    Problems with WLAN connectivity - solved
    10 Posts 3 Posters 3.7k Views 4 Watching
      rkorell Module Developer
      Dear mirror fans,
      for your information and reference some findings with my mirror.
      I’m running a MagicMirror on a PI5 with an NVME HAT as boot device.
      My first approach was to de-assemble an original Pi power supply (because of its form factor) and to build this internally into the mirror-frame.
      As reported earlier in a different thread this power supply died due to overheating.
      My next approach was to use a new PI-power supply - this time externally.
      Caused by the circumstances of my installation (power plug far below mirror position and Pi mounted on the top of the mirror) I have used a USB-C to USB-C cable (150cm, 5A) to extend the standard-cable.
      As it turns out now this wasn’t a good idea, ether:
      It worked pretty long (several weeks) good and without any problem.
      But since some days I got more and more really stubborn WLAN losses which were often unrecoverable - only plugging out power supply to reforce a restart helped (I’m working headless as majority of you).
      In the meantime I was able to implement a tiny service which automatically detects the connectivity loss and restarts the WLAN, so a sufficient symptomatic treatment is in place - this discovers connectivity every five minutes, which is OK to me.
      While I was just tinkering I’ve thought it could be a nice idea to identify the root cause and so I added some logging features in the mentioned service.
      Now the interesting (unexpected) finding: Obvious root cause was an undervoltage!
      I’ve searched around (because initially I failed to remember my “cable-extension”) but couldn’t find any reason for this (nothing attached else than the NVME and my mirror doesn’t have anything heavily using the harddisk)…
      Then the additional cable came in my mind and - voilà - this was the root cause - despite its thickness and 5A specification.
      For now I have added some 230V cabeling to the top of the mirror, installed there (outside the mirror frame) a third (de-assembled) PI power supply and connected the standard-long cable of this power supply to the Pi.
      Since then no undervoltage detected (prior to this every few minutes).
      So my learning: Pi is bitchy with cable extensions and tiny undervoltages can lead to heavy WLAN problems.
      May one or the other can benefit from these findings.
      Warm regards,
      Ralf
        sdetweil @rkorell
        @rkorell awesome post, great info!
          @sdetweil :-)
          Thanks.
          In addition: If somebody is interested in the scripts and system-services definitions for own purposes - give me a ping and I will share this for sure…
          Regards,
          Ralf
            schlomm @rkorell
            @rkorell Thanks for your Insights! Interesting!
            One question: How you got the idea that the issue is caused by power/energy circumstances?
            Are there any specific logs with those information?
            And yes - it would be great to get an idea of your scripts :)
              rkorell Module Developer @schlomm
              Dear @schlomm ,
              I initially had no clue at all regarding root cause :-)
              And the finding “undervoltage” was never expected but came out off my logfiles.
              After a LOT of tinkering and playing with syptomatic “solutions” system kept to be unstable so I decided to dig in and do some logging to identify root cause.
              For this I wrote a shellscript and installed a system service which collects this data every five minutes.
              shellscript:
              sudo nano /usr/local/bin/wlan-diagnose.sh
              content:
              #!/bin/bash
              LOGFILE="/var/log/wlan-diagnose.log"
              DATE=$(date '+%a %d %b %H:%M:%S %Z %Y')
              WLAN_IF="wlan0"
              echo "===== $DATE =====" >> $LOGFILE
              # IP-Adresse
              echo "--- IP-Adresse ---" >> $LOGFILE
              ip addr show $WLAN_IF >> $LOGFILE 2>&1
              # Link-Status
              echo "--- Link Status ---" >> $LOGFILE
              iw dev $WLAN_IF link >> $LOGFILE 2>&1
              # Default Route
              echo "--- Routing ---" >> $LOGFILE
              ip route >> $LOGFILE 2>&1
              # Wpa_supplicant Status
              echo "--- wpa_supplicant ---" >> $LOGFILE
              systemctl status wpa_supplicant --no-pager >> $LOGFILE 2>&1
              # Letzte wpa_supplicant Logs
              echo "--- wpa_supplicant journal (letzte 20 Zeilen) ---" >> $LOGFILE
              journalctl -u wpa_supplicant -n 20 --no-pager >> $LOGFILE 2>&1
              # Kernel/Treiber Logs
              echo "--- dmesg wlan0 ---" >> $LOGFILE
              dmesg | tail -n 20 >> $LOGFILE 2>&1
              # Ping-Test
              PING_TARGET="8.8.8.8"
              ping -I $WLAN_IF -c3 -W3 $PING_TARGET >> $LOGFILE 2>&1
              echo "" >> $LOGFILE
              set as executable:
              sudo chmod +x /usr/local/bin/wlan-diagnose.sh
              systemd-timer for this diagnosis script:
              sudo nano /etc/systemd/system/wlan-diagnose.timer
              content:
              [Unit]
              Description=WLAN Diagnose alle 5 Minuten
              [Timer]
              OnBootSec=1min
              OnUnitActiveSec=5min
              Persistent=true
              [Install]
              WantedBy=timers.target
              service file:
              sudo nano /etc/systemd/system/wlan-diagnose.service
              content:
              [Unit]
              Description=WLAN Diagnose Service
              [Service]
              Type=oneshot
              ExecStart=/usr/local/bin/wlan-diagnose.sh
              activate the service:
              sudo systemctl daemon-reload
              sudo systemctl enable --now wlan-diagnose.timer
              Created logfile: /var/log/wlan-diagnose.log
              possible command for filtering for errors:
              grep -i "fail\|error\|disconnect" /var/log/wlan-diagnose.log
              in my personal case directly after starting the service the undervoltage warnings appeared in the logfile:
              Sep 24 19:23:02 MagicMirrorPi5 wpa_supplicant[702]: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:bc:0e:51:50:48 completed [id=0 id_str=] Sep 24 19:23:02 MagicMirrorPi5 wpa_supplicant[702]: bgscan simple: Failed to enable signal strength monitoring --- dmesg wlan0 --- [ 385.672898] hwmon hwmon4: Voltage normalised [ 399.780700] hwmon hwmon4: Undervoltage detected! [ 401.796721] hwmon hwmon4: Voltage normalised [ 403.812728] hwmon hwmon4: Undervoltage detected! [ 405.831888] hwmon hwmon4: Voltage normalised [ 425.988994] hwmon hwmon4: Undervoltage detected! [ 428.008109] hwmon hwmon4: Voltage normalised [ 434.052979] hwmon hwmon4: Undervoltage detected! [ 438.087587] hwmon hwmon4: Voltage normalised [ 442.117090] hwmon hwmon4: Undervoltage detected! [ 444.133104] hwmon hwmon4: Voltage normalised [ 452.198182] hwmon hwmon4: Undervoltage detected! [ 454.213171] hwmon hwmon4: Voltage normalised [ 470.341318] hwmon hwmon4: Undervoltage detected! [ 478.405369] hwmon hwmon4: Voltage normalised [ 488.485467] hwmon hwmon4: Undervoltage detected! [ 490.505469] hwmon hwmon4: Voltage normalised [ 514.693689] hwmon hwmon4: Undervoltage detected! [ 516.709733] hwmon hwmon4: Voltage normalised [ 520.744884] hwmon hwmon4: Undervoltage detected! PING 8.8.8.8 (8.8.8.8) from 172.23.56.157 wlan0: 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=116 time=13.2 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=33.6 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=27.5 ms --- 8.8.8.8 ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2003ms rtt min/avg/max/mdev = 13.220/24.756/33.576/8.529 ms
              So I had identified my root cause with first strike.
              In the meantime (today) I had severe additional problems (also “identified” by this mentioned log) - but this was a kernel/device driver problem which I cannot solve today.
              But this leads to a modified recovery script because the version from yesterday only tried to restart the WPA_Supplicant which was not sufficient for my problem today.
              [EDIT - Sep, 8th, 2025: deleted old recovery script because usage of ping without qualified path produced an error by the script itself. For this reason the script is not as useful as I thought. Sorry for confusion! ]
              Hope this helps you.
              Do not hesitate to ask for further information …
              Warmest regards,
              Ralf
                rkorell Module Developer @rkorell
                addition:
                the recovery script is: /usr/local/bin/wlan-recovery.sh
                set executable:
                sudo chmod +x /usr/local/bin/wlan-recovery.sh
                Systemd-Service
                sudo nano /etc/systemd/system/wlan-recovery.service
                content:
                [Unit]
                Description=WLAN Recovery Script
                After=network.target
                [Service]
                Type=oneshot
                ExecStart=/usr/local/bin/wlan-recovery.sh
                timer:
                sudo nano /etc/systemd/system/wlan-recovery.timer
                content:
                [Unit]
                Description=Run WLAN Recovery every 5 minutes
                [Timer]
                OnBootSec=1min
                Persistent=true
                [Install]
                activate this service:
                sudo systemctl enable --now wlan-recovery.timer
                logfile: /var/log/wlan-recovery.log
                  schlomm @rkorell
                  @rkorell Thanks for all these detailed Information! I’ll setup your scripts on my MagicMirror Instances - I have 6 different ones to manage and at least one has some weird problems - maybe also relating to power issues.
                  Thanks und Vielen Dank :)
                  R 2 Replies Last reply Reply Quote 1
                    @schlomm Sehr gern und VIEL ERFOLG!
                    • melde Dich, wenn Du noch was benötigst.
                      Ralf
                      Dear @schlomm , team,
                      as I learned today sometimes system limitations are hard and leads to unwanted results.
                      I even got more serioous trouble with my pi and his WIFI so I had to dig in deeper.
                      The aproach until now - because of “growing” up - is a “recovery” and a “diagnose” part.
                      This leads to - surprise, surprise :-) - inconsistent data and so dignosis is merely impossible.
                      For this reason I converged both approches into one script and implemented a 4-stages error-handling and consecutive escalation (until reboot).
                      At this stage i had to recognize: almost EVERY test results immediatly in an error at stage 1 (ping) and was resolved at stage 2 (L2/L3 - ICMP problem – checking status of wlan interface).
                      To identify root cause for this I - again - dig down deeply (ChatGPT was NOT that helpful!) and found: At systemd level (on my system!?) ping is not in PATH !!!
                      So a fully qualified call solved this problem - and most of my “problems” are solved !
                      If you are using “ping”, too and stuck in problems in scripts - keep this in mind: “usr/bin/ping” might be really helpful for you.
                      If you are interested in, here my current recovery-script - including some useful logging information:
                      #!/bin/bash
                      # WLAN Recovery Script (Monolithische Version)
                      # Autor: Dr.  Ralf Korell, MD
                      # Datum: 2025-10-07
                      # Dieses Script wird per systemd-Timer regelmäßig aufgerufen.
                      # Es prüft die WLAN-Verbindung in mehreren Stufen und führt nur dann
                      # Recovery-Aktionen aus, wenn wirklich eine Unterbrechung vorliegt.
                      # Features:
                      #   - Mehrstufige Diagnose (Ping, iw, IP, Route)
                      #   - Schutz vor Fehlalarmen und Selbstabschüssen
                      #   - SSH/VNC-Safe-Mode (keine Unterbrechung aktiver Sessions)
                      #   - Logrotation + Statistikdatei
                      # === Konfiguration ==========================================================
                      LOGFILE="/var/log/wlan-recovery.log"
                      STATSFILE="/var/log/wlan-recovery.stats"
                      MAX_LOG_SIZE=50000              # ~50 KB, dann Logrotation
                      PING_TARGET="172.23.56.1"
                      MAX_CONSECUTIVE_FAILS=2         # bevor Recovery startet
                      COOLDOWN_FILE="/tmp/wlan-recovery.cooldown"
                      COOLDOWN_MINUTES=5
                      # interne Speicherorte (nicht verändern)
                      STATEFILE="/tmp/wlan-recovery.state"
                      DATE_NOW=$(date "+%Y-%m-%d %H:%M:%S")
                      # === Hilfsfunktionen ========================================================
                      log() {
                          echo "$DATE_NOW: $1" | tee -a "$LOGFILE"
                      rotate_log() {
                          if [ -f "$LOGFILE" ] && [ $(wc -c <"$LOGFILE") -gt $MAX_LOG_SIZE ]; then
                              mv "$LOGFILE" "$LOGFILE.old"
                              echo "$DATE_NOW: Log rotated." > "$LOGFILE"
                          fi
                      increment_stat() {
                          local key="$1"
                          local value
                          value=$(grep "^$key=" "$STATSFILE" 2>/dev/null | cut -d= -f2)
                          value=$((value + 1))
                          grep -v "^$key=" "$STATSFILE" 2>/dev/null > "${STATSFILE}.tmp"
                          echo "$key=$value" >> "${STATSFILE}.tmp"
                          mv "${STATSFILE}.tmp" "$STATSFILE"
                      cooldown_active() {
                          if [ -f "$COOLDOWN_FILE" ]; then
                              local last=$(date -r "$COOLDOWN_FILE" +%s)
                              local now=$(date +%s)
                              local diff=$(( (now - last) / 60 ))
                              [ $diff -lt $COOLDOWN_MINUTES ]
                          else
                              return 1
                          fi
                      start_cooldown() {
                          touch "$COOLDOWN_FILE"
                      ssh_or_vnc_active() {
                          ss -tn state established | grep -Eq '(:22|:5900)'
                      # === Diagnosefunktionen =====================================================
                      is_connected_l2() {
                          iw dev wlan0 link 2>/dev/null | grep -q "Connected to"
                      has_ip_l3() {
                          ip -4 addr show wlan0 2>/dev/null | grep -q "inet "
                      has_route() {
                          ip route get "$PING_TARGET" 2>/dev/null | grep -q "dev wlan0"
                      ping_ok() {
                          /usr/bin/ping -I wlan0 -c 3 -W 2 "$PING_TARGET" >/dev/null 2>&1
                      # === Hauptlogik =============================================================
                      rotate_log
                      # Init Statsfile falls nicht vorhanden
                      [ -f "$STATSFILE" ] || echo -e "success=0\nrecoveries=0\nfailures=0" > "$STATSFILE"
                      # Lese bisherigen Fehlerzähler
                      fails=0
                      [ -f "$STATEFILE" ] && fails=$(cat "$STATEFILE")
                      # Diagnose
                      if ping_ok; then
                          log "Ping erfolgreich. WLAN funktioniert."
                          echo 0 > "$STATEFILE"
                          increment_stat "success"
                          exit 0
                      fi
                      # Wenn Ping fehlschlägt → weitere Prüfungen
                      log "Ping fehlgeschlagen → erweiterte Diagnose..."
                      if is_connected_l2 && has_ip_l3 && has_route; then
                          log "L2/L3 ok → ICMP-Problem (kein Recovery)."
                          increment_stat "failures"
                          exit 0
                      fi
                      # Hier gilt: echte Verbindung gestört
                      fails=$((fails + 1))
                      echo "$fails" > "$STATEFILE"
                      if [ $fails -lt $MAX_CONSECUTIVE_FAILS ]; then
                          log "Erster Fehler ($fails/$MAX_CONSECUTIVE_FAILS) → Beobachten..."
                          exit 0
                      fi
                      # Wenn Cooldown läuft → überspringen
                      if cooldown_active; then
                          log "Cooldown aktiv → Recovery übersprungen."
                          exit 0
                      fi
                      # === Recovery-Stufen ========================================================
                      if ssh_or_vnc_active; then
                          log "SSH/VNC aktiv → keine Recovery ausgeführt, nur geloggt."
                          exit 0
                      fi
                      log "Verbindung tatsächlich gestört → Recovery-Prozess gestartet."
                      increment_stat "recoveries"
                      # Stufe 1: sanfte Reassoziation
                      log "→ Stufe 1: wpa_supplicant Reassoziation..."
                      wpa_cli -i wlan0 reassociate >/dev/null 2>&1
                      sleep 5
                      if ping_ok; then
                          log "Reassoziation erfolgreich."
                          start_cooldown
                          exit 0
                      fi
                      # Stufe 2: Interface Toggle
                      log "→ Stufe 2: Interface Toggle..."
                      ip link set wlan0 down
                      sleep 2
                      ip link set wlan0 up
                      sleep 8
                      if ping_ok; then
                          log "Interface Toggle erfolgreich."
                          start_cooldown
                          exit 0
                      fi
                      # Stufe 3: Treiber-Reload
                      log "→ Stufe 3: Treiber-Reload..."
                      modprobe -r brcmfmac && modprobe brcmfmac
                      sleep 10
                      if ping_ok; then
                          log "Treiber-Reload erfolgreich."
                          start_cooldown
                          exit 0
                      fi
                      # Wenn alles fehlschlägt
                      log "Alle Recovery-Stufen fehlgeschlagen → Fehler bleibt bestehen."
                      start_cooldown
                      exit 1
                      [EDIT: in script above: changed ping count from -c 1 to -c 3 in:
                      /usr/bin/ping -I wlan0 -c 1 -W 2 “$PING_TARGET” >/dev/null 2>&1
                      Warmest regards,
                      Ralf
                        In addition: It’s possible that the old recovery script was part of my problems - due to the above mentioned ping problem.
                        For this reason I’ve edited my earlier post and deleted the content of the script.
                        I’ve added an “edit note” instead.
                        Sorry for confusion and any inconvenience!
                        Regards,
                        Ralf
