    auto-booting but no modules (no warning with config file)
    24 Posts 2 Posters 8.7k Views 2 Watching
    • W Offline
      will23110
      yeah, shame though I’d only just perfected it ahah, so the three errors are
      • Uncaught SyntaxError: Invalid or unexpected token (translator.js:1)
      • Uncaught SyntaxError: Invalid or unexpected token (loader.js:1
      • Uncaught ReferenceError: Translator is not defined (misn.js:452)
        at Object.init (main.js:425)
        at main.js:580
        and then a couple of security warning that I can probably (hopefully) fix.
        sdetweil @will23110
        @will23110 said in auto-booting but no modules (no warning with config file):
        so, I would use some editor to look at these two files in
        MagicMirror/js
        line 1 of each is a comment (/* */)
        maybe there was an error on the memory card when u rebooted…
        this error is because of the prior error on the translator.js file
        • W Offline
          will23110
          so I’ve got translator.js open, it says at the top
          /* global config, vendor, MM, Module */
          /* MagicMirror
           * Module and file loaders.
           * Etc...
          should it be
           /* MagicMirror*/
           /* Module and file loaders.*/
           /* Etc...
          • W Offline
            will23110
            but in the repository for MagicMirror on github its the same, how do I quickly check for differences instead of having to go through the entire thing and comparing to another file
              sdetweil @will23110
              @will23110 no, 1st is ok
                sdetweil @will23110
                @will23110 compare, i do not know
                • W Offline
                  will23110
                  Okay, I’ll check through it and correct anything that may be wrong
                  • W Offline
                    will23110
                    so I had an idea to check through it fast, I copied the loader.js info off of github and paste it into the find (ctrl+f) window, the whole document is highlighted, meaning there are no errors… could it be something else??
                      sdetweil @will23110
                      this one bothers me, I can’t find that file anywhere (misn.js), unless that is acut/paste/typo
                      based on the fact that files look ok, I would suggest doing an fsck (file system check) against the memory card
                      you will probably have to move it to another system to do that… windows cannot do it
                      • W Offline
                        will23110
                        how would I go about doing that on a pi?
