    Max! cube system
    maxcubeeq-3
    5 Posts 4 Posters 2.5k Views 4 Watching
      blazkom
      Does anybody know if it is possible to make module that show settings and current temprature from MAX! EQ-3 Cube
      http://www.eq-3.com/products/max/max-house-solution/max-cube-lan-gateway.html
      Thanx a lot
        schienw
        https://github.com/mirko3000/MMM-max
          pinsdorf Module Developer
          When there is an API there is a way! :-)
          Have a look at this community approach to describe Max! Cube API.
            blazkom
            I have install module
            Can someone please check if this script is corrent. My cube ip is 192.168.1.135
            If i add script like that, then when magic mirror is start i only get black screen.
            module: ‘MMM-max’,
            position: ‘bottom_left’,
            header: ‘Heizung / Temperatur’, // This is optional
            maxIP: ‘192.168.1.135’, // See ‘Configuration options’ for more information.
            • V Offline
              Vauxdvihl
              @pinsdorf
              i have a problem with getting connected to MaxCube
              [2020-09-16 20:55:56.345] [LOG]    Triggering MAX upate
              [2020-09-16 20:55:56.351] [ERROR]  Error: getaddrinfo ENOTFOUND 192.xxx.xxx.xxx:80
                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:64:26) {
                errno: 'ENOTFOUND',
                code: 'ENOTFOUND',
                syscall: 'getaddrinfo',
                hostname: '192.xxx.xxx.xxx:80'
              [2020-09-16 20:55:56.360] [ERROR]  Whoops! There was an uncaught exception...
              [2020-09-16 20:55:56.361] [ERROR]  Error [ERR_UNHANDLED_ERROR]: Unhandled error. (undefined)
                  at MaxCubeLowLevel.emit (events.js:299:17)
                  at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-max/maxcube/maxcube-lowlevel.js:51:10)
                  at Socket.emit (events.js:310:20)
                  at emitErrorNT (internal/streams/destroy.js:92:8)
                  at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
                  at processTicksAndRejections (internal/process/task_queues.js:84:21) {
                code: 'ERR_UNHANDLED_ERROR',
                context: undefined
              Do you have an idea want went wrong?
              here is my config
              {//MMM-max
              				module: 'MMM-max',
              				position: 'bottom_left',
              				header: 'Heizung / Temperatur',  // This is optional
              				maxIP: '192.xxx.xxx.xxx:80',// See 'Configuration options' for more information.
              Thanks a lot
