    Can't make MMM-Paris-RATP-PG work
    13 Posts 5 Posters 7.7k Views 5 Watching
      AFCM
      Let me first say I’m not an programmer or a developper so my question might be easy to answer
      I started to build my magic mirror, modules work fine but I have some trouble to make MMM-Paris-RATP-PG work properly.
      I don’t know what I should put in the config part {
      I tested this and that from what I can find in the readme but nothing seems to work, I can’t even have something displayed on my monitor.
      I also tested MMM-LocalTransport but it doesn’t fit my needs, want to make it work so my son can use it before he goes to school, stuff like that
      I don’t need a very complex config, just to be able to see, like in the screenshot (https://github.com/da4throux/MMM-Paris-RATP-PG) one line with the bus number, next passage etc and then I will fill the module myself
      Thank you very much,
      da4throuxD 1 Reply Last reply Reply Quote 0
      • da4throuxD Offline
        da4throux @AFCM
        Hi @AFCM , so did you try something from the suggestions of the github readme file,
        like just with one bus for example:
        config:{
        busStations: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’}
        Would it be working on your setup ?
          AFCM @da4throux
          @da4throux Thank you, so I tried your config, I can only see the header nothing else. And the header shows “Connections, update request x S ago”
          This is what I have in my config.js :
          module: ‘MMM-Paris-RATP-PG’,
          position: ‘top_center’,
          header: ‘Connections’,
          config: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’
          I can use the module as a standalone right ? I don’t need anything else ?
            da4throux @AFCM
            @AFCM
            It sounds like a connectivity issue.
            1st step: Do the standard modules work: not setting the RATP, but for example the weather module ?
            2nd step: if it worked, then add the RATP module, also add ‘debug:true’ in the config also, and share the browser console, this will probably give some more hint.
              Jab
              I do have issue with the module, as it shows always “Loading Connection”
              here is my config:
              module: “MMM-Paris-RATP-PG”,
              position: “top_left”,
              header: “RATP”,
              busStations: [
              {type: “traffic”, line: [“rers”,“A”]},
              {type: “traffic”, line: [“metros”,“3”]},
              {type: “traffic”, line: [“metros”,“9”]}
              I’ve tested URL and they work fine. Any idea ?
              Regards,
              Jab
                Jab @Jab
                @Jab
                Reply to myself. Finally it works fine this morning, but I get this:
                A N/A
                3 N/A
                9 N/A
                I’ll continue to investigate…
                ChrisC da4throuxD 2 Replies Last reply Reply Quote 0
                • ChrisC Offline
                  Chris @Jab
                  @Jab
                  If this can help you do your tests, I leave you the code of my config that works well on my mirror.
                  			module: "MMM-Ratp",
                  			header: "Bus 147 (vers Eglise De Pantin)", // le titre qui sera affiché en haut sur la configuration du widget
                  				apiURL: "https://api-ratp.pierre-grimaud.fr/v3/schedules/bus/147/mairie+de+livry+++gargan/R",
                  Regards,
                    da4throux @Jab
                    @Jab
                    Hi, thanks for giving the module a try.
                    the busStations element in your config seems to only as for traffic information, for those 3 lines.
                    N/A is typically what I get when there is no traffic in the night for example.
                    I checked with a similar config
                            module: 'MMM-Paris-RATP-PG',
                            position: 'bottom_right',
                            header: 'Test Config',
                              busStations: [
                    		        {type: 'traffic', line: ['rers','A']},
                                            {type: 'traffic', line: ['metros','3']},
                                            {type: 'traffic', line: ['metros','9']}
                              pluiePlaces: [{id: '751140', name: 'Home'}],
                              pluieUpdateInterval: 1 * 5 * 60 * 1000, //default is 10 minutes, make it 5 (minimum update time)
                    and get: three Traffic OK.
                    So that might have been the time you worked on it maybe ?
                    Out of curiosity how did you resolve your first issue of “Loading Connection” ?
                      da4throux @Chris
                      @Chris
                      just as a note, this is a config for a different module. To do a similar check with this module you would do:
                        position: 'top_left',
                        header: 'Chris',
                          busStations: [
                            {type: 'bus', line: 147, stations: 'mairie+de+livry+++gargan', destination: 'R'}
                      ChrisC 1 Reply Last reply Reply Quote 0
                      • ChrisC Offline
                        Chris @da4throux
                        @da4throux
                        Indeed, sorry, I spoke too fast and I was wrong module.
                        I will try this configuration to see the result.
                        Regards,
