    Error on npm install
    14 Posts 3 Posters 10.7k Views 3 Watching
      rmeskill
      I’ve run npm cache clean --force also to no avail. And here’s the output of the .log file referenced in the initial error:
      pi@raspberrypi:~ $ tail /home/pi/.npm/_logs/2019-01-06T14_26_53_131Z-debug.log
      12308 http fetch GET 200 https://registry.npmjs.org/core-js/-/core-js-2.5.1.tgz 48668ms
      12309 silly extract core-js@2.5.1 extracted to /home/pi/MagicMirror/node_modules/.staging/core-js-bce1a382 (63355ms)
      12310 http fetch GET 200 https://registry.npmjs.org/clarinet/-/clarinet-0.12.3.tgz 60019ms
      12311 silly extract clarinet@^0.12.0 extracted to /home/pi/MagicMirror/node_modules/.staging/clarinet-d9485acf (60537ms)
      12312 http fetch GET 200 https://registry.npmjs.org/rxjs/-/rxjs-6.3.3.tgz 216457ms
      12313 silly extract rxjs@^6.1.0 extracted to /home/pi/MagicMirror/node_modules/.staging/rxjs-ec2c3fab (217547ms)
      12314 timing npm Completed in 9958812ms
      12315 error cb() never called!
      12316 error This is an error with npm itself. Please report this error at:
      12317 error https://npm.community
        paddyhughes @rmeskill
        @rmeskill
        I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
        This is what worked for me
        sudo npm i -g npm
          rmeskill
          @paddyhughes said in Error on npm install:
          sudo npm i -g npm
          sudo npm i -g npm didn’t work for me, got this error:
          pi@raspberrypi:~ $ sudo npm i -g npm
          /usr/local/lib/node_modules/npm/bin/npm-cli.js:85
                let notifier = require('update-notifier')({pkg})
          SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
              at exports.runInThisContext (vm.js:53:16)
              at Module._compile (module.js:414:25)
              at Object.Module._extensions..js (module.js:442:10)
              at Module.load (module.js:356:32)
              at Function.Module._load (module.js:311:12)
              at Function.Module.runMain (module.js:467:10)
              at startup (node.js:134:18)
              at node.js:961:3
          Trying just with npm i -g npm instead…
            rmeskill
            @rmeskill said in Error on npm install:
            Did give me a positive output:
            Trying npm install again…
              @rmeskill try do it in the MagicMirror folder
              sudo npm i -g npm
                sdetweil @paddyhughes
                @paddyhughes -g means global, not mm specific.
                  rmeskill
                  sudo npm i -g npm
                  Sudo still doesn’t work, but I tried it again just ‘npm i -g npm’ in the MagicMirror folder. Now I’m trying npm install again in the MagicMirror folder again, so I guess we’ll see, but it looks like it’s stuck at the same point as last time
                    sdetweil @rmeskill
                    @rmeskill looks like node is also downlevel
                      rmeskill
                      @sdetweil said in Error on npm install:
                      Do you mean I should upgrade it? this isn’t enough:
                      pi@raspberrypi:~/MagicMirror $ node -v
                      v11.6.0
                        sdetweil @rmeskill
                        @rmeskill that is a surprise
                          rmeskill
                          Now I’m trying to remove npm and nodejs to start again, but even after I’ve run apt-get remove npm nodejs I still get this:
                          pi@raspberrypi:~/MagicMirror $ which npm
                          /home/pi/.nvm/versions/node/v11.6.0/bin/npm
                          pi@raspberrypi:~/MagicMirror $ which node
                          /home/pi/.nvm/versions/node/v11.6.0/bin/node
                            .nvm/
                            looks like node version manager (nvm) was used to install these…
                            you could temporarily remove those folders from the PATH environment variable.
                            or search for remove nvm… and found
                            No, all you need to do is remove $NVM_DIR (~/.nvm is the default), and the relevant 2 lines in your profile file (but you also can leave those behind, since they’re guarded by a file existence check).
                              rmeskill
                              Seems my reply to this got lost…
                              Got this working! Removed the .nvm directory, removed the symlinks, shutdown pm2 and re-ran the installation script and it all went in fine!
                              sudo rm -rf ~/.nvm
                              sudo rm -f /usr/local/bin/node
                              sudo rm -f /usr/local/bin/nvm
                              pm2 stop mm
                              sudo rm -rf ~/MagicMirror
                              bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                              I got an error on npm not being the right version, so upgraded that:
                              sudo npm i -g npm
                              (Note sudo is working now, which it wasn’t before) And now my node and npm versions look good and pm2 is running MagicMirror again!
                              pi@raspberrypi:/ $ node -v
                              v9.11.2
                              pi@raspberrypi:/ $ npm -v
                              6.5.0
                              Thanks everyone for the help!
