modules
            npm run install-mm
            any changes you made to package.json are shown in the
            somefile.txt if you need to re-apply them to the new package.json file
            generally first rule, NEVER edit any files we ship.
            1 it breaks upgrades
            2 YOU are RESPONSIBLE for remembering WHAT and WHY you did it and how to fix it for next time.
            this is why my upgrade script is TWO passes… to detect changes to critical files and warn you … help you remember (before we whack them)
            • X Offline
              Sorry I didn’t know that, I thought that it were better to save/restore these files. Next time i will answer that question with no.
                @xIExodusIx BUT their presence in the list SHOULD have made you think…
                what did I change? and is it still important…
                that is why I recommend running the test pass to find those things…
                my hope is to never break a running mirror…
                • X Offline
                  Sorry, I thougt they were important so thought it were better to save/restore them.
                  I never changed anything in them, I can not code, I’m too stupid for coding!
                  The question will you save tells me they are important otherwise they were maybe orverwritten so it is better to save them.
                  I did not know that they were KEY-files for each new versions of MM and had (must) to be replaced by new ones.
                  I never will answer that quesion with yes again.
                  Now I will start to install my MM from scratch again for get it work. This will be my last attemp. When this does not work this time I will give up my MagicMirror project.
                  Thanks for helping.
                    @xIExodusIx you do not need to start over…
                    jut use the command I gave to restore the 2 files and do the npm install again
                    all will be well…
                    X 2 Replies Last reply Reply Quote 0
                    • X Offline
                      I did that, but my MM won’t show up!
                      And now it’s to late I already killed my USB-Boot-Stick by writing the working MM-Image from yesterday to it.
                        chrisfr1976 @sdetweil
                        Mirror is running now. I used
                        rm -rf node_modules
                        npm run install-mm
                        I didn‘t change anything there but this fixed my main problem.
                        But I still have this error message when I use pm2 start whatever. But it may be cosmetics…
                        Thanks for your help one again!
                        Chris
                        Regards, Chris.
                        • X Offline
                          So it’s up and running with MM 2.29.
                          I think I will never touch it again, only make OS updates/upgrades and nothing else.
