    nodejs 22.18.0 ??
    25 Posts 3 Posters 6.8k Views 3 Watching
      sdetweil @Assassins
      @Assassins trixie 32 bit is trouble so far. I’d go back to bookworm
      AssassinsA 1 Reply Last reply
      • AssassinsA
        Assassins @sdetweil
        @sdetweil i had the same problem yesterday with bookworm
          sdetweil @Assassins
          @Assassins did you use my script?
          I tested 32 bit on pi3 the other other day
          • AssassinsA
            Assassins @sdetweil
            @sdetweil but is only install 22.15.0 and not 22.18.0 yesterday on bookworm, and today on trixie
              sdetweil @Assassins
              @Assassins flash sd card with bookworm , boot sd, run script
              • AssassinsA
                Assassins @sdetweil
                bookworm 32bit on a freash install say :
                pi@EmptyImage:~ $ sudo npm install n -g
                sudo: npm: Command not found
                S AssassinsA 2 Replies Last reply
                  sdetweil @Assassins
                  @Assassins yes, node/npm are not installed
                  • AssassinsA
                    Assassins @Assassins
                    You start by referring to another thread.
                    Have you even read what I’m writing in this thread??
                    Read further up, I’m writing that just install 22.15.0 on a fresh install, and you write back, after you wirte “flash sd card with bookworm , boot sd, run script” the another thread say
                      the script, my script will install node/npm at the version we think matches inside electron, if necessary
                      IF there is a problem, separately, outside my script,
                      you can use n or nvm to update/change your node version
                      n requires node and npm to be installed (as they are part of the n install)
                      • AssassinsA
                        But how can i install 22.18.0 on a fresh install without all the script.
                        Why does it have to be so much hassle to install MM today, in the past it was MUCH easier to install.
                        S 3 Replies Last reply
                          sdetweil @Assassins
                          @Assassins which OS? trixie 32 bit is a mess… stay with bookworm
                          my script does the job. from the start (not on trixie)
                          I have tested on pi3 (32) and pi5 (64) and VM (64 bit)
                          trixie changes the way swap space increase is done and requires a reboot to change (dumb)
                          so, it runs REALLLLLLLLLLY slow… in small memory systems… PI-02w
                            sdetweil @Assassins
                            @Assassins you can also install nvm, which is a bash version of node installation
                              sdetweil @Assassins
                              @Assassins well the good news is we are keeping the MagicMirror core dependencies up to date, but that is the bad news too… change brings churn….
                              • TAGinsideT
                                TAGinside @Assassins
                                @Assassins
                                You can try this
                                Before check if you have a version installed yet
                                node -v
                                If yes uninstall it
                                For install node.js 22 MAJOR
                                curl -sL https://deb.nodesource.com/setup_22.x | sudo -E bash -
                                sudo apt install nodejs
                                At least check if you have the good version with node -v
