This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
Unsolved MMM-Remote-Control
@yorickmolema It actually fixed itself by me but im not sure what I did. It tried moving things around in the config file but not sure what else. I also dont get my IP address on screen but thats a separate issue.
@teitlebot Can you send your config?
If I click away the error and press save I get the following error in the terminal where I started MM:
undefined Whoops! There was an uncaught exception... TypeError: Cannot read property 'length' of undefined at Class.saveDefaultSettings (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:898:44) at Object.callback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:679:56) at Object.run (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:547:26) at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:555:28) at ontimeout (timers.js:427:11) at tryOnTimeout (timers.js:289:5) at listOnTimeout (timers.js:252:5) at Timer.processTimers (timers.js:212:10) MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "0.0.0.0", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "192.168.1.1/24"], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "alert", disabled: true, }, { module: 'MMM-Remote-Control', disabled: false, // uncomment the following line to show the URL of the remote control on the mirror position: 'bottom_left', // you can hide this module afterwards from the remote control itself config: { customCommand: {}, // Optional, See "Using Custom Commands" below customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below showModuleApiMenu: true, // Optional, Enable the Module Controls menu apiKey: "", // Optional, See API/README.md for details } }, module.exports = config;}
@teitlebot I have the following config now:
/*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/ var config = { address: '0.0.0.0', electronOptions: {}, ipWhitelist: ['127.0.0.1','::ffff:127.0.0.1','::1', '192.168.123.26','192.168.123.28','192.168.123.25',], language: 'nl', modules: [ { module: 'MMM-Remote-Control', disabled: false, config: { customCommand: {}, customMenu: 'custom_menu.json', showModuleApiMenu: 'true', apikey: '', } }, { module: "newsfeed", position: "bottom_bar", // This can be any of the regions. Best results in center regions. config: { // The config property is optional. // If no config is set, an example calendar is shown. // See 'Configuration options' for more information. feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml", }, { title: "BBC", url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk", }, ] } } ], paths: { modules: 'modules', vendor: 'vendor' } } /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
And it doesn’t work yet. I couldn’t copy your config cause then i got an error that the text editor wouldn’t save it.
Hi @teitlebot , please can you share your config file as i am tried to edit mine to bypass the problem and can’t figure it out
