Unsolved MMM-MirrorMirrorOnTheWall installation issue
@oceank I haven’t gotten the chance to give it another try but i will soon :)
Did you do the changes that @blackpanda suggested ?? whats it telling you now??@blackpanda It took me a while to realize that it says MagicMirror but on our MirrorMirror.js file the ClienId is MirrorMirror so i changed that and i uploaded on Lambda and i made the appropriate policy changes on the IoT to reflect my arn:aws and my number nut just copy paste yours
but when i test Lambda now i get this error: The applicationIds don’t match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.e0223a06-d061-48bd-9b1c-3XXXXa950fcfAnd the app ID has not changed?? And also when i go to test the skill now on the Alexa developer side now i dont even get"Hello My queen…" i used to get it just goes straight to there was a problem with the requested skills response.
What else do i need to change cause i doubt there is anything major …has the syntax changed again appID or aplicationId etc???
Thank you any help is greatly appreciated
D -
@richland007 so you changed the clientId in the lambda function and uploaded it. Did you change the client id in the module as well? Can you post your security policy? You should also define your queues (modules) there.
The app id is defined in index.js of the skill. APP_ID is defined in a variable near the top of the file.
Looks like this currently:
alexa.appId = APP_ID
Also, you can verify what your skill id is by checking in the amazon developer console then selecting ‘endpoint’ (it’s an option on the left pane under interaction model and interfaces).
pro-tip:
A way to check and see if you’re actually subscribing to the topics that are publishing search results:
if you run the following command from a remote putty session…
cd ~/MagicMirror Display=:0 npm start
you should eventually see that you’re subscribing to the topics!
Initially, the misconfigured security policy was preventing this from happening and authorization errors were being thrown in the background (had to dig into cloudwatch logs for this). In putty, the command would simply hang at “Attempt to connect to AWS”
Basically your youtube api search results will be published to the “new-video” queue…and if your aren’t subscribed to that queue then you wont see anything change on your monitor. Same for your google image searches and “new-images”. and so on.
when building the alexa model and enter the interaction model, is this the correct model?
“interactionModel”: {
“languageModel”: {
“invocationName”: “magic mirror”,
“intents”: [
“name”: “AMAZON.FallbackIntent”,
“samples”: []
“name”: “AMAZON.CancelIntent”,
“samples”: []
“name”: “AMAZON.HelpIntent”,
“samples”: []
“name”: “AMAZON.StopIntent”,
“samples”: []
“name”: “MirrorMirrorHelloIntent”,
“slots”: [],
“samples”: [
“good evening”,
“good afternoon”,
“good morning”,
“hey”,
“hi”,
“hello”
“name”: “ShowTextIntent”,
“slots”: [
“name”: “displayText”,
“type”: “LIST_OF_TEXT”
“samples”: [
“say {displayText}”,
“display text of {displayText}”,
“show text of {displayText}”
“name”: “TurnOnModuleIntent”,
“slots”: [
“name”: “moduleName”,
“type”: “LIST_OF_MODULES”
“samples”: [
“open {moduleName}”,
"open module {moduleName} ",
“show {moduleName}”,
"show module {moduleName} ",
“turn on {moduleName}”,
"turn on module {moduleName} ",
“start {moduleName}”,
"start module {moduleName} "
“name”: “TurnOnAllModuleIntent”,
“slots”: [],
“samples”: [
“open all”,
“open all modules”,
“open every module”,
“open each module”,
“show all modules”,
“show me all modules”,
“show every module”,
“show each module”,
“turn on all”,
“turn on all modules”,
“turn on every module”,
“turn on each module”,
“start all”,
“start all modules”,
“start every module”,
“start each module”
“name”: “TurnOffAllModuleIntent”,
“slots”: [],
“samples”: [
“close all”,
“close all modules”,
“close every module”,
“close each module”,
“hide all”,
“hide all modules”,
“hide every module”,
“hide each module”,
“turn off all”,
“turn off all modules”,
“turn off every module”,
“turn off each module”
“name”: “TurnOffModuleIntent”,
“slots”: [
“samples”: [
“close {moduleName}”,
"close module {moduleName} ",
“hide {moduleName}”,
"hide module {moduleName} ",
“turn off {moduleName}”,
“turn off module {moduleName}”
“name”: “ShowImagesIntent”,
“slots”: [
“name”: “searchTerm”,
“type”: “LIST_OF_IMAGES”
“samples”: [
“find {searchTerm}”,
“find images of {searchTerm}”,
“find pictures of {searchTerm}”,
“show me {searchTerm}”,
“show me pictures of {searchTerm}”,
“show me images of {searchTerm}”,
“show pictures of {searchTerm}”,
“show images of {searchTerm}”,
“display pictures of {searchTerm}”,
“display images of {searchTerm}”
“name”: “ShowVideoIntent”,
“slots”: [
“name”: “searchTermVideo”,
“type”: “LIST_OF_VIDEOS”
“samples”: [
“show me how to {searchTermVideo}”,
“show me video of {searchTermVideo}”,
“show me a video of {searchTermVideo}”,
“show video of {searchTermVideo}”,
“show a video of {searchTermVideo}”,
“display video of {searchTermVideo}”,
“display a video of {searchTermVideo}”,
“find video of {searchTermVideo}”,
“find a video of {searchTermVideo}”
“name”: “AMAZON.MoreIntent”,
“samples”: []
“name”: “AMAZON.NavigateHomeIntent”,
“samples”: []
“name”: “AMAZON.NavigateSettingsIntent”,
“samples”: []
“name”: “AMAZON.NextIntent”,
“samples”: []
“name”: “AMAZON.PageUpIntent”,
“samples”: []
“name”: “AMAZON.PageDownIntent”,
“samples”: []
“name”: “AMAZON.PreviousIntent”,
“samples”: []
“name”: “AMAZON.ScrollRightIntent”,
“samples”: []
“name”: “AMAZON.ScrollDownIntent”,
“samples”: []
“name”: “AMAZON.ScrollLeftIntent”,
“samples”: []
“name”: “AMAZON.ScrollUpIntent”,
“samples”: []
“types”: [
“name”: “LIST_OF_TEXT”,
“values”: [
“name”: {
“value”: “hello”
“name”: {
“value”: “hello everyone”
“name”: {
“value”: “good morning”
“name”: {
“value”: “good morning to you”
“name”: {
“value”: “how are you doing”
“name”: “LIST_OF_MODULES”,
“values”: [
“name”: {
“value”: “calendar”
“name”: {
“value”: “current weather”
“name”: {
“value”: “smile test”
“name”: {
“value”: “compliments”
“name”: “LIST_OF_IMAGES”,
“values”: [
“name”: {
“value”: “queen”
“name”: {
“value”: “snow white”
“name”: {
“value”: “seven dwarfs”
“name”: {
“value”: “sharks”
“name”: {
“value”: “elon musk”
“name”: {
“value”: “apples”
“name”: {
“value”: “sea animals”
“name”: {
“value”: “octopus”
“name”: {
“value”: “volcanoes”
“name”: {
“value”: “birds”
“name”: {
“value”: “bill gates”
“name”: {
“value”: “animals”
“name”: {
“value”: “rattle snakes”
“name”: “LIST_OF_VIDEOS”,
“values”: [
“name”: {
“value”: “draw”
“name”: {
“value”: “paint”
“name”: {
“value”: “make slime”
“name”: {
“value”: “unlock locks”
“name”: {
“value”: “apples”
“name”: {
“value”: “bananas”
“name”: {
“value”: “movie trailer”
“name”: {
“value”: “video games”
“name”: {
“name”: {
“value”: “birds”
“name”: {
“name”: {
“value”: “animals”
“name”: {
“name”: {
“value”: “cats”
“name”: {
“value”: “dogs”
“name”: {
“value”: “lego superman”
“name”: {
“value”: “lego batman”
“name”: {
“value”: “apple and orange”
“name”: {
“value”: “evil queen”
@oceank does it compile? what happens when you test? That model can vary, mine has been customized a bit.
@blackpanda OK well i think i got it to work but not really …it doesn’t seem like it is working right!!!
I changed the alexa.appId = APP_ID but when i test Lambda it is still giving this error onthe Lamda Test: application Id must be unique.START RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a Version: $LATEST 2019-01-05T19:14:08.827Z 12e0e369-111e-11e9-9390-b5c3e0fcc19a The applicationIds don't match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.e0223a06-d061-48bd-9b1c-XXX9a950fcf 2019-01-05T19:14:08.850Z 12e0e369-111e-11e9-9390-b5c3e0fcc19a { "errorMessage": "Invalid ApplicationId: amzn1.ask.skill.e0223a06-d061-48bd-9b1c-XXXX9a950fcf", "errorType": "Error", "stackTrace": [ "AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:157:27)", "HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)", "/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9", "done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)", "/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7", "I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)", "I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)", "load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)", "I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)", "AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:114:32)" ] } END RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a REPORT RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a Duration: 208.20 ms Billed Duration: 300 ms Memory Size: 128 MB Max Memory Used: 65 MB
On a good note:
When i start the MMM-MirrorMirrorOnTheWall now i can see:cd ~/MagicMirror Display=:0 npm start
Connected to AWS IoT:
Subscribed: etc etc …for all 4: new-text, new-images, change-module, new-video just like yours so it is connected to IoTHowever when i go to developer.alexa site and try to build the new interaction model using the drag and drop template i get this error
Again the Interaction Model Is the stock one that comes with the package form github
Lets get this sucker going it is driving me nuts… i can confirm that the AppID is the right one
Denis
@richland007 Yep. Ran into that one. The interaction model from the project is outdated. You’ll have to refactor it a bit.
AMAZON.LITERAL was deprecated and you’ll have to create a Custom literal (pretty easy to do from the UI).
Check this out: https://developer.amazon.com/docs/custom-skills/literal-slot-type-reference.html
Regarding the app id, you’re sure you copied the skill value and added it to the APP_ID variable before uploading it to Lambda? Also, did you disable skill verification in Lambda (this was mentioned in the install doc)?
@blackpanda said in MMM-MirrorMirrorOnTheWall installation issue:
Yes i sure did copy and paste it to the index.js file before uploading i tried it also twice just now i also made sure that i disabled the skill verification on Alexa Skill Kit (it says right now on Lambda: "We recommend you enable skill verification for Alexa Skill Kit to do that delete and read the skill etc etc…)
Its so wired … i just found that AMAZON.LITERAL post right before you posted here i will try to work as much asi can on it and ask for help again
D
@blackpanda OMG!!! thanx a MILION DUDE! im so happy, its all working now, video, pcitures, modules…everything =)
YES!
@blackpanda last question: If I made a picture search I see the pictures. But how do I clear those? same goes to video.
