    Kalliope assistant + MM
    Scheduled Pinned Locked Moved Fun & Games
    58 Posts 10 Posters 46.8k Views 12 Watching
    • E Offline
      E3V3A @sispheor
      @sispheor Sorry, but I would never use a pre-compiled image of anything. It just doesn’t make sense. Most people already has a bunch of stuff installed that they don’t want to loose.
      So from what I understand from your github comment, we need to install at least 3 separate Kalliope things in order to use it. Now, that’s quite a bunch of work, and a lot of separate reading. It would be great to have all steps in one place.
      No, I don’t want to sound pessimistic or anything, but I believe in trying to keep basic installation info in one place. I’m so sick of dealing with the lack of documentation and easy to follow instructions for 99% of what you find on github. Those things alone can be total project killers.
      KISS principle! (At least to get up and running.)
      "Everything I do (here) is for free – altruism is the way!"
        sispheor
        As Kalliope is a complete separate project, yes it has its own installation process. But il you take a look to the manual install doc it’s not a big deal.
        I don’t know what you mean by having all info in one place. MM has is installation doc in one place, and modules have their own doc per module.
        It’s exactly the same for Kalliope. You need to install the core project and then module (neuron).
        Don’t hesitate to tell me if something is missing.
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          E3V3A @sispheor
          @sispheor
          What I mean is:
          People already has MM installed, so they go to MMM-kalliope in hope to just get it working/installed, but instead just find:
          Module to bind Kalliope with your Magic Mirror.
          Note: On Kalliope, a neuron is available to talk with this module directly.
          Huh!? WTF is a neuron!? What is that? Well…ok.
          So they go to kalliope_neuron_magic_mirror and find the same screenshot there…but still no installation info to follow. Eh, what does this do, and why is not just part of the MMM? Circular back link to MMM-kalliope, since there is no ref link back to main kalliope.
          By this time I’m already annoyed, but try to persist and follow:
          Kalliope installation documentation
          Then … I have to follow the next link:
          Please follow the right link bellow to install requirements depending on your target environment:
          Raspbian (Raspberry Pi 2 & 3)
          and the next one…and now I’m totally sick of shitty instructions. And whatever was good, I’ve already forgotten.
          One page please!?
          I think it should be simple enough for you guys to do, especially for simple unified devices like the RPi’s, where everyone is pretty much running the same stuff.
          • E Offline
            E3V3A
            A hot KISS tip for writing any kind of SW installation documentation:
            • Ask your girlfriend, boyfriend or 9 year old kid, who has not used it before to follow it.
            Could they complete it within 1 hour?
            No? - Then it’s shit written documentation.
            • E Offline
              E3V3A
              I just want to inform the rest of the forum members, that in case you think I come across as a bit hardass here, I’m in good contact with @sispheor who I think understand now, what the problems are.
              What are they?
              • How to make great project modules more reachable outside the developer expert community!
              • Everyone want to talk to their computers, Google, Alexa, Siri, Jarvis, AI-this-that-and-what-not!
                sispheor
                We have added a single line command install for Kalliope.
                Tested on a single Raspberry Pi, both project fit perfectly and the whole can be installed in two command line.
                Thanks for your feedback !
                • E Offline
                  E3V3A @sispheor
                  @sispheor said in Kalliope assistant + MM:
                  Is it for the MMM-kalliope?
                  Fantastic! Sound like music to our ears!
                    sispheor
                    No it’s for Kalliope core. MMM-Kalliope need to be installed via only a clone of the module as usual.
                    And the kalliope neuron can be installed via the kalliope CLI. It’s in the doc of each community neuron.
                    • N Offline
                      NoNameRo
                      @sispheor when trying to install Kalliope on a freshly installed system, I have 2 errors
                      Searching for SpeechRecognition>=3.7.1
                      Reading https://pypi.python.org/simple/SpeechRecognition/
                      No local packages or working download links found for SpeechRecognition>=3.7.1
                      error: Could not find suitable distribution for Requirement.parse('SpeechRecognition>=3.7.1')
                      Searching for apscheduler>=3.3.1
                      Reading https://pypi.python.org/simple/apscheduler/
                      Downloading https://pypi.python.org/packages/c4/16/8be21944c787ef13cd7581c62d446053d079f36aa54ef20b5b45b378944d/APScheduler-3.5.1.tar.gz#md5=18c2050f24bad3dd82e17dd4b5f182df
                      Best match: APScheduler 3.5.1
                      Processing APScheduler-3.5.1.tar.gz
                      Writing /tmp/easy_install-NmMSMf/APScheduler-3.5.1/setup.cfg
                      Running APScheduler-3.5.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-NmMSMf/APScheduler-3.5.1/egg-dist-tmp-px4K5B
                        File "build/bdist.linux-armv7l/egg/apscheduler/executors/base_py3.py", line 12
                          async def run_coroutine_job(job, jobstore_alias, run_times, logger_name):
                      SyntaxError: invalid syntax
                      creating /usr/local/lib/python2.7/dist-packages/APScheduler-3.5.1-py2.7.egg
                      Extracting APScheduler-3.5.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
                        File "/usr/local/lib/python2.7/dist-packages/APScheduler-3.5.1-py2.7.egg/apscheduler/executors/base_py3.py", line 12
                      then a little excitement, add the starter configuration to rpi_install_kalliope.sh, and let the user during the installation choose which language he wants to install
                        sispheor @NoNameRo
                        @NoNameRo said in Kalliope assistant + MM:
                        SpeechRecognition
                        I had this one time.
                        Can you try to install the lib manually?
                        sudo pip install SpeechRecognition
                        Then run the install again from the kalliope folder (in /home/pi)
                        sudo python setup.py
                        It’s weird, sometime pip doesn’t find this lib.
                        • 1 / 6
