Disable header in MMM-MieleAtHome and MMM-Homeconnect
Is there any chance to scale both styles that the icons are looking the same height and style?
@OberfragGER you are looking at the header part of the page Dom
You need the body part where the html is
Use the elements tab , click the pointer to left, mouse ver the module til it’s highlighted and click to
Open the html view there -
this should work, but MMM-MieleAtHome and therefore MMM-Homeconnect as a fork do override the header…
{ module: “MMM-MieleAtHome”, header: "", position: “bottom_left”, }, -
@HeikoGr said in Disable header in MMM-MieleAtHome and MMM-Homeconnect:
{ module: “MMM-MieleAtHome”, header: "", position: “bottom_left”, },Thata not working on both modules :(
i found 2-3 ways for you to get rid of the header:
1.: you add “!important” to force the css rule
.MMM-MieleAtHome .module-header { display: none !important; }- fork MMM-MieleAtHome and get rid of
// you have to delete this function at MMM-MietAtHome.js line 92-95 getHeader: function() { return "Miele@Home"; },MMM-HomeConnect is similar. But here you have a third option: take my fork: https://github.com/heikogr/MMM-HomeConnect2 (only thing: it has an different styling)
@HeikoGr shouldn’t need the !important as no other class is specified AFTER the , module-header
@OberfragGER the second… and you can do it a couple ways
// using classes
.MMM-MieleAtHome .module-header { display:none; }or using html element
.MMM-MieleAtHome header { display:none; } -
@HeikoGr Thanks a lot!
your tip with !important was working.I´ll take a look into yout module too. Especially the Headless Device Flow is very interesting!
@sdetweil Sorry. Both ways did´nt work. Only the “display: none !important;” did the trick.
Thank you for you support…as always! -
S sdetweil has marked this topic as solved on
