    MMM-Pages module all showing on one page
    26 Posts 3 Posters 3.6k Views 3 Watching
      sdetweil @hahawoooooo
      @hahawoooooo
      MM is a server with a browser auto started (npm start, electron is the browser), and with any browser connecting too
      or
      MM can be a server (npm run server) with any browser connecting from anywhere
      MM is just an app…
      you can configure the system to start an app on boot multiple ways
      you can edit the system startup settings,
      different on window, mac, linx (and diff linux versions)
      OR you can run ANOTHER app, that does all that work for you
      pm2 (node process manager v2)
      it can start many different apps (mm , mmpm, and any other tool you like,
      I have a spotify plugin on another mirror app, it can use the spotify api to play, pause, blah blah
      if I install and start the spotify player daemon… (librespot or raspotify on pi)
      I use pm2 to launch that too , and I can play on this machine.
      the cool thing about pm2 is YOU don’t need to know HOW the system autostart works,
      pm2 handles all that for you…
      • H Offline
        hahawoooooo @sdetweil
        @sdetweil Thanks for the explainer! That really helps to clarify things a bit.
        I am using pm2 to start, and it is running with the electron browser, with the MM running directly on the Raspberry Pi. Your explanation made me realize I can open the magic mirror from any browser in the house while I’m troubleshooting, which is really helpful!
        I still haven’t figured out why the page timing rotation doesn’t work at all. Even if I set modules on different pages (page 0 and page 1, for instance), they all load in when I start up the MM. It’s like the pages aren’t loaded in, so they’re nothing to switch between.
        Here are the logs on firefox from a separate computer while the server is running on the Pi:
        [CX3] Module is not prepared yet, wait a while. MMM-CalendarExt3.js:396:11
        [CX3A] Module is not prepared yet, wait a while. MMM-CalendarExt3Agenda.js:186:11
        Uncaught (in promise) TypeError: searchClass.toLowerCase is not a function
            newModules http://192.168.1.180:8080/js/main.js:526
            modulesByClass http://192.168.1.180:8080/js/main.js:522
            exceptWithClass http://192.168.1.180:8080/js/main.js:507
            animatePageChange http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:220
            notificationReceived http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:117
            sendNotification http://192.168.1.180:8080/js/main.js:101
            createDomObjects http://192.168.1.180:8080/js/main.js:70
        main.js:526:38
        module tries to update the DOM without being displayed. main.js:678:9
        module tries to update the DOM without being displayed. 2 main.js:678:9
        module tries to update the DOM without being displayed. 5 main.js:678:9
        module tries to update the DOM without being displayed. 3 main.js:678:9
          @hahawoooooo
          Please use code block around logs, code or config
          Can you post your pages config
          • H Offline
            @sdetweil Sure thing!
            {  //MMM-Pages
                    module: "MMM-pages",					// flip between pages - goal was to set full page calendar on one page, rest on other
            			timings: {
            				default: 5000			// rotate every 5 seconds
                                            ['weather',                          // page 0
            				'MMM-CalendarExt3',
            				'MMM-CalendarExt3Agenda',
            				'MMM-Chores',
            				'MMM-Dad-Jokes'
                           ['MMM-TitanSchoolMealMenu'],        // page 1
            			fixed: [
            					['MMM-page-indicator',						// what to show on every page
            					'MMM-SmartTouch',
            					'clock',
            					'MMM-MagicMover',
            					'MMM-Wallpaper']
            			hiddenPages:{					// modules to not show, or to hide in specific pages
            				"hidden": [
            					'calendar',
            					'updatenotification',
            					'MMM-Remote-Control'
            • H Offline
              hahawoooooo @hahawoooooo
              Okay, I may have discovered the reason of the pages not rotating, the “searchClass.toLowerCase” not being found, and possibly a of other small strangeness I was seeing.
              I was running the latest version of magic mirror without realizing you have to do a fresh wipe and re-install for major Raspberry Pi OS updates. I had put aside this project for about a year or so, and picked it back up in October without updating to Trixie.
              I’m working through the OS update and restoring everything from the restore scripts to see how it runs. Fingers crossed!
                @hahawoooooo you do NOT Have to do a wipe and install again…
                generally that error message means it was trying to do a string operation (toLowerCase), but the thing was not a string (usually null )
                • H Offline
                  @sdetweil said in MMM-Pages module all showing on one page:
                  That makes sense. Updating the OS fixed a few other issues, but the MMM-pages issue is still happening with the same “toLowerCase” error. I’m removing modules I’m not using and spellchecking everything to see if there’s a spelling or formatting error I’m missing in the config file in case that’s the reason for className calls to bork up somewhere.
                    @hahawoooooo I also recommend using the classes approach to config
                         modules:[
                                  [ "page1"],
                                  [ "page2"],
                                 "fixed": ["fixed"]
                          . Etc
                    Then for the modules you want on page1
                    Add
                          classes:"page1",
                    In the config below module: line
                    This was so much easier for me
                    • H Offline
                      I feel incredibly foolish - I attempted to use classes before and I couldn’t get it to work. It ends up that I had it coded as:
                      class:'page1',
                      instead of:
                      classes:'page1'
                      I swear I stared at this config file forever without seeing it!!! Thanks so much for the being patient, and I got everything working now.
                      • H hahawoooooo has marked this topic as solved on
                        @hahawoooooo it’s amazing what our minds see, even when it’s wrong!
                        Glad you found it!!
