    MM does not boot when starting my raspberry
    12 Posts 4 Posters 9.4k Views 4 Watching
      asquelo
      I have installed AUTOSTART
      And I followed the instructions
      but it does not work
      romainR 1 Reply Last reply Reply Quote 0
      • romainR Offline
        romain @asquelo
        @asquelo You probably did it wrong. I did that a lot few weeks ago.
        you need to run pm2 startup as non sudo. then it display a command you have to run. On my pi it’s the following :
        pi@raspberrypi:~ $ pm2 startup
        [PM2] Init System found: systemd
        [PM2] You have to run this command as root. Execute the following command:
        sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
        so you run the command that was display. For me it’s sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
        Then you pm2 start mm.sh , then you wait until it’s open (not sure if it’s necessary to actually wait). Then while it’s open, you run pm2 save. They you can reboot and see your mirror open.
        I used to run sudo pm2 startup and don’t understand why it wasn’t working back in the day even though the autostart guide didn’t ask to do it…
        O 1 Reply Last reply Reply Quote 1
          asquelo
          it works ! many thanks !
          • O Offline
            opensky727 @romain
            @romain I tried that and I have “env: /usr/lib/node_modules/pm2: Permission Denied” Do you know how to have access? Thanks.
            • romainR Offline
              romain @opensky727
              @opensky727 did you put the sudo at the begining of the command ?
              It should loook like this
              You should have the permission as sudo
              • O Offline
                opensky727 @romain
                @romain it worked, thanks a lot.
                  RE_Magic_Mirror
                  This worked for me thank you. There is a delay from when it boots up and MM starts, is there any way to reduce that time so the desktop never shows?
                  • romainR Offline
                    romain @RE_Magic_Mirror
                    @RE_Magic_Mirror Not that I know of but I am not an expert in linux configuration.
                    But if your issue is about “seeing” the desktop, I might have some tricks for you.
                    Maybe you could change you desktop wallpaper to be a black screen for started and take away the trash icon so the desktop part is black and empty.
                    Then you could right click on the panel barr above your screen and enter the panel settings and play around with them to make the barre itself invisible and then take away the unnecessary icons on it.
                    It will not make your mirror start quicker but you won’t see the default wallpaper and menu as much
                      RE_Magic_Mirror @romain
                      @romain that is exactly what i have done up to this point, i think my knowledge of linux configuration “mirrors” your own. I dont plan on this rebooting very often so I am probably worrying about silly stuff as i wait for my mic and pir to come in, then i am going to have real issues lol. Thank you for the reply.
                      • romainR Offline
                        @RE_Magic_Mirror Nice pun ;)
