    Screen shines black / Don´t know if it´s an Pi or Screen-Error?
    14 Posts 5 Posters 6.2k Views 4 Watching
    • K Offline
      killing joke
      Hello @ all,
      unfortunately I don´t know how to describe my problem excactly and therefore I don´t know if its in the right corner of the forum.
      After I start my Pi (connected via HDMI to the screen) it works fine. The MagicMirror starts automatically after a few seconds on the destop.
      After 10 to 15 minutes the screen turns black but is still on (the notebook screen shines on the backside completly white).
      If I connect a mouse and/or a keyboard to the pi and press any key nothing happend, so it seems not to be a screensaver issue?!
      On the screen menu I switched the screen sleep mode to off so it can´t be this issue as well?!
      Is there an sleep mode on the pi or included in the MagicMirror code?
      Any help is appreciated.
      Thanks in advance
      Killing Joke aka Daniel
      P.S.: Whenever I switch the screen off and on again it´s still black.
      • jcklerkJ Offline
        jcklerk
        stop the auto run and goo to the magicmirror folder in the command line and type npm start dev
        chek if ther are errors… bicase then the application is blank and your monitor is going in sleep…
        jcklerkJ 1 Reply Last reply Reply Quote 0
        • jcklerkJ Offline
          jcklerk @jcklerk
          @jcklerk only is jou didnt see ennything on the screan if you start up the magicmirror
          like so https://gyazo.com/88b59086d8b394e8cdf94dd3faa1b014
          and this is the screan when the dev is tunt on…
          https://gyazo.com/d2492aa8a2988b37a353e49b72aee5d9
          • K Offline
            killing joke
            When I go to the MM folder and type
            npm stop
            I got an errors:
            npm ERR! missing script: stop
            nom ERR!            /home/pi/.npm/_logs/2018-07-26T14_14_20_020Z-debug.log
            but I can´t open the folder because there is no folder like this.
            So I can´t stop it?!
            I can´t stop the npm aswell via remote desktop from Windows...
            I´m confused
            • jcklerkJ Offline
              jcklerk @killing joke
              @killing-joke try pm2 stop mm or pm2 stop mm.sh
              • K Offline
                killing joke
                It worked with
                pm2 stop MagicMirror
                after
                npm start dev
                there are some errors… but they appeared after I connected via remote desktop
                (see picture)!
                • jcklerkJ Offline
                  jcklerk
                  and wat does the consel put out?? ( wher you type npm start )
                  • K Offline
                    killing joke
                    • N Offline
                      NoNameRo @killing joke
                      @killing-joke
                      check if the screensaver is deactivated
                      • K Offline
                        killing joke
                        On the screen the the screensaver is deactivated.
                        Is there an option on the pi?
