    Magic Mirror continuously resets when I view from browser
    15 Posts 2 Posters 3.9k Views 2 Watching
      Dexter1088 @sdetweil
      No worries I had the calendar URL changed in the last one
      this one they are Calendar 1,2,3,4.
      pm2 shows no instances running
      Some File.txt
      > magicmirror@2.31.0-develop start
      > npm run start:x11
      > magicmirror@2.31.0-develop start:x11
      [2025-02-07 21:22:29.326] [LOG]   Starting MagicMirror: v2.31.0-develop
      [2025-02-07 21:22:29.430] [LOG]   Loading config ...
      [2025-02-07 21:22:29.439] [LOG]   config template file not exists, no envsubst
      [2025-02-07 21:22:32.160] [INFO]  Checking config file /home/jj/MagicMirror/config/config.js ...
      [2025-02-07 21:22:32.452] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-02-07 21:22:32.455] [INFO]  Checking modules structure configuration ...
      [2025-02-07 21:22:32.857] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-02-07 21:22:32.866] [LOG]   Loading module helpers ...
      [2025-02-07 21:22:32.929] [LOG]   Initializing new module helper ...
      [2025-02-07 21:22:32.932] [LOG]   Module helper loaded: MMM-Page-Selector
      [2025-02-07 21:22:32.936] [LOG]   No helper found for module: MMM-ButtonMenus.
      [2025-02-07 21:22:32.968] [LOG]   Initializing new module helper ...
      [2025-02-07 21:22:32.969] [LOG]   Module helper loaded: MMM-OnScreenMenu
      [2025-02-07 21:22:33.712] [LOG]   Initializing new module helper ...
      [2025-02-07 21:22:33.713] [LOG]   Module helper loaded: calendar
      [2025-02-07 21:22:33.733] [LOG]   No helper found for module: MMM-CalendarExt3.
      [2025-02-07 21:22:33.734] [LOG]   All module helpers loaded.
      [2025-02-07 21:22:33.764] [LOG]   Starting server on port 8080 ...
      [2025-02-07 21:22:33.774] [WARN]  You're using a full whitelist configuration to allow for all IPs
      [2025-02-07 21:22:35.362] [LOG]   Server started ...
      [2025-02-07 21:22:35.366] [LOG]   Connecting socket for: MMM-Page-Selector
      [2025-02-07 21:22:35.372] [LOG]   Connecting socket for: MMM-OnScreenMenu
      [2025-02-07 21:22:35.375] [LOG]   Connecting socket for: calendar
      [2025-02-07 21:22:35.378] [LOG]   Starting node helper for: calendar
      [2025-02-07 21:22:35.380] [LOG]   Sockets connected & modules started ...
      [2025-02-07 21:22:43.076] [LOG]   Launching application.
      [2025-02-07 21:22:48.141] [INFO]  System information:
      ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; virtual: false
      ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 12; arch: arm; kernel: 6.6.51+rpt-rpi-v7
      ### VERSIONS: electron: 32.2.7; used node: 23.6.0; installed node: 23.6.0; npm: 10.9.2; pm2: 5.4.3
      ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
      [2025-02-07 21:22:52.579] [LOG]   Create new calendarfetcher for url: Calendar1 - Interval: 3600000
      [2025-02-07 21:22:52.878] [LOG]   Create new calendarfetcher for url: Calendar2 - Interval: 3600000
      [2025-02-07 21:22:52.889] [LOG]   Create new calendarfetcher for url: Calendar3 - Interval: 3600000
      [2025-02-07 21:22:52.900] [LOG]   Create new calendarfetcher for url: Calendar4 - Interval: 3600000
      [2025-02-07 21:22:54.146] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:22:54.454] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:22:56.392] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:23:00.694] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:23:02.130] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:23:02.131] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:23:02.154] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:23:02.156] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:23:02.177] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:23:02.178] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:23:02.186] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:23:02.188] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:23:02.616] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:23:02.629] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:23:03.975] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:23:08.124] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      and here’s after I view from browser
      [2025-02-07 21:28:40.025] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:28:40.027] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:40.047] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:28:40.048] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:40.074] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:28:40.075] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:40.084] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:28:40.085] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:40.627] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:40.954] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:41.554] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:28:41.555] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:41.563] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:28:41.564] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:41.582] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:28:41.585] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:41.593] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:28:41.595] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:42.850] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:42.986] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:43.082] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:44.268] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:48.213] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:52.107] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:52.814] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:28:52.815] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:52.831] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:28:52.832] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:52.847] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:28:52.848] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:52.857] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:28:52.858] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:53.659] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:53.681] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:55.232] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:55.242] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:28:55.243] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:28:55.249] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:28:55.250] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:28:55.261] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:28:55.262] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:55.266] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:28:55.267] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:55.427] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:28:55.599] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:28:56.695] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:29:00.300] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:29:04.126] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:29:04.625] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:29:04.626] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:29:04.643] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:29:04.644] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:29:04.659] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:29:04.660] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:29:04.666] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:29:04.667] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:29:04.946] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:29:05.487] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:29:06.690] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:29:10.874] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:29:11.655] [LOG]   Use existing calendarfetcher for url: Calendar1
      [2025-02-07 21:29:11.657] [INFO]  Calendar-Fetcher: Broadcasting 41 events from Calendar1.
      [2025-02-07 21:29:11.668] [LOG]   Use existing calendarfetcher for url: Calendar2
      [2025-02-07 21:29:11.669] [INFO]  Calendar-Fetcher: Broadcasting 203 events from Calendar2.
      [2025-02-07 21:29:11.686] [LOG]   Use existing calendarfetcher for url: Calendar3
      [2025-02-07 21:29:11.687] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:29:11.694] [LOG]   Use existing calendarfetcher for url: Calendar4
      [2025-02-07 21:29:11.695] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
      [2025-02-07 21:29:12.037] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar3.
      [2025-02-07 21:29:12.131] [INFO]  Calendar-Fetcher: Broadcasting 0 events from Calendar4.
        sdetweil @Dexter1088
        @Dexter1088 do you have the fix on?
        https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
        i dont see server restart
        D 1 Reply Last reply
          I do, after some troubleshooting I think the error is with how I have the Calendar ext3 config setup.
          Soon as I take this code out, everything works fine from browser and no resets.
          I will look it over make sure I’m not doing something wrong.
          /*/ CALENDAR EXT3
                      module: "MMM-CalendarExt3",
                      pages: {
                          calendar: "middle_center"
                          mode: "month",
                          instanceId: "Main_Calendar",
                          locale: "en-US",
          		maxEventLines: 5,
                          firstDayOfWeek: 1,
                          monthIndex: 0,
                          calendarSet:
                              'Calendar 1',
                              'Calendar 2',
          		    'Calendar 3',
          		    'Calendar 4'
                          fontSize: "18x",
          		eventHeight: "22px",
                          useSymbol: true,
                          displayLegend: true,
                          cellDateOptions: {
                              month: "short",
                              day: "numeric"
                          headerWeekDayOptions: {
                              weekday: "long"
                          eventTimeOptions: {
                              timeStyle: "short"
                          animationSpeed: 1000,
                          skipPassedEventToday: false,
                          showMore: true,
                          useMarquee: false,
           refreshInterval: 1000000 ,
              scanInterval: 100000,
              broadcastPastEvents: true
            @Dexter1088 broadcastPastEvents is a default cal parm
            what is the pages:{} thing
            not in ext3
            D 2 Replies Last reply
              https://github.com/edward-shen/MMM-pages
                That’s the problem though, soon as I take out the pages, the web view works fine. something fishy with it. Weird it works on the Raspberry Pi directly just fine.
                  @Dexter1088 ok. thats not the correct config
                  if you use the classes approach
                  classes: at each module
                  otherwise the module names are in the page definitions
                    Dexter1088 @Dexter1088
                    I’m an idiot, sorry its not MMM-Pages its MMM-Page selector…
                    https://github.com/Veldrovive/MMM-Page-Selector
                    I’m working with it now to see if I have it in the wrong spot, but it’s defiantly what is causing the constant reboots/refresh’s. Thanks!
                      Dexter1088
                      Does anyone know or have an alternative module to MMM-Page-Selector?
                      The problem is defiantly with that module, and I can’t seem to find a good work around. Soon as I view it from the browser it goes nuts and refresh’s over and over.
                      I’m just looking for something that will allow me to set different pages I can view like “Home, Calendar, tasks”
                      Thanks!
                        @Dexter1088 i’m leaving off the mmm
                        pages, carousel, modulesrotation
                        see the third party list linked in the top menu here
                        pages lets you use arbitrary names for the pages
                        • D Dexter1088 has marked this topic as solved on
                          Thankyou, went with MMM-Pages and no more refresh issues, thanks!
                            @Dexter1088 awesome
