    Error: listen Eaddrinuse. Help plox :)
    4 Posts 3 Posters 4.4k Views 3 Watching
    • D
      davidrq7
      Hi guys i have a little error… Can any1 help plz ? :)
      alt text
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @davidrq7
        @davidrq7 something on your system is already using port 8080, is there a instance of MagicMirror not closed correctly? either restart the pi or change the port in the config file
        • Y
          yawns Moderator
          There is another process running on port 8080
          Are you running MagicMirror with pm2? Or manually?
          Please run sudo netstat -lnptu to check which application is blocking 8080
          • D
            davidrq7
            THX guys now i know what is going on. MagicMirror works fine :) THX !
