    Magic Mirror continuously resets when I view from browser
    15 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @Dexter1088
      @Dexter1088 do you have the fix on?
      https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
      i dont see server restart
        Dexter1088 @sdetweil
        I do, after some troubleshooting I think the error is with how I have the Calendar ext3 config setup.
        Soon as I take this code out, everything works fine from browser and no resets.
        I will look it over make sure I’m not doing something wrong.
        /*/ CALENDAR EXT3
                    module: "MMM-CalendarExt3",
                    pages: {
                        calendar: "middle_center"
                        mode: "month",
                        instanceId: "Main_Calendar",
                        locale: "en-US",
        		maxEventLines: 5,
                        firstDayOfWeek: 1,
                        monthIndex: 0,
                        calendarSet:
                            'Calendar 1',
                            'Calendar 2',
        		    'Calendar 3',
        		    'Calendar 4'
                        fontSize: "18x",
        		eventHeight: "22px",
                        useSymbol: true,
                        displayLegend: true,
                        cellDateOptions: {
                            month: "short",
                            day: "numeric"
                        headerWeekDayOptions: {
                            weekday: "long"
                        eventTimeOptions: {
                            timeStyle: "short"
                        animationSpeed: 1000,
                        skipPassedEventToday: false,
                        showMore: true,
                        useMarquee: false,
         refreshInterval: 1000000 ,
            scanInterval: 100000,
            broadcastPastEvents: true
          @Dexter1088 broadcastPastEvents is a default cal parm
          what is the pages:{} thing
          not in ext3
            https://github.com/edward-shen/MMM-pages
              That’s the problem though, soon as I take out the pages, the web view works fine. something fishy with it. Weird it works on the Raspberry Pi directly just fine.
                @Dexter1088 ok. thats not the correct config
                if you use the classes approach
                classes: at each module
                otherwise the module names are in the page definitions
                  Dexter1088 @Dexter1088
                  I’m an idiot, sorry its not MMM-Pages its MMM-Page selector…
                  https://github.com/Veldrovive/MMM-Page-Selector
                  I’m working with it now to see if I have it in the wrong spot, but it’s defiantly what is causing the constant reboots/refresh’s. Thanks!
                    Dexter1088
                    Does anyone know or have an alternative module to MMM-Page-Selector?
                    The problem is defiantly with that module, and I can’t seem to find a good work around. Soon as I view it from the browser it goes nuts and refresh’s over and over.
                    I’m just looking for something that will allow me to set different pages I can view like “Home, Calendar, tasks”
                    Thanks!
                      @Dexter1088 i’m leaving off the mmm
                      pages, carousel, modulesrotation
                      see the third party list linked in the top menu here
                      pages lets you use arbitrary names for the pages
                      • D Dexter1088 has marked this topic as solved on
                        Thankyou, went with MMM-Pages and no more refresh issues, thanks!
