Can't make MMM-Paris-RATP-PG work
13 Posts 5 Posters 6.7k Views 5 Watching
    AFCM
    Let me first say I’m not an programmer or a developper so my question might be easy to answer
    I started to build my magic mirror, modules work fine but I have some trouble to make MMM-Paris-RATP-PG work properly.
    I don’t know what I should put in the config part {
    I tested this and that from what I can find in the readme but nothing seems to work, I can’t even have something displayed on my monitor.
    I also tested MMM-LocalTransport but it doesn’t fit my needs, want to make it work so my son can use it before he goes to school, stuff like that
    I don’t need a very complex config, just to be able to see, like in the screenshot (https://github.com/da4throux/MMM-Paris-RATP-PG) one line with the bus number, next passage etc and then I will fill the module myself
    Thank you very much,
    D 1 Reply Last reply Oct 21, 2017, 2:07 PM Reply Quote 0
      da4throux @AFCM
      Hi @AFCM , so did you try something from the suggestions of the github readme file,
      like just with one bus for example:
      config:{
      busStations: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’}
      Would it be working on your setup ?
      A 1 Reply Last reply Oct 23, 2017, 5:45 PM Reply Quote 0
        AFCM @da4throux
        @da4throux Thank you, so I tried your config, I can only see the header nothing else. And the header shows “Connections, update request x S ago”
        This is what I have in my config.js :
        module: ‘MMM-Paris-RATP-PG’,
        position: ‘top_center’,
        header: ‘Connections’,
        config: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’
        I can use the module as a standalone right ? I don’t need anything else ?
        D 1 Reply Last reply Oct 26, 2017, 9:08 PM Reply Quote 0
          da4throux @AFCM
          @AFCM
          It sounds like a connectivity issue.
          1st step: Do the standard modules work: not setting the RATP, but for example the weather module ?
          2nd step: if it worked, then add the RATP module, also add ‘debug:true’ in the config also, and share the browser console, this will probably give some more hint.
            Jab
            I do have issue with the module, as it shows always “Loading Connection”
            here is my config:
            module: “MMM-Paris-RATP-PG”,
            position: “top_left”,
            header: “RATP”,
            busStations: [
            {type: “traffic”, line: [“rers”,“A”]},
            {type: “traffic”, line: [“metros”,“3”]},
            {type: “traffic”, line: [“metros”,“9”]}
            I’ve tested URL and they work fine. Any idea ?
            Regards,
            Jab
            J 1 Reply Last reply Dec 31, 2017, 8:36 AM Reply Quote 0
              Jab @Jab
              @Jab
              Reply to myself. Finally it works fine this morning, but I get this:
              A N/A
              3 N/A
              9 N/A
              I’ll continue to investigate…
              C D 2 Replies Last reply Dec 31, 2017, 10:54 AM Reply Quote 0
                Chris @Jab
                @Jab
                If this can help you do your tests, I leave you the code of my config that works well on my mirror.
                			module: "MMM-Ratp",
                			header: "Bus 147 (vers Eglise De Pantin)", // le titre qui sera affiché en haut sur la configuration du widget
                				apiURL: "https://api-ratp.pierre-grimaud.fr/v3/schedules/bus/147/mairie+de+livry+++gargan/R",
                Regards,
                D 1 Reply Last reply Jan 1, 2018, 10:18 AM Reply Quote 0
                  da4throux @Jab
                  @Jab
                  Hi, thanks for giving the module a try.
                  the busStations element in your config seems to only as for traffic information, for those 3 lines.
                  N/A is typically what I get when there is no traffic in the night for example.
                  I checked with a similar config
                          module: 'MMM-Paris-RATP-PG',
                          position: 'bottom_right',
                          header: 'Test Config',
                            busStations: [
                  		        {type: 'traffic', line: ['rers','A']},
                                          {type: 'traffic', line: ['metros','3']},
                                          {type: 'traffic', line: ['metros','9']}
                            pluiePlaces: [{id: '751140', name: 'Home'}],
                            pluieUpdateInterval: 1 * 5 * 60 * 1000, //default is 10 minutes, make it 5 (minimum update time)
                  and get: three Traffic OK.
                  So that might have been the time you worked on it maybe ?
                  Out of curiosity how did you resolve your first issue of “Loading Connection” ?
                    da4throux @Chris
                    @Chris
                    just as a note, this is a config for a different module. To do a similar check with this module you would do:
                      position: 'top_left',
                      header: 'Chris',
                        busStations: [
                          {type: 'bus', line: 147, stations: 'mairie+de+livry+++gargan', destination: 'R'}
                    C 1 Reply Last reply Jan 1, 2018, 11:52 AM Reply Quote 0
                      Chris @da4throux
                      @da4throux
                      Indeed, sorry, I spoke too fast and I was wrong module.
                      I will try this configuration to see the result.
                      Regards,
