    nodejs 22.18.0 ??
    25 Posts 3 Posters 6.1k Views 3 Watching
      Also try
      nvm —help
      AssassinsA 1 Reply Last reply Reply Quote 0
      • AssassinsA Offline
        Assassins @sdetweil
        @sdetweil said in nodejs 22.18.0 ??:
        lsb_release -a
        Distributor ID: Raspbian
        Description: Raspbian GNU/Linux 13 (trixie)
        Release: 13
        Codename: trixie
          Assassins @sdetweil
          @sdetweil is a new fresh install i dont can install 22.18.0, so i can not install MM 2.33.0
            sdetweil @Assassins
            @Assassins trixie 32 bit is trouble so far. I’d go back to bookworm
              Assassins @sdetweil
              @sdetweil i had the same problem yesterday with bookworm
                sdetweil @Assassins
                @Assassins did you use my script?
                I tested 32 bit on pi3 the other other day
                  Assassins @sdetweil
                  @sdetweil but is only install 22.15.0 and not 22.18.0 yesterday on bookworm, and today on trixie
                    sdetweil @Assassins
                    @Assassins flash sd card with bookworm , boot sd, run script
                      Assassins @sdetweil
                      bookworm 32bit on a freash install say :
                      pi@EmptyImage:~ $ sudo npm install n -g
                      sudo: npm: Command not found
                      S AssassinsA 2 Replies Last reply Reply Quote 0
                        sdetweil @Assassins
                        @Assassins yes, node/npm are not installed
                          Assassins @Assassins
                          You start by referring to another thread.
                          Have you even read what I’m writing in this thread??
                          Read further up, I’m writing that just install 22.15.0 on a fresh install, and you write back, after you wirte “flash sd card with bookworm , boot sd, run script” the another thread say
                            the script, my script will install node/npm at the version we think matches inside electron, if necessary
                            IF there is a problem, separately, outside my script,
                            you can use n or nvm to update/change your node version
                            n requires node and npm to be installed (as they are part of the n install)
                              But how can i install 22.18.0 on a fresh install without all the script.
                              Why does it have to be so much hassle to install MM today, in the past it was MUCH easier to install.
                              S 3 Replies Last reply Reply Quote 1
                                sdetweil @Assassins
                                @Assassins which OS? trixie 32 bit is a mess… stay with bookworm
                                my script does the job. from the start (not on trixie)
                                I have tested on pi3 (32) and pi5 (64) and VM (64 bit)
                                trixie changes the way swap space increase is done and requires a reboot to change (dumb)
                                so, it runs REALLLLLLLLLLY slow… in small memory systems… PI-02w
                                  sdetweil @Assassins
                                  @Assassins you can also install nvm, which is a bash version of node installation
                                    sdetweil @Assassins
                                    @Assassins well the good news is we are keeping the MagicMirror core dependencies up to date, but that is the bad news too… change brings churn….
                                    • TAGinsideT Offline
                                      TAGinside @Assassins
                                      @Assassins
                                      You can try this
                                      Before check if you have a version installed yet
                                      node -v
                                      If yes uninstall it
                                      For install node.js 22 MAJOR
                                      curl -sL https://deb.nodesource.com/setup_22.x | sudo -E bash -
                                      sudo apt install nodejs
                                      At least check if you have the good version with node -v
