    MMM-Remote-Control
    11 Posts 3 Posters 5.3k Views 3 Watching
    • Y
      yorickmolema
      This is my config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
       //address: "localhost", // Address to listen on, can be:
       address: "0.0.0.0",
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.123.X"], // Set [] to allow all IP addresses
      	language: "nl",
      	timeFormat: 24,
      	units: "metric",
      			module: "newsfeed",
      			position: "top_bar",
      				feeds: [
      						title: "Nu.nl",
      						url: "https://www.nu.nl/rss/Algemeen"
      						title: "Nu.nl",
      						url: "https://www.nu.nl/rss/Internet"
      				showSourceTitle: false,
      				showPublishDate: false
      			module: "clock",
      			position: "top_left"
      		module: 'MMM-SmartWebDisplay',
      		position: 'middle_center',	// This can be any of the regions.
      			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
      			height:"100%", //hauteur du cadre en pixel ou %
      			width:"100%", //largeur
                     		updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                      	NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                      	displayStateInfos: false,	//to display if the module is on autoloop, or stop.
                      	displayLastUpdate: true, //to display the last update of the URL
      			displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                      	url: [""], //source of the URL to be displayed
                      	scrolling: "no" // allow scrolling or not. html 4 only
      	        module: 'MMM-Remote-Control',
      	        // , position: 'bottom_left'
      		position: "bottom_left",
      	          customCommand: {},  // Optional, See "Using Custom Commands" below
      	        customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      	        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              	apiKey: "",         // Optional, See API/README.md for details
      			module: "currentweather",
      				locationID: "2750947",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "c3494d09f5358b30a53a3167af88d38d"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "compliments",
      			position: "",	// This can be any of the regions.
      										// Best results in one of the middle regions like: lower_third
      				compliments: {
      					day_sunny: [
      						"Today is a sunny day",
      						"It's a beautiful day"
      					snow: [
      						"Snowball battle!"
      					rain: [
      						"Don't forget your umbrella"
      					anytime: [
      						"Hey there sexy!"
      					morning: [
      						"Good morning, handsome!",
      						"Enjoy your day!",
      						"How was your sleep?",
      						"Good morning, sunshine!",
      					        "Who needs coffee when you have your smile?",
             						"Go get 'em, Tiger!"
      					afternoon: [
      						"Hello, beauty!",
      						"You look sexy!",
      						"Looking good today!",
      					        "Hitting your stride!",
      					        "You are making a difference!",
              					"You're more fun than bubble wrap!"
      					evening: [
      						"Wow, you look hot!",
      						"You look nice!",
      						"Hi, sexy!",
      						"You made someone smile today, I know it.",
      					        "You are making a difference.",
              					"The day was better for your efforts."
      • Y
        yorickmolema
        • T
          teitlebot @yorickmolema
          @yorickmolema
          Having the same issue. any luck?
          Y 1 Reply Last reply
          • Y
            yorickmolema @teitlebot
            @teitlebot Nope, I have updated all the software on my pi, but that didn’t help.
            T 1 Reply Last reply
            • T
              @yorickmolema It actually fixed itself by me but im not sure what I did. It tried moving things around in the config file but not sure what else. I also dont get my IP address on screen but thats a separate issue.
              • Y
                @teitlebot Can you send your config?
                • Y
                  yorickmolema
                  If I click away the error and press save I get the following error in the terminal where I started MM:
                  undefined
                  TypeError: Cannot read property 'length' of undefined
                      at Class.saveDefaultSettings (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:898:44)
                      at Object.callback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:679:56)
                      at Object.run (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:547:26)
                      at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:555:28)
                      at ontimeout (timers.js:427:11)
                      at tryOnTimeout (timers.js:289:5)
                      at listOnTimeout (timers.js:252:5)
                      at Timer.processTimers (timers.js:212:10)
                  • T
                    @yorickmolema
                     * MIT Licensed.
                    var config = {
                    	address: "0.0.0.0", // Address to listen on, can be:
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "192.168.1.1/24"],
                    	language: "en",
                    	timeFormat: 12,
                    	units: "imperial",
                    			module: "alert",
                    disabled: true,
                    disabled: false,
                        position: 'bottom_left',
                    • Y
                      @teitlebot I have the following config now:
                      /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                      var config =
                        address: '0.0.0.0',
                        electronOptions: {},
                        ipWhitelist: ['127.0.0.1','::ffff:127.0.0.1','::1', '192.168.123.26','192.168.123.28','192.168.123.25',],
                        language: 'nl',
                      	disabled: false,
                      		customCommand: {},
                      		customMenu: 'custom_menu.json',
                      		showModuleApiMenu: 'true',
                      		apikey: '',
                      		module: "newsfeed",
                      		position: "bottom_bar",	// This can be any of the regions. Best results in center regions.
                      			// If no config is set, an example calendar is shown.
                      			feeds: [
                      					title: "New York Times",
                      					url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                      					title: "BBC",
                      					url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk",
                        paths: {
                          modules: 'modules',
                          vendor: 'vendor'
                      And it doesn’t work yet. I couldn’t copy your config cause then i got an error that the text editor wouldn’t save it.
                        seso
                        Hi @teitlebot , please can you share your config file as i am tried to edit mine to bypass the problem and can’t figure it out
