    Added MMM-ModuleUpdateNotifier and MMM-AptUpdateNotifier
    10 Posts 2 Posters 1.0k Views 2 Watching
      sdetweil @CrashTest
      @CrashTest you assume the developers are active and interested in doing dependency updates for no particular reason . ( many w breaking changes)
      Most developers are not active on the forums.
      Anyhow I don’t think the module one is particularly helpful for users. As it sets off a fire alarm with no resolution.
      In my humble opinion
        CrashTest @sdetweil
        Never said it was useful (except to myself :)).
        But to be clear, MMM-ModuleUpdateNotifier will inform the user if a module they are using has an update (and therefore the developer is active). So it does notify the user of an actionable thing.
        Either way, the two modules are out there in the wild now. If people have suggestions, they can interact with the projects on github or ignore them if not useful for them.
        For me, it was an interesting opportunity to do some AI-assisted coding in a language that I have not used before and to get back into Linux a little.
        Cheers
          sdetweil @CrashTest
          @CrashTest Our updatenotification module does that for the active modules… same as for MM base
          I wasn’t talking about that one
          I’m the moderator here, so just watching out for our users…
          C 2 Replies Last reply Reply Quote 0
            CrashTest @sdetweil
            Sounds good. Totally new to this world of MM. My efforts on these modules started when I saw someone post in the “Show Your Mirror” folder that they created a custom module to check for apt updates, but they did not include the module. So I figured I would create one.
            Cheers
              CrashTest @sdetweil
              I did not know that about the default updatenotification module. Good to know.
              I have that module in my config.js with no config options, so I am running the default options. And I have not seen it put up a notification if there was a newer commit on one of the modules (which was the case). In my case that one module that had a newer commit was in my modules directory but not used in config.js, so looking at useModulesFromConfig option, I assume that module was not looked at. So it all makes sense.
              I did put in a pull request to tweak wording in updatenotification.md
              Cheers
                sdetweil @CrashTest
                @CrashTest awesome effort!
                  sdetweil @CrashTest
                  @CrashTest I saw update for the doc
                  It should automagically put up an update banner for all
                  Modules in config.js if their git GitHub ( source repo) commit status changes
                  It as also outputs messsges where npm start is logged as it scans the repository
