    Magic Mirror Mac Mini npm start
    18 Posts 3 Posters 6.4k Views 3 Watching
      @sdetweil did the mirror app start?
        drx1984 @sdetweil
        @sdetweil said in Magic Mirror Mac Mini npm start:
        Yes starts, Now I try to restart the MacMini and see if Magic Mirror starts automatically
          drx1984 @sdetweil
          @sdetweil pity MagicMirror does not start automatically after reboot
            drx1984
            Does anyone have Magic Mirror on the Mac Mini on the run???
            How does she do that with the autostart??
              A Former User
              forget pm2. this could be a help.
              https://stackoverflow.com/questions/6442364/running-script-upon-login-mac
                drx1984 @Guest
                @Sean
                thanks, do I need to write a script?
                  A Former User @drx1984
                  @drx1984
                  Wait a second. After trial on my mac, I’ll post for you. (And I think pm2 could also be available with launchd)
                    drx1984 @Guest
                    @Sean ok, that would be very nice
                      @drx1984
                      Ok. I found incredibly simple solution.
                      sudo pm2 startup darwin
                      That’s all. It is already served by pm2 since https://github.com/Unitech/pm2/pull/936
                      (It will take a few seconds until MM starts from bootup)
                        drx1984 @Guest
                        @Sean said in Magic Mirror Mac Mini npm start:
                        ok thanks the command: sudo pm2 startup darwin tonight test and report you.
                        Many Thanks
                          drx1984 @Guest
                          @Sean I just tried, unfortunately I get an error message. Do you know how I can solve this?
                          Thank you
                            Hmmm… For me it works.
                            Check ~/Library/LaunchAgents/directory whether exists or not.
                            You can save your xml (under Template) totarget path by manual then execute command list
