Solved Screen shines black / Don´t know if it´s an Pi or Screen-Error?
@jcklerk only is jou didnt see ennything on the screan if you start up the magicmirror
like so https://gyazo.com/88b59086d8b394e8cdf94dd3faa1b014and this is the screan when the dev is tunt on…
https://gyazo.com/d2492aa8a2988b37a353e49b72aee5d9 -
When I go to the MM folder and type
npm stop
I got an errors:
npm ERR! missing script: stop npm ERR! A complete log of this run can be found in: nom ERR! /home/pi/.npm/_logs/2018-07-26T14_14_20_020Z-debug.log but I can´t open the folder because there is no folder like this. So I can´t stop it?! I can´t stop the npm aswell via remote desktop from Windows... I´m confused
@killing-joke try pm2 stop mm or pm2 stop mm.sh
It worked with
pm2 stop MagicMirror
after
npm start dev
there are some errors… but they appeared after I connected via remote desktop
(see picture)!
0_1532617380576_forum.png -
and wat does the consel put out?? ( wher you type npm start )
@killing-joke
check if the screensaver is deactivated -
On the screen the the screensaver is deactivated.
Is there an option on the pi?
@killing-joke said in Screen shines black / Don´t know if it´s an Pi or Screen-Error?:
what you can still try
open
sudo nano /boot/config.txt
and add
# uncomment to put the monitor into power saving mode (DPMS) hdmi_blanking=1
After I edit the code as you described above, the screen shows “no signal” after 10 to 15 minutes.
