    Error with MM update
    5 Posts 3 Posters 2.6k Views 3 Watching
      JoeFranz
      I have just tried mm to 2.1.3 to update, I get this error:
      pi@raspberrypi:~/MagicMirror $ git pull && npm install
      error: Your local changes to the following files would be overwritten by merge:
      modules/README.md
      Please, commit your changes or stash them before you can merge.
      Aborting
      can someone help?
      randomnoiseR 1 Reply Last reply Reply Quote 0
      • randomnoiseR Offline
        randomnoise @JoeFranz
        @JoeFranz I had same issue (except for me it was the calendar.js file it didnt like… this was because I had manually edited that file to apply hotfix for 24h times).
        You can run a git reset --hard which will ‘fix’ the readme.md file you must have edited… a word of warning though- this will also reset your custom.css (at least it seemed to for me) so make sure you take a copy 1st.
        • Sandy2503S Offline
          Sandy2503
          i had the same.
          i have renamed the calendar.js to calendar.js.org in the folder modules/default/calendar and the update works very well …
          Sandy
            JoeFranz
            now I get at the end of this error message
            npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
            if I run mm now then I have only a black screen :-(
              JoeFranz
              I had probably killed something, now everything is running again.
              There is probably a problem with the calendar since the update. But I’m probably not alone …
              Thanks for the quick help!
