    auto-booting but no modules (no warning with config file)
    24 Posts 2 Posters 9.7k Views 2 Watching
      sdetweil @will23110
      @will23110 said in auto-booting but no modules (no warning with config file):
      Uncaught SyntaxError: Invalid or unexpected token (translator.js:1)
      Uncaught SyntaxError: Invalid or unexpected token (loader.js:1
      so, I would use some editor to look at these two files in
      MagicMirror/js
      line 1 of each is a comment (/* */)
      maybe there was an error on the memory card when u rebooted…
      Uncaught ReferenceError: Translator is not defined (misn.js:452)
      this error is because of the prior error on the translator.js file
      • W Offline
        will23110
        so I’ve got translator.js open, it says at the top
        /* global config, vendor, MM, Module */
        /* MagicMirror
         * Module and file loaders.
         * Etc...
        should it be
         /* MagicMirror*/
         /* Module and file loaders.*/
         /* Etc...
        • W Offline
          will23110
          but in the repository for MagicMirror on github its the same, how do I quickly check for differences instead of having to go through the entire thing and comparing to another file
            sdetweil @will23110
            @will23110 no, 1st is ok
              sdetweil @will23110
              @will23110 compare, i do not know
              • W Offline
                will23110
                Okay, I’ll check through it and correct anything that may be wrong
                • W Offline
                  will23110
                  so I had an idea to check through it fast, I copied the loader.js info off of github and paste it into the find (ctrl+f) window, the whole document is highlighted, meaning there are no errors… could it be something else??
                    sdetweil @will23110
                    this one bothers me, I can’t find that file anywhere (misn.js), unless that is acut/paste/typo
                    based on the fact that files look ok, I would suggest doing an fsck (file system check) against the memory card
                    you will probably have to move it to another system to do that… windows cannot do it
                    • W Offline
                      will23110
                      how would I go about doing that on a pi?
                        sdetweil @will23110
                        @will23110 a google search says
                        https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=179361
                        • W Offline
                          will23110
                          what do you mean by misn.js, I will have a look at that site, thanks
                            sdetweil @will23110
                            the error u posted says
                            i see a use of Translator in main.js
                            but cannot find a misn.js
                            • W Offline
                              will23110
                              oh, typo haha, it’s supposed to say main.js, there are no errors in that one either, sorry about that
                                sdetweil @will23110
                                @will23110 ok
                                • W Offline
                                  will23110
                                  wait so from the site you gave me, if I run
                                  sudo touch /forcefsck; sudo reboot
                                  will that break it?
                                    sdetweil @will23110
                                    @will23110 no, that forces the fsck on next boot, then reboots
                                    • W Offline
                                      will23110
                                      oh I see, I’ll try it now
                                      • W Offline
                                        will23110
                                        I tried it and it did nothing…
                                        • W Offline
                                          will23110
                                          so there was one issue in each .js file, I ended up pasting the entire .js repository back in from the GitHub files, that seems it fixed it.
                                          for people having this issue when it black screens, run
                                          cd MagicMirror
                                          npm start dev
                                          that starts up magic mirror with dev options, go to the second tab, there will be files that have errors or security issues, that’s what it was for mine anyway… It’s fixed now, thanks a lot for helping.
