    Translate errors in "NEWS"
    4 Posts 3 Posters 3.1k Views 2 Watching
    • G Offline
      gshimself
      Hi guys. I just updated my RPI2 from MM1 to the new MM2. Works like a charm!
      But I got one problem. I uses a RSS feed from a swedish newsfeed called “Expressen” and they uses swedish letters like “ÅÄÖ”. This aint a problem overall on the MM2 (Like calenders, weather and so on. There it works) But on the newsfeed i only get “?” symbols.
      I’ve checked and UTC-8 shall work, but I have tried change it anyway to ISO-8859 but no success.
      Anyone that could help me with this problem? Thanks!
        Snoevit
        Hey! I got the same issue, i solved it by using this:
        	module: 'newsfeed',
        	position: 'bottom_center',
        		feeds: [
        			   title: "Expressen",
        			   url: "http://expressen.se/rss/nyheter",
        			   encoding: "ISO-8859-1",
        			showSourceTitle: true,
        			showPublishDate: true,
        			showDescription: true,
        			reloadInterval: 200000,
        			updateInterval: 15000,
        			animationSpeed: 3500
        When i was trying with Aftonbladet, DN and my local paper, they all worked without encoding, so there must be something in Expressens feed.
        • MichMichM Offline
          MichMich
          Like @Snoevit says: check out the encoding field.
          • G Offline
            gshimself
            @Snoevit I did try it, but I probly made something wrong cause now it’s working. Thanks alot! :)
