    Disable header in MMM-MieleAtHome and MMM-Homeconnect
    14 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @OberfragGER
      @OberfragGER said in Disable header in MMM-MieleAtHome and MMM-Homeconnect:
      MMM-Homeconnect
      can you show the config of both modules, xxx out any personal info
        this
        .MMM-MieleAtHome .module-header {
          display: none;
        should have worked for that module
        have you opened the developer window elements tab to look at the css applied?
        see the second link in my signature below
        O 1 Reply Last reply
        • O
          OberfragGER @sdetweil
          @sdetweil Thanks for your help.
          But its still not working.
          module: “MMM-MieleAtHome”,
          position: “bottom_left”,
          showDeviceIfDoorIsOpen: false,
          showHeader: false,
          userName: “xxx”,
          password: “xxx”,
          client_ID: “xxx”,
          client_Secret: “xxx”,
          vg: ‘de-DE’, // Your country code from the list above
          language: ‘de’, // Language supported from list above
          showAlwaysAllDevices: false //always display component
          I even tried display: none without ";". I doesnt work...
          O S 2 Replies Last reply
          • O
            OberfragGER @OberfragGER
            Is there any chance to scale both styles that the icons are looking the same height and style?
              @OberfragGER you are looking at the header part of the page Dom
              You need the body part where the html is
              Use the elements tab , click the pointer to left, mouse ver the module til it’s highlighted and click to
              Open the html view there
              • H
                HeikoGr
                this should work, but MMM-MieleAtHome and therefore MMM-Homeconnect as a fork do override the header…
                  header: "",
                • O
                  OberfragGER @HeikoGr
                  @HeikoGr said in Disable header in MMM-MieleAtHome and MMM-Homeconnect:
                    header: "",
                  Thata not working on both modules :(
                  • O
                    @sdetweil Hi sam,
                    this one?
                    or this one?
                    • H
                      HeikoGr
                      i found 2-3 ways for you to get rid of the header:
                      1.: you add “!important” to force the css rule
                          display: none !important;
                      1. fork MMM-MieleAtHome and get rid of
                      	// you have to delete this function at MMM-MietAtHome.js line 92-95
                      	getHeader: function() {
                      		return "Miele@Home";
                      MMM-HomeConnect is similar. But here you have a third option: take my fork: https://github.com/heikogr/MMM-HomeConnect2 (only thing: it has an different styling)
                      S O 2 Replies Last reply
                        sdetweil @HeikoGr
                        @HeikoGr shouldn’t need the !important as no other class is specified AFTER the , module-header
                          @OberfragGER the second… and you can do it a couple ways
                          // using classes
                               display:none;
                          or using html element
                          .MMM-MieleAtHome header {
                             display:none;
                          • O
                            @HeikoGr Thanks a lot!
                            your tip with !important was working.
                            I´ll take a look into yout module too. Especially the Headless Device Flow is very interesting!
                            • O
                              @sdetweil Sorry. Both ways did´nt work. Only the “display: none !important;” did the trick.
                              Thank you for you support…as always!
