    Error on npm install
    14 Posts 3 Posters 10.6k Views 3 Watching
      rmeskill
      So I had a working copy of MagicMirror2 running on a Raspberry Pi 2, but I was running node at version 4.2 (I think, though it could have been npm that was complaining) so I finally bit the bullet and decided to upgrade. Now I’m running node v11.6.0 and npm v6.5.0, but when I try npm install && npm start in the MagicMirror directory, I get an error after it hangs for 30-60 minutes on one piece installing. It’s not always consistent on where it fails and I’ve tried multiple times to no avail. I’ve tried removing and reinstalling nodejs. I’ve tried copying away the MagicMirror directory and running the install script and everything fails at the same point. Here’s the output:
      pi@raspberrypi:~/MagicMirror $ npm install && npm start
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      Unhandled rejection Error: Command failed: /usr/bin/git clone --mirror -q git://github.com/patriksimek/vm2.git /home/pi/.npm/_cacache/tmp/git-clone-6428927c/.git
      warning: templates not found /tmp/pacote-git-template-tmp/git-clone-1f4f605f
      fatal: read error: Connection timed out
          at ChildProcess.exithandler (child_process.js:294:12)
          at ChildProcess.emit (events.js:188:13)
          at maybeClose (internal/child_process.js:978:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
      npm ERR! cb() never called!
      npm ERR! This is an error with npm itself. Please report this error at:
      npm ERR!     <https://npm.community>
      npm ERR!     /home/pi/.npm/_logs/2019-01-06T06_19_57_831Z-debug.log
      I should note the error appears to be due to a connection time-out, and I’ve checked my dns and pings work fine to the outside world. Does anyone have any thoughts?
        rmeskill
        I’ve run npm cache clean --force also to no avail. And here’s the output of the .log file referenced in the initial error:
        pi@raspberrypi:~ $ tail /home/pi/.npm/_logs/2019-01-06T14_26_53_131Z-debug.log
        12308 http fetch GET 200 https://registry.npmjs.org/core-js/-/core-js-2.5.1.tgz 48668ms
        12309 silly extract core-js@2.5.1 extracted to /home/pi/MagicMirror/node_modules/.staging/core-js-bce1a382 (63355ms)
        12310 http fetch GET 200 https://registry.npmjs.org/clarinet/-/clarinet-0.12.3.tgz 60019ms
        12311 silly extract clarinet@^0.12.0 extracted to /home/pi/MagicMirror/node_modules/.staging/clarinet-d9485acf (60537ms)
        12312 http fetch GET 200 https://registry.npmjs.org/rxjs/-/rxjs-6.3.3.tgz 216457ms
        12313 silly extract rxjs@^6.1.0 extracted to /home/pi/MagicMirror/node_modules/.staging/rxjs-ec2c3fab (217547ms)
        12314 timing npm Completed in 9958812ms
        12315 error cb() never called!
        12316 error This is an error with npm itself. Please report this error at:
        12317 error https://npm.community
          paddyhughes @rmeskill
          @rmeskill
          I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
          This is what worked for me
          sudo npm i -g npm
            rmeskill
            @paddyhughes said in Error on npm install:
            sudo npm i -g npm
            sudo npm i -g npm didn’t work for me, got this error:
            pi@raspberrypi:~ $ sudo npm i -g npm
            /usr/local/lib/node_modules/npm/bin/npm-cli.js:85
                  let notifier = require('update-notifier')({pkg})
            SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
                at exports.runInThisContext (vm.js:53:16)
                at Module._compile (module.js:414:25)
                at Object.Module._extensions..js (module.js:442:10)
                at Module.load (module.js:356:32)
                at Function.Module._load (module.js:311:12)
                at Function.Module.runMain (module.js:467:10)
                at startup (node.js:134:18)
                at node.js:961:3
            Trying just with npm i -g npm instead…
              rmeskill
              @rmeskill said in Error on npm install:
              Did give me a positive output:
              Trying npm install again…
                @rmeskill try do it in the MagicMirror folder
                sudo npm i -g npm
                  sdetweil @paddyhughes
                  @paddyhughes -g means global, not mm specific.
                    rmeskill
                    sudo npm i -g npm
                    Sudo still doesn’t work, but I tried it again just ‘npm i -g npm’ in the MagicMirror folder. Now I’m trying npm install again in the MagicMirror folder again, so I guess we’ll see, but it looks like it’s stuck at the same point as last time
                      sdetweil @rmeskill
                      @rmeskill looks like node is also downlevel
                        rmeskill
                        @sdetweil said in Error on npm install:
                        Do you mean I should upgrade it? this isn’t enough:
                        pi@raspberrypi:~/MagicMirror $ node -v
                        v11.6.0
                          sdetweil @rmeskill
                          @rmeskill that is a surprise
                            rmeskill
                            Now I’m trying to remove npm and nodejs to start again, but even after I’ve run apt-get remove npm nodejs I still get this:
                            pi@raspberrypi:~/MagicMirror $ which npm
                            /home/pi/.nvm/versions/node/v11.6.0/bin/npm
                            pi@raspberrypi:~/MagicMirror $ which node
                            /home/pi/.nvm/versions/node/v11.6.0/bin/node
                              .nvm/
                              looks like node version manager (nvm) was used to install these…
                              you could temporarily remove those folders from the PATH environment variable.
                              or search for remove nvm… and found
                              No, all you need to do is remove $NVM_DIR (~/.nvm is the default), and the relevant 2 lines in your profile file (but you also can leave those behind, since they’re guarded by a file existence check).
                                rmeskill
                                Seems my reply to this got lost…
                                Got this working! Removed the .nvm directory, removed the symlinks, shutdown pm2 and re-ran the installation script and it all went in fine!
                                sudo rm -rf ~/.nvm
                                sudo rm -f /usr/local/bin/node
                                sudo rm -f /usr/local/bin/nvm
                                pm2 stop mm
                                sudo rm -rf ~/MagicMirror
                                bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                                I got an error on npm not being the right version, so upgraded that:
                                sudo npm i -g npm
                                (Note sudo is working now, which it wasn’t before) And now my node and npm versions look good and pm2 is running MagicMirror again!
                                pi@raspberrypi:/ $ node -v
                                v9.11.2
                                pi@raspberrypi:/ $ npm -v
                                6.5.0
                                Thanks everyone for the help!
