    MMM-AssistantMk2
    421 Posts 61 Posters 788.9k Views 57 Watching
      A Former User @citizendevpi
      @citizendevpi
      Ok. forget my previous answer.
      arecord -l
      It’s l (small L), not 1 (one)
      citizendevpiC 1 Reply Last reply Reply Quote 0
      • citizendevpiC
        citizendevpi @Guest
        @sean **** List of CAPTURE Hardware Devices ****
        card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
        Subdevices: 0/1
        Subdevice #0: subdevice #0
          @citizendevpi
          Your recording device is plughw:0,0. or default. Remember it.
          Then try this.
          arecord -d 10 test.wav
          Say something. It will be record your voice to test.wav on 10 secs.
          Works?
          If so, then,
          aplay test.wav
          It should play previous recording from arecord. Can you hear anything?
          • citizendevpiC
            citizendevpi @Guest
            @sean yes barley
            but yes
              @citizendevpi
              Your Mic and Speaker are both the default. So, Now, show your config to me.
              • citizendevpiC
                citizendevpi @Guest
                  A Former User
                  UPDATE
                  2.1.0 demo
                  [2.1.0] - 2018.11.14
                  • Customizable command feature is added. Now you can control your device and MM without other module’s help.
                    And notification system of transcriptionHook is changed. New configuration is needed.
                  • Prepared hook commands. Say these (Or customize them in configuration)
                    • hide all : modules on screen will be hidden
                    • show all : hidden modules will be shown again
                    • reboot yourself : reboot device
                    • shutdown yourself : shutdown device
                    • go to sleep : LCD power off (you might need to modify /scripts/screenoff.sh)
                    • wake up : LCD power on (you might need to modify /scripts/screenon.sh)
                  • onIdle feature be added. After timer without no query after last query, command will be activated. (By default, after 30min All modules will be hidden.)
                  • And onActivate feature is added. When you activate Assistant, this command will be executed after timer. (By default, modules hidden by onIdle will be shown again)
                  • For update from 2.0.0
                  cd ~/MagicMirror/modules/MMM-AssistantMk2
                  git pull
                  • Cr4z33C
                    Cr4z33 @Guest
                    @sean thanks for the update, but what are those fireworks?
                    Nothing to do with your module or? :grinning_face:
                      A Former User @Cr4z33
                      @cr4z33 I wanted someone to ask about Fireworks. :D. I’m making that module for my X-mas eyecandy.
                      But unfortunately, on RPI the speed is crazy slow. I’m doing optimization, but hard. :D. If I get a success, I’ll release.
                      • Cr4z33C
                        Cr4z33 @Guest
                        @sean lol alright although I personally wouldn’t use it. :grinning_face_with_smiling_eyes:
                        • T
                          teitlebot
                          @Sean
                          Thanks for the update. I have two small issues after update.
                          For some weird reason most of my modules go blank after some time and only turn back on after I trigger assistant with voice.
                          Also the feedback window only shows up at the bottom if the speaker icon is top right of screen but if I try moving icon the feedback window ends up being in very small areas of screen.
                          I can post video if I’m not explaining well.
                            A Former User @teitlebot
                            @teitlebot
                            • onIdle feature be added. After “timer” is passed without no query from last query, command will be activated. (By default, after 30min All modules will be hidden.)
                              => set configuration like this.
                            onIdle: {
                            timer: 0, // if you don’t want to use this feature, just set timer as 0 or command as “”
                            command: “”
                              @teitlebot
                              Second might be css adjustments needed. I don’t know your whole module and css structure, so currently can’t answer. Tomorrow I’ll test and reply to you.
                              • T
                                Tschili
                                  A Former User
                                  UPDATED
                                  [2.1.1] - 2018.11.23
                                  • TTS feature is added. Now, Other modules can order MMM-AssistantMk2 to say something. It can be used like something similar TEXT-TO-SPEECH. By example, you can build your customClock module to say current time via MMM-AssistantMk2
                                    • USAGE:
                                      • this.sendNotification("ASSISTANT_SAY", "Time to go to bed")
                                      • this.sendNotification("ASSISTANT_SAY", {text:"C'est trop chaud", lang:"fr-FR"})
                                    • NOTICE:
                                      • This feature is somekind of Assistant hooking. If you say “Repeat after me SOMETHING”, Google Assistant will repeat SOMETHING. So, there could be a possibility of not responding as intend. Too long or complex text might be not available.
                                      • Currently I can’t find correspondence of Repeat after me for German/Japanese/Korean language. PR please.
                                    • Thanks to Valerio Pilo. His brilliant idea and PR could make this feature.
                                  • For TelegramBot, TTS feature is also added. Now you can make your Home Mirror to say something with MMM-TelegramBot even when you are working in your office.
                                    • /s Please open the door, mom!
                                  • Youtube playing status in frontend dev-panel is added.
                                    • At least you can get status of Youtube player event when video fails to be played.
                                  • For update from 2.1.0
                                  git pull
                                  • T
                                    teitlebot
                                    @Sean Thank for the update
                                    I have another strange problem starting with the previous update already. If I have assistant module running my node serveronly debug doesnt show anything past “open your browser…”
                                    Basically everything is working but no information gets displayed in the debug window. This problem is only there if I load this module, so something here is doing it.
                                      @teitlebot Weird. I cannot guess what could make that. Exactly what commands did you execute? and Is MM running regardless no log?
                                      • T
                                        teitlebot @Guest
                                        @sean Yes MM is running without log just fine.
                                        I didnt execute anything but I do have lots of modules running and none of their info shows in the log unless I disable assistant.
                                          A Former User
                                          Maybe verbose:true ?
                                          • T
                                            teitlebot @Guest
                                            @sean said in MMM-AssistantMk2:
                                            verbose:true
                                            just tried that but didnt help
                                            • 10
                                            • 11
                                            • 21
                                            • 22
                                            • 9 / 22
