auto-booting but no modules (no warning with config file)
24 Posts 2 Posters 7.4k Views 2 Watching
  • W Offline
    will23110
    So I turned off my mirror last night as per usual and turned it back on this morning to find that the modules aren’t loading, I don’t have a notification saying that I had an error with the config.js folder, the thing autoboots then shows absolutely nothing, I am running the latest version, I ran npm audit which showed 7 low, 1 medium, 1 high, so I ran npm audit fix, now I only have 5 low… but it still isn’t working… Any suggestions where to look or what to potentially do that doesn’t involve starting again??
    S 1 Reply Last reply Feb 8, 2019, 12:22 PM Reply Quote 0
      sdetweil @will23110
      @will23110 from the console of your pi, or over ssh, run
      npm start dev
      from the MagicMirror folder
      open the console tab, and look for errors, red text
      usually when a module crashes, the mirror will go black
      • W Offline
        will23110
        so I’ve run that and in the top right corner it says 3 errors and 2 warnings, I just don’t understand why it would do this overnight, it was working perfectly last night
        S 1 Reply Last reply Feb 8, 2019, 12:46 PM Reply Quote 0
          sdetweil @will23110
          @will23110 select the console tab to scroll the list
          no idea, something changed
          • W Offline
            will23110
            yeah, shame though I’d only just perfected it ahah, so the three errors are
            • Uncaught SyntaxError: Invalid or unexpected token (translator.js:1)
            • Uncaught SyntaxError: Invalid or unexpected token (loader.js:1
            • Uncaught ReferenceError: Translator is not defined (misn.js:452)
              at Object.init (main.js:425)
              at main.js:580
              and then a couple of security warning that I can probably (hopefully) fix.
            S 2 Replies Last reply Feb 8, 2019, 1:03 PM Reply Quote 0
              sdetweil @will23110
              @will23110 said in auto-booting but no modules (no warning with config file):
              so, I would use some editor to look at these two files in
              MagicMirror/js
              line 1 of each is a comment (/* */)
              maybe there was an error on the memory card when u rebooted…
              this error is because of the prior error on the translator.js file
              • W Offline
                will23110
                so I’ve got translator.js open, it says at the top
                /* global config, vendor, MM, Module */
                /* MagicMirror
                 * Module and file loaders.
                 * Etc...
                should it be
                 /* MagicMirror*/
                 /* Module and file loaders.*/
                 /* Etc...
                S 1 Reply Last reply Feb 8, 2019, 1:38 PM Reply Quote 0
                • W Offline
                  will23110
                  but in the repository for MagicMirror on github its the same, how do I quickly check for differences instead of having to go through the entire thing and comparing to another file
                    sdetweil @will23110
                    @will23110 no, 1st is ok
                      sdetweil @will23110
                      @will23110 compare, i do not know
                      1 / 3
