    Error on npm install
    14 Posts 3 Posters 10.8k Views 3 Watching
      rmeskill
      @rmeskill said in Error on npm install:
      Trying just with npm i -g npm instead…
      Did give me a positive output:
      Trying npm install again…
        paddyhughes @rmeskill
        @rmeskill try do it in the MagicMirror folder
        sudo npm i -g npm
          sdetweil @paddyhughes
          @paddyhughes -g means global, not mm specific.
            rmeskill
            @paddyhughes said in Error on npm install:
            sudo npm i -g npm
            Sudo still doesn’t work, but I tried it again just ‘npm i -g npm’ in the MagicMirror folder. Now I’m trying npm install again in the MagicMirror folder again, so I guess we’ll see, but it looks like it’s stuck at the same point as last time
              sdetweil @rmeskill
              @rmeskill looks like node is also downlevel
                rmeskill
                @sdetweil said in Error on npm install:
                Do you mean I should upgrade it? this isn’t enough:
                pi@raspberrypi:~/MagicMirror $ node -v
                v11.6.0
                  sdetweil @rmeskill
                  @rmeskill that is a surprise
                    rmeskill
                    Now I’m trying to remove npm and nodejs to start again, but even after I’ve run apt-get remove npm nodejs I still get this:
                    pi@raspberrypi:~/MagicMirror $ which npm
                    /home/pi/.nvm/versions/node/v11.6.0/bin/npm
                    pi@raspberrypi:~/MagicMirror $ which node
                    /home/pi/.nvm/versions/node/v11.6.0/bin/node
                      .nvm/
                      looks like node version manager (nvm) was used to install these…
                      you could temporarily remove those folders from the PATH environment variable.
                      or search for remove nvm… and found
                      No, all you need to do is remove $NVM_DIR (~/.nvm is the default), and the relevant 2 lines in your profile file (but you also can leave those behind, since they’re guarded by a file existence check).
                        rmeskill
                        Seems my reply to this got lost…
                        Got this working! Removed the .nvm directory, removed the symlinks, shutdown pm2 and re-ran the installation script and it all went in fine!
                        sudo rm -rf ~/.nvm
                        sudo rm -f /usr/local/bin/node
                        sudo rm -f /usr/local/bin/nvm
                        pm2 stop mm
                        sudo rm -rf ~/MagicMirror
                        bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                        I got an error on npm not being the right version, so upgraded that:
                        sudo npm i -g npm
                        (Note sudo is working now, which it wasn’t before) And now my node and npm versions look good and pm2 is running MagicMirror again!
                        pi@raspberrypi:/ $ node -v
                        v9.11.2
                        pi@raspberrypi:/ $ npm -v
                        6.5.0
                        Thanks everyone for the help!
