    MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4
    10 Posts 3 Posters 981 Views 3 Watching
      sdetweil @raspberrypi9
      @raspberrypi9 I do not… my pi’s run all day every day
      3/4/5/odroid
        raspberrypi9
        /varl/log/messages:
        Dec 20 01:02:58 mirror kernel: [ 6510.507323] schedule from __mmc_claim_host+0x
        c0/0x208
        Dec 20 01:03:00 mirror kernel: [ 6510.507360] __mmc_claim_host from mmc_sd_dete
        ct+0x1c/0x74
        Dec 20 01:03:02 mirror kernel: [ 6510.507402] mmc_sd_detect from mmc_rescan+0xa
        4/0x2e0
        Dec 20 01:03:03 mirror kernel: [ 6510.507431] mmc_rescan from process_one_work+
        0x244/0x508
        Dec 20 01:03:05 mirror kernel: [ 6510.507465] process_one_work from worker_thre
        ad+0x48/0x558
        Dec 20 01:03:07 mirror kernel: [ 6510.507498] worker_thread from kthread+0xe4/0x100
        Dec 20 01:03:09 mirror kernel: [ 6510.507532] kthread from ret_from_fork+0x14/0x34
        Dec 20 01:03:12 mirror kernel: [ 6510.507558] Exception stack(0xbbe1dfb0 to 0xbbe1dff8)
        Dec 20 01:03:13 mirror kernel: [ 6510.507574] dfa0: 00000000 00000000 00000000 00000000
        Dec 20 01:03:14 mirror kernel: [ 6510.507592] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
        Dec 20 01:03:14 mirror kernel: [ 6510.507607] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
        /var/log/syslog:
        Dec 20 00:46:30 mirror kernel: [ 5527.545960] Exception stack(0xbc405fb0 to 0xbc405ff8)
        Dec 20 00:46:30 mirror kernel: [ 5527.545977] 5fa0: 00000000 00000000 00000000 00000000
        Dec 20 00:46:30 mirror kernel: [ 5527.545995] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
        Dec 20 00:46:30 mirror kernel: [ 5527.546011] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
        Dec 20 01:02:52 mirror kernel: [ 6510.507132] INFO: task kworker/0:0:3629 blocked for more than 122 seconds.
        Dec 20 01:02:53 mirror kernel: [ 6510.507190] Tainted: G C 6.1.21-v7+ #1642
        Dec 20 01:02:54 mirror kernel: [ 6510.507203] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
        Dec 20 01:02:55 mirror kernel: [ 6510.507212] task:kworker/0:0 state:D stack:0 pid:3629 ppid:2 flags:0x00000000
        Dec 20 01:02:56 mirror kernel: [ 6510.507247] Workqueue: events_freezable mmc_rescan
        Dec 20 01:02:57 mirror kernel: [ 6510.507288] __schedule from schedule+0x58/0xf0
        Dec 20 01:02:58 mirror kernel: [ 6510.507323] schedule from __mmc_claim_host+0xc0/0x208
        Dec 20 01:03:00 mirror kernel: [ 6510.507360] __mmc_claim_host from mmc_sd_detect+0x1c/0x74
        Dec 20 01:03:02 mirror kernel: [ 6510.507402] mmc_sd_detect from mmc_rescan+0xa4/0x2e0
        Dec 20 01:03:03 mirror kernel: [ 6510.507431] mmc_rescan from process_one_work+0x244/0x508
        Dec 20 01:03:05 mirror kernel: [ 6510.507465] process_one_work from worker_thread+0x48/0x558
          raspberrypi9
          I have other projects running on other Pis and they have been running with 2 years uptime. I think it is something about the Magic Mirror application and maybe the Raspberry Pi 3B. I would switch to a Pi 4, but like I said, I can’t control the brightness with the Pi 4.
            @raspberrypi9 MagicMirror is just a browser w javascript
            unless there are gpio modules
            does this pi3 have a fan?
            do you get the same on the 32 bit os?
            the stack errors sound like hardware problem
              raspberrypi9 @sdetweil
              @sdetweil I am using a gpio module and a PIR motion sensor. I don’t have a fan. I am running bullseye 32-bit os. Should I try changing any of those things?
                @raspberrypi9 i don’t know. i have pi3 w and wo fan
                • karsten13K Offline
                  karsten13 @raspberrypi9
                  @raspberrypi9
                  this can be caused by a specific module so you can try disabling one by one …
