    MMM-Pages module all showing on one page
    26 Posts 3 Posters 4.0k Views 3 Watching
    • plainbrokeP Offline
      plainbroke @sdetweil
      I think I found my answer, I was on version 1.0.0 of MMM-pages.
      We will see what happens with Version 1.3.0 in the morning.
      I did the git pull.
      • H Offline
        hahawoooooo @sdetweil
        @sdetweil Good catch on that one - there are two MMM-Pages listed in the third party module website, and I was using your fork which is at 1.0.0. I uninstalled that version and installed the 1.3.0 version, but still having the same issue with all modules on one page.
        I need to get a bit more sleep and look again just to make sure I did everything correctly after the changes.
        One thing I noticed is I’m getting socket.io connection errors in the logs. where it repeatedly tries connecting and then fails. I can grab the log texts when I get back home tonight if that’s anywhere related to the problem.
        S H 2 Replies Last reply Reply Quote 0
          sdetweil @hahawoooooo
          @hahawoooooo I think this is a totally different problem…
          are you using node 22.18.0 on the system?
          node inside this electron version is 22.18
          are you using a browser or is this the electron page started by npm start?
          • H Offline
            hahawoooooo @hahawoooooo
            Node version is 22.18.0, and I’m using pm2 to start it. I changed the mm.sh file to open it via firefox.
              @hahawoooooo so you are doing npm run server and then launching firefox…
              or is this my runstart.sh and u set the env variable for firefox as the browser over server
              • H Offline
                @sdetweil To be honest, I need to get a bit smarter about the difference between the different start options (npm, pm2, mmpm, running over server). I’m currently just running pm2 start locally and not running a server.
                  @hahawoooooo
                  MM is a server with a browser auto started (npm start, electron is the browser), and with any browser connecting too
                  or
                  MM can be a server (npm run server) with any browser connecting from anywhere
                  MM is just an app…
                  you can configure the system to start an app on boot multiple ways
                  you can edit the system startup settings,
                  different on window, mac, linx (and diff linux versions)
                  OR you can run ANOTHER app, that does all that work for you
                  pm2 (node process manager v2)
                  it can start many different apps (mm , mmpm, and any other tool you like,
                  I have a spotify plugin on another mirror app, it can use the spotify api to play, pause, blah blah
                  if I install and start the spotify player daemon… (librespot or raspotify on pi)
                  I use pm2 to launch that too , and I can play on this machine.
                  the cool thing about pm2 is YOU don’t need to know HOW the system autostart works,
                  pm2 handles all that for you…
                  • H Offline
                    @sdetweil Thanks for the explainer! That really helps to clarify things a bit.
                    I am using pm2 to start, and it is running with the electron browser, with the MM running directly on the Raspberry Pi. Your explanation made me realize I can open the magic mirror from any browser in the house while I’m troubleshooting, which is really helpful!
                    I still haven’t figured out why the page timing rotation doesn’t work at all. Even if I set modules on different pages (page 0 and page 1, for instance), they all load in when I start up the MM. It’s like the pages aren’t loaded in, so they’re nothing to switch between.
                    Here are the logs on firefox from a separate computer while the server is running on the Pi:
                    [CX3] Module is not prepared yet, wait a while. MMM-CalendarExt3.js:396:11
                    [CX3A] Module is not prepared yet, wait a while. MMM-CalendarExt3Agenda.js:186:11
                    Uncaught (in promise) TypeError: searchClass.toLowerCase is not a function
                        newModules http://192.168.1.180:8080/js/main.js:526
                        modulesByClass http://192.168.1.180:8080/js/main.js:522
                        exceptWithClass http://192.168.1.180:8080/js/main.js:507
                        animatePageChange http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:220
                        notificationReceived http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:117
                        sendNotification http://192.168.1.180:8080/js/main.js:101
                        createDomObjects http://192.168.1.180:8080/js/main.js:70
                    main.js:526:38
                    module tries to update the DOM without being displayed. main.js:678:9
                    module tries to update the DOM without being displayed. 2 main.js:678:9
                    module tries to update the DOM without being displayed. 5 main.js:678:9
                    module tries to update the DOM without being displayed. 3 main.js:678:9
                      @hahawoooooo
                      Please use code block around logs, code or config
                      Can you post your pages config
                      • H Offline
                        @sdetweil Sure thing!
                        {  //MMM-Pages
                                module: "MMM-pages",					// flip between pages - goal was to set full page calendar on one page, rest on other
                        			timings: {
                        				default: 5000			// rotate every 5 seconds
                                                        ['weather',                          // page 0
                        				'MMM-CalendarExt3',
                        				'MMM-CalendarExt3Agenda',
                        				'MMM-Chores',
                        				'MMM-Dad-Jokes'
                                       ['MMM-TitanSchoolMealMenu'],        // page 1
                        			fixed: [
                        					['MMM-page-indicator',						// what to show on every page
                        					'MMM-SmartTouch',
                        					'clock',
                        					'MMM-MagicMover',
                        					'MMM-Wallpaper']
                        			hiddenPages:{					// modules to not show, or to hide in specific pages
                        				"hidden": [
                        					'calendar',
                        					'updatenotification',
                        					'MMM-Remote-Control'
                        • H Offline
                          Okay, I may have discovered the reason of the pages not rotating, the “searchClass.toLowerCase” not being found, and possibly a of other small strangeness I was seeing.
                          I was running the latest version of magic mirror without realizing you have to do a fresh wipe and re-install for major Raspberry Pi OS updates. I had put aside this project for about a year or so, and picked it back up in October without updating to Trixie.
                          I’m working through the OS update and restoring everything from the restore scripts to see how it runs. Fingers crossed!
                            @hahawoooooo you do NOT Have to do a wipe and install again…
                            generally that error message means it was trying to do a string operation (toLowerCase), but the thing was not a string (usually null )
                            • H Offline
                              @sdetweil said in MMM-Pages module all showing on one page:
                              That makes sense. Updating the OS fixed a few other issues, but the MMM-pages issue is still happening with the same “toLowerCase” error. I’m removing modules I’m not using and spellchecking everything to see if there’s a spelling or formatting error I’m missing in the config file in case that’s the reason for className calls to bork up somewhere.
                                @hahawoooooo I also recommend using the classes approach to config
                                     modules:[
                                              [ "page1"],
                                              [ "page2"],
                                             "fixed": ["fixed"]
                                      . Etc
                                Then for the modules you want on page1
                                Add
                                      classes:"page1",
                                In the config below module: line
                                This was so much easier for me
                                • H Offline
                                  I feel incredibly foolish - I attempted to use classes before and I couldn’t get it to work. It ends up that I had it coded as:
                                  class:'page1',
                                  instead of:
                                  classes:'page1'
                                  I swear I stared at this config file forever without seeing it!!! Thanks so much for the being patient, and I got everything working now.
                                  • H hahawoooooo has marked this topic as solved on
                                    @hahawoooooo it’s amazing what our minds see, even when it’s wrong!
                                    Glad you found it!!
