    MMM-Swipe: deprecated WARNINGS plus ERROR
    3 Posts 2 Posters 1.9k Views 2 Watching
    • binderthB Offline
      binderth
      Hi there,
      first of all: Do I understand it correctly, that there’s two HC-SR04 sensors neede? one for left and one for right?
      If so (which I imagine), please make the readme in github a bit more clear on this. Took me a few thoughts on how to figure “right” and “left” pins. If you’re not familiar with those sensors, you’re a bit confused… ;)
      after cloning the repo to modules and npm install I get the following warnings:
      pi@MagicMirror:~/MagicMirror/modules/MMM-Swipe $ npm install
      npm WARN deprecated math-statistics@1.2.0: THIS PROJECT IS NO LONGER MAINTAINED by clebert
      npm WARN deprecated typesystem@5.0.0: THIS PROJECT IS NO LONGER MAINTAINED by clebert
      npm WARN deprecated expressive-assertion@1.5.1: THIS PROJECT IS NO LONGER MAINTAINED by clebert
      Don’t know, if that’s the cause for the following errors on startup:
      pi@MagicMirror:~/MagicMirror $ DISPLAY=:0 npm restart &
      [1] 1171
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-Globe.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'mmm-usonic'
      App threw an error during load
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:403:25)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_helper.js:11:16)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions..js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
      { Error: Cannot find module 'mmm-usonic'
          at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
      Launching application.
      it seems, the dependency to mmm-usonic wasn’t solved, I don’t see this module anywhere on my pi…
      Thanks for help!
      Thomas.
      • mochmanM Offline
        mochman Module Developer
        Thomas,
        I haven’t developed it since I first made it so I’m not sure if it still works with all the updates the pi & MM have gotten. Sorry.
        If you want to still try and get it to work, yes you do need 2 sensors to detect movement between them. You also need to run the MagicMirror with sudo to allow permissions to the GPIO pins in MagicMirror.
        binderthB 1 Reply Last reply Reply Quote 2
        • binderthB Offline
          binderth @mochman
          @mochman ok. thanks for the update.
          Does anyone know: Is there some “newer” gesture-module for the MagicMirror?
