    MMM-Pages module all showing on one page
    26 Posts 3 Posters 4.0k Views 3 Watching
      sdetweil @hahawoooooo
      @hahawoooooo as pages is done all in browser, can you open the developers window, ctrl -shift-I, select the console tab,
      And enter page is the filter field
      plainbrokeP H 2 Replies Last reply Reply Quote 0
      • plainbrokeP Offline
        plainbroke @sdetweil
        Sam,
        MMM-Adventskalendar, causes Your Pages to load all 50 of my modules on one page. I removed it and installed MMM-MyTeams-Adventskalendar and it works fine, now… Could not figure out what was actually causing it. Something about picture not having naming text. Didn’t know that would cause it to freak out.
        • H Offline
          hahawoooooo @sdetweil
          @sdetweil : Thanks for the help! Here’s what I copied from the dev console after filtering for “Page”:
          • Failed to load resource: the 8080/modules/MMM-page-indicator/MMM-page-indicator.js:1 server responded with a status of 404 (Not Found)
          • Refused to execute script from ‘http://localhost:8080/modules/MMM-page-indicator/MMM-page-indicator.js’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.
          • Refused to apply style from ‘http://localhost:8080/modules/MMM-pages/pages.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
            sdetweil @plainbroke
            @plainbroke thx… will look at it
            I added it with example params and it works with pages just fine…
                module: "MMM-Adventskalender",
                classes:"page1",   // on my pages def
                position: "top_center",
                    backgroundImage: "/modules/MMM-Adventskalender/images/background.jpg",
                    doorMargin: 30,
                    moduleWidth: 800,
                    moduleHeight: 600,
                    autopen: true,
                    autoopenat: "10:00",
              @hahawoooooo weird… none of those make sense…
              not found, then not executable
              and css… typically that means not found
              is this on a synology nas, and docker for MM??
              • H Offline
                @sdetweil I was a bit flummoxed myself, honestly. It’s on a raspberry pi, and I’m not using docker.
                  @hahawoooooo can you do
                  cd ~/MagicMirror/modules
                  ls -laF
                  • H Offline
                    @sdetweil Sure thing:
                    total 32
                    drwxr-xr-x 8 dtraindisplay dtraindisplay 4096 Dec 2 21:36 ./
                    drwxr-xr-x 16 dtraindisplay dtraindisplay 4096 Dec 2 21:15 …/
                    drwxr-xr-x 10 dtraindisplay dtraindisplay 4096 Dec 2 21:08 default/
                    drwxr-xr-x 7 dtraindisplay dtraindisplay 4096 Dec 2 21:36 MMM-CalendarExt3/
                    drwxr-xr-x 5 dtraindisplay dtraindisplay 4096 Dec 2 21:37 MMM-LINQConnectCalendar/
                    drwxr-xr-x 4 dtraindisplay dtraindisplay 4096 Dec 2 21:30 MMM-mmpm/
                    drwxr-xr-x 7 dtraindisplay dtraindisplay 4096 Dec 2 21:34 MMM-page-indicator/
                    drwxr-xr-x 5 dtraindisplay dtraindisplay 4096 Dec 2 21:34 MMM-pages/
                    I also tried doing a fresh install using the install script in a new folder, and I’m running into the same issue, but the console logs (ctrl+shift_I) is now showing a different output:
                    loader.js:179 Load script: modules/MMM-pages/MMM-pages.js
                    module.js:489 Module registered: MMM-pages
                    loader.js:152 Bootstrapping module: MMM-pages
                    loader.js:156 Scripts loaded for: MMM-pages
                    loader.js:195 Load stylesheet: modules/MMM-pages/pages.css
                    loader.js:159 Styles loaded for: MMM-pages
                    loader.js:162 Translations loaded for: MMM-pages
                    loader.js:179 Load script: modules/MMM-page-indicator/MMM-page-indicator.js
                    module.js:489 Module registered: MMM-page-indicator
                    loader.js:152 Bootstrapping module: MMM-page-indicator
                    loader.js:156 Scripts loaded for: MMM-page-indicator
                    loader.js:195 Load stylesheet: modules/MMM-page-indicator/page-indicators.css
                    loader.js:159 Styles loaded for: MMM-page-indicator
                    loader.js:162 Translations loaded for: MMM-page-indicator
                    MMM-page-indicator.js:138 [MMM-page-indicator]: MMM-pages detected. Will ignore PAGE_INCREMENT and PAGE_DECREMENT as it is already handled by MMM-pages
                    MMM-pages.js:117 [MMM-pages] received that all objects are created; will now hide things!
                    MMM-pages.js:331 [MMM-pages] resuming rotation
                    MMM-page-indicator.js:106 [MMM-page-indicator]: Changing maximum pages to 2
                    MMM-page-indicator.js:131 [MMM-page-indicator]: Setting page to 0
                    main.js:527 Uncaught (in promise) TypeError: searchClass.toLowerCase is not a function
                    at main.js:527:38
                    at Array.filter ()
                    at modulesByClass (main.js:523:31)
                    at Array.exceptWithClass (main.js:508:11)
                    at Class.animatePageChange (MMM-pages.js:234:8)
                    at Class.notificationReceived (MMM-pages.js:121:14)
                    at sendNotification (main.js:101:12)
                    at main.js:70:4
                    I also
                      @hahawoooooo interesting
                      Can you do
                      cd ~/MagicMirror/modules/MMM-pages
                      grep version package.json
                      Latest is 1.3.0
                      If not 1.3.0
                      git pull
                      The restart MagicMirror
                        I think I found my answer, I was on version 1.0.0 of MMM-pages.
                        We will see what happens with Version 1.3.0 in the morning.
                        I did the git pull.
                        • H Offline
                          @sdetweil Good catch on that one - there are two MMM-Pages listed in the third party module website, and I was using your fork which is at 1.0.0. I uninstalled that version and installed the 1.3.0 version, but still having the same issue with all modules on one page.
                          I need to get a bit more sleep and look again just to make sure I did everything correctly after the changes.
                          One thing I noticed is I’m getting socket.io connection errors in the logs. where it repeatedly tries connecting and then fails. I can grab the log texts when I get back home tonight if that’s anywhere related to the problem.
                          S H 2 Replies Last reply Reply Quote 0
                            @hahawoooooo I think this is a totally different problem…
                            are you using node 22.18.0 on the system?
                            node inside this electron version is 22.18
                            are you using a browser or is this the electron page started by npm start?
                            • H Offline
                              hahawoooooo @hahawoooooo
                              Node version is 22.18.0, and I’m using pm2 to start it. I changed the mm.sh file to open it via firefox.
                                @hahawoooooo so you are doing npm run server and then launching firefox…
                                or is this my runstart.sh and u set the env variable for firefox as the browser over server
                                • H Offline
                                  @sdetweil To be honest, I need to get a bit smarter about the difference between the different start options (npm, pm2, mmpm, running over server). I’m currently just running pm2 start locally and not running a server.
                                    @hahawoooooo
                                    MM is a server with a browser auto started (npm start, electron is the browser), and with any browser connecting too
                                    or
                                    MM can be a server (npm run server) with any browser connecting from anywhere
                                    MM is just an app…
                                    you can configure the system to start an app on boot multiple ways
                                    you can edit the system startup settings,
                                    different on window, mac, linx (and diff linux versions)
                                    OR you can run ANOTHER app, that does all that work for you
                                    pm2 (node process manager v2)
                                    it can start many different apps (mm , mmpm, and any other tool you like,
                                    I have a spotify plugin on another mirror app, it can use the spotify api to play, pause, blah blah
                                    if I install and start the spotify player daemon… (librespot or raspotify on pi)
                                    I use pm2 to launch that too , and I can play on this machine.
                                    the cool thing about pm2 is YOU don’t need to know HOW the system autostart works,
                                    pm2 handles all that for you…
                                    • H Offline
                                      @sdetweil Thanks for the explainer! That really helps to clarify things a bit.
                                      I am using pm2 to start, and it is running with the electron browser, with the MM running directly on the Raspberry Pi. Your explanation made me realize I can open the magic mirror from any browser in the house while I’m troubleshooting, which is really helpful!
                                      I still haven’t figured out why the page timing rotation doesn’t work at all. Even if I set modules on different pages (page 0 and page 1, for instance), they all load in when I start up the MM. It’s like the pages aren’t loaded in, so they’re nothing to switch between.
                                      Here are the logs on firefox from a separate computer while the server is running on the Pi:
                                      [CX3] Module is not prepared yet, wait a while. MMM-CalendarExt3.js:396:11
                                      [CX3A] Module is not prepared yet, wait a while. MMM-CalendarExt3Agenda.js:186:11
                                          newModules http://192.168.1.180:8080/js/main.js:526
                                          modulesByClass http://192.168.1.180:8080/js/main.js:522
                                          exceptWithClass http://192.168.1.180:8080/js/main.js:507
                                          animatePageChange http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:220
                                          notificationReceived http://192.168.1.180:8080/modules/MMM-pages/MMM-pages.js:117
                                          sendNotification http://192.168.1.180:8080/js/main.js:101
                                          createDomObjects http://192.168.1.180:8080/js/main.js:70
                                      main.js:526:38
                                      module tries to update the DOM without being displayed. main.js:678:9
                                      module tries to update the DOM without being displayed. 2 main.js:678:9
                                      module tries to update the DOM without being displayed. 5 main.js:678:9
                                      module tries to update the DOM without being displayed. 3 main.js:678:9
                                        @hahawoooooo
                                        Please use code block around logs, code or config
                                        Can you post your pages config
                                        • H Offline
                                          @sdetweil Sure thing!
                                          {  //MMM-Pages
                                                  module: "MMM-pages",					// flip between pages - goal was to set full page calendar on one page, rest on other
                                          			timings: {
                                          				default: 5000			// rotate every 5 seconds
        ['weather',                          // page 0
                                          				'MMM-CalendarExt3',
                                          				'MMM-CalendarExt3Agenda',
                                          				'MMM-Chores',
                                          				'MMM-Dad-Jokes'
                                                         ['MMM-TitanSchoolMealMenu'],        // page 1
                                          			fixed: [
                                          					['MMM-page-indicator',						// what to show on every page
                                          					'MMM-SmartTouch',
                                          					'clock',
                                          					'MMM-MagicMover',
                                          					'MMM-Wallpaper']
                                          			hiddenPages:{					// modules to not show, or to hide in specific pages
                                          				"hidden": [
                                          					'calendar',
                                          					'updatenotification',
                                          					'MMM-Remote-Control'
                                          • H Offline
                                            Okay, I may have discovered the reason of the pages not rotating, the “searchClass.toLowerCase” not being found, and possibly a of other small strangeness I was seeing.
                                            I was running the latest version of magic mirror without realizing you have to do a fresh wipe and re-install for major Raspberry Pi OS updates. I had put aside this project for about a year or so, and picked it back up in October without updating to Trixie.
                                            I’m working through the OS update and restoring everything from the restore scripts to see how it runs. Fingers crossed!
