    auto-booting but no modules (no warning with config file)
    24 Posts 2 Posters 9.9k Views 2 Watching
    • W Offline
      will23110
      yeah, shame though I’d only just perfected it ahah, so the three errors are
      • Uncaught SyntaxError: Invalid or unexpected token (translator.js:1)
      • Uncaught SyntaxError: Invalid or unexpected token (loader.js:1
      • Uncaught ReferenceError: Translator is not defined (misn.js:452)
        at Object.init (main.js:425)
        at main.js:580
        and then a couple of security warning that I can probably (hopefully) fix.
        sdetweil @will23110
        @will23110 said in auto-booting but no modules (no warning with config file):
        so, I would use some editor to look at these two files in
        MagicMirror/js
        line 1 of each is a comment (/* */)
        maybe there was an error on the memory card when u rebooted…
        this error is because of the prior error on the translator.js file
        • W Offline
          will23110
          so I’ve got translator.js open, it says at the top
          /* global config, vendor, MM, Module */
          /* MagicMirror
           * Module and file loaders.
           * Etc...
          should it be
           /* MagicMirror*/
           /* Module and file loaders.*/
           /* Etc...
          • W Offline
            will23110
            but in the repository for MagicMirror on github its the same, how do I quickly check for differences instead of having to go through the entire thing and comparing to another file
              sdetweil @will23110
              @will23110 no, 1st is ok
                sdetweil @will23110
                @will23110 compare, i do not know
                • W Offline
                  will23110
                  Okay, I’ll check through it and correct anything that may be wrong
                  • W Offline
                    will23110
                    so I had an idea to check through it fast, I copied the loader.js info off of github and paste it into the find (ctrl+f) window, the whole document is highlighted, meaning there are no errors… could it be something else??
                      sdetweil @will23110
                      this one bothers me, I can’t find that file anywhere (misn.js), unless that is acut/paste/typo
                      based on the fact that files look ok, I would suggest doing an fsck (file system check) against the memory card
                      you will probably have to move it to another system to do that… windows cannot do it
                      • W Offline
                        will23110
                        how would I go about doing that on a pi?
                          sdetweil @will23110
                          @will23110 a google search says
                          https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=179361
                          • W Offline
                            will23110
                            what do you mean by misn.js, I will have a look at that site, thanks
                              sdetweil @will23110
                              the error u posted says
                              i see a use of Translator in main.js
                              but cannot find a misn.js
                              • W Offline
                                will23110
                                oh, typo haha, it’s supposed to say main.js, there are no errors in that one either, sorry about that
                                  sdetweil @will23110
                                  @will23110 ok
                                  • W Offline
                                    will23110
                                    wait so from the site you gave me, if I run
                                    sudo touch /forcefsck; sudo reboot
                                    will that break it?
                                      sdetweil @will23110
                                      @will23110 no, that forces the fsck on next boot, then reboots
                                      • W Offline
                                        will23110
                                        oh I see, I’ll try it now
                                        • W Offline
                                          will23110
                                          I tried it and it did nothing…
                                          • W Offline
                                            will23110
                                            so there was one issue in each .js file, I ended up pasting the entire .js repository back in from the GitHub files, that seems it fixed it.
                                            for people having this issue when it black screens, run
                                            cd MagicMirror
                                            npm start dev
                                            that starts up magic mirror with dev options, go to the second tab, there will be files that have errors or security issues, that’s what it was for mine anyway… It’s fixed now, thanks a lot for helping.
