    MMM-GoogleAssistant autostart
    46 Posts 3 Posters 25.5k Views 3 Watching
      starting a pgm at boot
      https://timleland.com/how-to-run-a-linux-program-on-startup/
      you might need two? on the py and one the mirror app?
        sdetweil @poopyurinal
        @poopyurinal so, does mirror app start? but assistant doesn’t work ? are you using pm2? to control Mirror autostart?
          auto install script sets up a pm2 module to start mirror app
            poopyurinal
            yes, the mirror app starts flawlessly with all installed modules. The assistant icon appears on the mirror, but is not activated by “Ok google” unless I type the commands in my OP. I believe pm2 is controlling the Mirror autostart.
              @poopyurinal ok, but if yoiu start it manually does it work?
              pm2 stop MagicMirror
              open a terminal window (ctrl-alt-t)
              cd MagicMirror
              npm start
              does it all work?
              I don’t know assistant.py I assume it runs in the background… and somehow talks to the module…
                and with mirror running on boot, press ctrl-shit-i to open the developers window, and select the console tab, and scroll up to find any module errors
                there is also a pm2 command to show its log… (I don’t use pm2 myself).
                  @poopyurinal said in MMM-GoogleAssistant autostart:
                  I know that to start the module successfully, I can enter the following 3 commands:
                  source env/bin/activate
                  cd ~/MagicMirror/modules/MMM-GoogleAssistant/pi
                  python3 assistant.py
                  you are not starting the module… you are starting a background application
                  that is included in the module folder
                  the ‘module’ only runs inside the MagicMirror environment
                  so, you need to create a command that does the startup…
                  start the py and then start MM
                  and then automate that
                  if u stop MM manually and restart it (without doing the assistant.py step) do the GA work thru mirror as u expect?
                    poopyurinal
                    pm2 stop MagicMirror gives me:
                    [PM2][ERROR] Process MagicMirror not found
                    │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
                    │ mm │ 0 │ fork │ online │ 1 │ 0% │ 2.5 MB │
                    Use pm2 show <id|name> to get more details about an app
                    Any thoughts? The MagicMirror is running. If I stop it by hitting Alt and closing it via the menu bar, it automatically restarts.
                      @poopyurinal pm2 list
                        poopyurinal
                        pm2 list
                        • 1 / 5
