    Slideshow for PDFs question
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @kochb1988
      @kochb1988 i have not seen a module that says it does this.
      did u look thru the third party modules? (list linked in the top menu above)
      • K
        kochb1988 @sdetweil
        @sdetweil I have not seen a real good example of what I believe is needed. I’m looking at it 2 ways at once just in case. 1: A rotating MM screen (module exists) between a calendar and a pdf viewer (don’t believe it exists. 2: The ability to control the rotation of the screen. Such as: Always showing the calendar. But, when time for a presentation, the user can click something on-screen (with kb/mouse attached) that would switch the screen to the PDF and maaayyyyybe have the ability to control the PDF slide show.
          sdetweil @kochb1988
          @kochb1988 mmm-pages can do this
          using the hidden page config for pdf module
          but you need the pdf module
            @kochb1988 here is a lib someone could use to create a module
            https://www.npmjs.com/package/pdfjs-dist
            the module would need to create a canvas element for the
            library to draw in. not hard
            use the getscripts: method to load the lib for browser access
              chrisfr1976 @sdetweil
              Challenge accepted :)
              MMM-PDFSlideshow
              I had some time today so I sat down and created something. Maybe useful. I’ll upload some Asterix-pdf to my mirror.
              I’m happy with this status. If anyone needs modifications create a pull request. I’m not happy with the fullscreen behavior since the scaling does not work as expected (fullscreen always uses the full width, so a full page display is not nice in landscape orientation). But I do not really need this.
              Regards, Chris.
                sdetweil @chrisfr1976
                @chrisfr1976 cool. why fullscreen or if set to fullscreen position?
                can be sized w css
                  @sdetweil Hi, this is the rest of my tries to show the page in 100% in fullscreen mode. So if position is set to a fullscreen region then also the fullscreen flag must be activated.
                  Regards, Chris.
                    @chrisfr1976 cool, should be possible to control in fullscreen w css.
                    in car, does this support url to pdf, or just local file?
                    (just local file)
                      now also hosted PDF-files are supported. PDF with url have now the lead. The local pdfs/ folder is the fall-back if no URL is set or in case of any errors.
                      But:
                      Most remote PDF is being blocked due to Cross-Origin Resource Sharing restrictions. The server hosting the PDF (https://www.w3.org/… etc.) is not allowing MagicMirror to access its resource. So the server-side PDF is downloaded locally and saved in a folder. Once the file exists locally, the download isn’t performed again. So if the server pdf is updated then the local download must be deleted.
                      • If a URL-PDF (or one single PDF) should be displayed change displayTime: 10000, to a higher value (avoid flickering)
                      • If a downloaded and local pdf should be displayed then copy or move the pdf from the pdfURL to pdfs folder and leave the URL in the config blank.
                      I think there are some optimizations in file handling possible and maybe a new PDF-URL can be sent with MMM-Remote module. But I won’t work on that any further. I will use the local folder in general (if I use the module at all - don’t know).
                      Regards, Chris.
                        @chrisfr1976 have you looked at the cors server api we provide?
                          Ö, no :)
                          Where?
                          Regards, Chris.
                            @chrisfr1976 not well documented and not 100%
                            http://mm_server:mm_port/cors?url=…,
                            sendheaders=…,
                            receiveheaders=…
                            send/receive headers are headername:value,…
                            code in js/server_functions.js
                            for my readme support in mmm-config i had to fallback to curl/wget
