    Slideshow for PDFs question
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 8.5k Views 3 Watching
    • K
      kochb1988 @sdetweil
      @sdetweil I have not seen a real good example of what I believe is needed. I’m looking at it 2 ways at once just in case. 1: A rotating MM screen (module exists) between a calendar and a pdf viewer (don’t believe it exists. 2: The ability to control the rotation of the screen. Such as: Always showing the calendar. But, when time for a presentation, the user can click something on-screen (with kb/mouse attached) that would switch the screen to the PDF and maaayyyyybe have the ability to control the PDF slide show.
        sdetweil @kochb1988
        @kochb1988 mmm-pages can do this
        using the hidden page config for pdf module
        but you need the pdf module
          @kochb1988 here is a lib someone could use to create a module
          https://www.npmjs.com/package/pdfjs-dist
          the module would need to create a canvas element for the
          library to draw in. not hard
          use the getscripts: method to load the lib for browser access
          C 1 Reply Last reply
            chrisfr1976 @sdetweil
            Challenge accepted :)
            MMM-PDFSlideshow
            I had some time today so I sat down and created something. Maybe useful. I’ll upload some Asterix-pdf to my mirror.
            I’m happy with this status. If anyone needs modifications create a pull request. I’m not happy with the fullscreen behavior since the scaling does not work as expected (fullscreen always uses the full width, so a full page display is not nice in landscape orientation). But I do not really need this.
            Regards, Chris.
            Reply Quote 2
              sdetweil @chrisfr1976
              @chrisfr1976 cool. why fullscreen or if set to fullscreen position?
              can be sized w css
                @sdetweil Hi, this is the rest of my tries to show the page in 100% in fullscreen mode. So if position is set to a fullscreen region then also the fullscreen flag must be activated.
                Regards, Chris.
                  @chrisfr1976 cool, should be possible to control in fullscreen w css.
                  in car, does this support url to pdf, or just local file?
                  (just local file)
                    now also hosted PDF-files are supported. PDF with url have now the lead. The local pdfs/ folder is the fall-back if no URL is set or in case of any errors.
                    But:
                    Most remote PDF is being blocked due to Cross-Origin Resource Sharing restrictions. The server hosting the PDF (https://www.w3.org/… etc.) is not allowing MagicMirror to access its resource. So the server-side PDF is downloaded locally and saved in a folder. Once the file exists locally, the download isn’t performed again. So if the server pdf is updated then the local download must be deleted.
                    • If a URL-PDF (or one single PDF) should be displayed change displayTime: 10000, to a higher value (avoid flickering)
                    • If a downloaded and local pdf should be displayed then copy or move the pdf from the pdfURL to pdfs folder and leave the URL in the config blank.
                    I think there are some optimizations in file handling possible and maybe a new PDF-URL can be sent with MMM-Remote module. But I won’t work on that any further. I will use the local folder in general (if I use the module at all - don’t know).
                    Regards, Chris.
                      @chrisfr1976 have you looked at the cors server api we provide?
                        Ö, no :)
                        Where?
                        Regards, Chris.
                          @chrisfr1976 not well documented and not 100%
                          http://mm_server:mm_port/cors?url=…,
                          sendheaders=…,
                          receiveheaders=…
                          send/receive headers are headername:value,…
                          code in js/server_functions.js
                          for my readme support in mmm-config i had to fallback to curl/wget
