    Disable header in MMM-MieleAtHome and MMM-Homeconnect
    14 Posts 3 Posters 2.2k Views 3 Watching
    • O Offline
      OberfragGER
      i just want to disable the headers of both Modules. MMM-Homeconnect is somehow copied from MMM-Mieleathome
      I treid diffent things. But nothing worked:
      showHeader: false,
      or in custom css
      .MMM-MieleAtHome .module-header {
        display: none;
      or
      .MMM-MieleAtHome header {
        text-align: left
        text-align: left
      Did u have an idea?
      • O Offline
        OberfragGER @sdetweil
        @sdetweil Sorry. Both ways did´nt work. Only the “display: none !important;” did the trick.
        Thank you for you support…as always!
          sdetweil @OberfragGER
          @OberfragGER said in Disable header in MMM-MieleAtHome and MMM-Homeconnect:
          MMM-Homeconnect
          can you show the config of both modules, xxx out any personal info
            this
              display: none;
            should have worked for that module
            have you opened the developer window elements tab to look at the css applied?
            see the second link in my signature below
            • O Offline
              @sdetweil Thanks for your help.
              But its still not working.
              module: “MMM-MieleAtHome”,
              position: “bottom_left”,
              showDeviceIfDoorIsOpen: false,
              showHeader: false,
              userName: “xxx”,
              password: “xxx”,
              client_ID: “xxx”,
              client_Secret: “xxx”,
              vg: ‘de-DE’, // Your country code from the list above
              language: ‘de’, // Language supported from list above
              showAlwaysAllDevices: false //always display component
              I even tried display: none without ";". I doesnt work...
              O S 2 Replies Last reply Reply Quote 0
              • O Offline
                OberfragGER @OberfragGER
                Is there any chance to scale both styles that the icons are looking the same height and style?
                  @OberfragGER you are looking at the header part of the page Dom
                  You need the body part where the html is
                  Use the elements tab , click the pointer to left, mouse ver the module til it’s highlighted and click to
                  Open the html view there
                  • H Offline
                    HeikoGr
                    this should work, but MMM-MieleAtHome and therefore MMM-Homeconnect as a fork do override the header…
                      header: "",
                    • O Offline
                      OberfragGER @HeikoGr
                      @HeikoGr said in Disable header in MMM-MieleAtHome and MMM-Homeconnect:
                        header: "",
                      Thata not working on both modules :(
                      • O Offline
                        @sdetweil Hi sam,
                        this one?
                        or this one?
                        • H Offline
                          HeikoGr
                          i found 2-3 ways for you to get rid of the header:
                          1.: you add “!important” to force the css rule
                          1. fork MMM-MieleAtHome and get rid of
                          	// you have to delete this function at MMM-MietAtHome.js line 92-95
                          	getHeader: function() {
                          		return "Miele@Home";
                          MMM-HomeConnect is similar. But here you have a third option: take my fork: https://github.com/heikogr/MMM-HomeConnect2 (only thing: it has an different styling)
                          S O 2 Replies Last reply Reply Quote 1
                            sdetweil @HeikoGr
                            @HeikoGr shouldn’t need the !important as no other class is specified AFTER the , module-header
                              @OberfragGER the second… and you can do it a couple ways
                              // using classes
                                   display:none;
                              or using html element
                                 display:none;
                              • O Offline
                                @HeikoGr Thanks a lot!
                                your tip with !important was working.
                                I´ll take a look into yout module too. Especially the Headless Device Flow is very interesting!
                                • O Offline
