    npm start and black screen
    5 Posts 2 Posters 3.9k Views 2 Watching
    • dexterbengD
      dexterbeng
      Here is the log:
      { Error: listen EADDRINUSE 0.0.0.0:8080
          at Object.exports._errnoException (util.js:1026:11)
          at exports._exceptionWithHostPort (util.js:1049:20)
          at Server._listen2 (net.js:1253:14)
          at listen (net.js:1289:10)
          at net.js:1399:9
          at _combinedTickCallback (internal/process/next_tick.js:77:11)
          at process._tickCallback (internal/process/next_tick.js:98:9)
          at Module.runMain (module.js:592:11)
          at run (bootstrap_node.js:402:7)
          at startup (bootstrap_node.js:157:9)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080 }
      Launching application.
      Shutting down server...
      How to fix this?
      Note : Use “pm2 start mm” is able to run mm.
      dexterbengD 1 Reply Last reply
      • dexterbengD
        dexterbeng @dexterbeng
        @dexterbeng
        I found the problem issue https://forum.magicmirror.builders/topic/2209/error-listen-eaddrinuse-help-plox
        So i use pm2 stop mm, then i can use back npm start since no application is using port:8080.
        But still, is there anyone can explain to me, why my pm2 start mm is take while to boot up my mm, even i ctrl+q, it will turn mm back very long time or never turn on again?
        N 1 Reply Last reply
        • N
          ninjabreadman @dexterbeng
          @dexterbeng If you have pm2 and the mm script installed, it’s simplest to use pm2 start/stop mm. However, npm start dev is still useful to debug server and client consoles, just don’t forget to first pm2 stop mm as you describe.
          • dexterbengD
            dexterbeng @ninjabreadman
            @ninjabreadman
            Ya, agree with that pm2 is the easier way.
            By the way, can I know when you using pm2 to start your mm and you ctrl+q to quit it, how long it takes to auto boot it up again?
            For me, it likes 15 seconds to 30 seconds, and sometimes never turn on again…
            • N
              @dexterbeng I would guess 15-30 seconds. pm2 has to detect that the process has terminated and restart. It depends on the polling interval for pm2 (which, as far as I can tell from their docs/issues, is 100ms, and cannot be changed – seems more frequent than I expected).
              Why are you killing mm with Ctrl+Q? Better to use pm2 restart mm or even pm2 start mm --watch which will also restart mm after file system changes (you may need to configure which directories to watch).
              Reply Quote 2
