    MMM-GoogleAssistant autostart
    46 Posts 3 Posters 31.6k Views 3 Watching
      sdetweil @poopyurinal
      @poopyurinal so, does mirror app start? but assistant doesn’t work ? are you using pm2? to control Mirror autostart?
        auto install script sets up a pm2 module to start mirror app
          poopyurinal
          yes, the mirror app starts flawlessly with all installed modules. The assistant icon appears on the mirror, but is not activated by “Ok google” unless I type the commands in my OP. I believe pm2 is controlling the Mirror autostart.
            @poopyurinal ok, but if yoiu start it manually does it work?
            pm2 stop MagicMirror
            open a terminal window (ctrl-alt-t)
            cd MagicMirror
            npm start
            does it all work?
            I don’t know assistant.py I assume it runs in the background… and somehow talks to the module…
              and with mirror running on boot, press ctrl-shit-i to open the developers window, and select the console tab, and scroll up to find any module errors
              there is also a pm2 command to show its log… (I don’t use pm2 myself).
                @poopyurinal said in MMM-GoogleAssistant autostart:
                I know that to start the module successfully, I can enter the following 3 commands:
                source env/bin/activate
                cd ~/MagicMirror/modules/MMM-GoogleAssistant/pi
                python3 assistant.py
                you are not starting the module… you are starting a background application
                that is included in the module folder
                the ‘module’ only runs inside the MagicMirror environment
                so, you need to create a command that does the startup…
                start the py and then start MM
                and then automate that
                if u stop MM manually and restart it (without doing the assistant.py step) do the GA work thru mirror as u expect?
                  poopyurinal
                  pm2 stop MagicMirror gives me:
                  [PM2][ERROR] Process MagicMirror not found
                  │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
                  │ mm │ 0 │ fork │ online │ 1 │ 0% │ 2.5 MB │
                  Use pm2 show <id|name> to get more details about an app
                  Any thoughts? The MagicMirror is running. If I stop it by hitting Alt and closing it via the menu bar, it automatically restarts.
                    @poopyurinal pm2 list
                      poopyurinal
                      pm2 list
                        @poopyurinal pm2 stop mm
                          poopyurinal
                          pm2 stop mm
                          [PM2] Applying action stopProcessId on app [mm](ids: 0)
                          [PM2] mm ✓
                          │ mm │ 0 │ fork │ stopped │ 1 │ 0% │ 0 B │
                          Sorry, limited by new user restriction of one post every 120 seconds
                            @poopyurinal cool now follow the link i gave about creating a service that will autostart and make it start the assitant.py
                            I don’t understand why the MMM-GoogleAssistant module doesn’t do this… it would be so easy…
                              in the link it asks for ‘your service name’ make that GoogleAssistant
                              the command is ‘/home/pi/MagicMirror/modulesMMM-GoogleAssistant/python3 assistant.py’
                                once u create the service… make sure assistant.py is not running already
                                ps -ef | grep assistant
                                the 1st number on the output is the process id
                                pi xxxx yyyy etc…
                                then
                                sudo kill -9 xxxx
                                then do
                                sudo systemctl start GoogleAssistant
                                then
                                to insure assistant is running
                                then start mirror manually with npm start
                                if all is good, reboot
                                service will start the assistant.py script
                                and pm2 will start mirror app
                                  poopyurinal
                                  Many thanks Sam! I’ll need to take a look at your suggestions tomorrow. I appreciate the quick (immediate!) help.
                                    @poopyurinal no problem… let us know either way
                                    i use the assistantmk2 module… don’t need that py file
                                      poopyurinal
                                      I’ll have to look at it. Tried the MM-GA module after 3+ failures of Alexa modules. Just would like one of them to work!
                                        @poopyurinal also use the MMM-Alexa module
                                          poopyurinal
                                          Tried and failed with MMM-Alexa. Doesn’t mean I can’t try again!
                                            poopyurinal
                                            Looking for some clarifications here. I tried Sam’s suggestion and created a GoogleAssistant.service in /etc/systemd/system. I am a little confused on the command though:
                                            The assistant.py file is located in /home/pi/MagicMirror/modules/MMM-GoogleAssistant/pi. And wouldn’t the “python3” command come first? Could someone clarify?
                                            Then, continuing to follow this post, he suggested running:
                                            to find the process id. However, when i try to kill that process id, is says it “No such process”. If I run the same command several times in a row, I get different process ids each time. Is it trying to run via some other pathway and retrying constantly? It wouldn’t surprise me, as I’ve tried to get this working via many methods. How can I track this down?
                                            Thanks for your help!
