    Problems with starting pm2 start mm.sh
    27 Posts 7 Posters 17.6k Views 7 Watching
      madoXX @sdetweil
      @sdetweil said in Problems with starting pm2 start mm.sh:
      @madoXX does it restart on boot?
      pm2 remove 0
      should have been
      pm2 delete 0
      and yep, needed a stop after the pm2 save
      no, the boot menu from the magic mirror appears (booting up), no error but it goes straight to the desktop.
      something strang here
      then
      pm2 list
      nothing running
      In fact the themm.sh is running caus i startet it above
      pm2 start /home/pi/mm.sh
        madoXX
        OK command back…
        after a few reboots now everything is starting fine.
        A big thanks to the community here!
        Very helpfull people here!
        • G Offline
          Gomalley
          I’m actually having thus EXACT problem and it is very frusterating. Im having a little trouble reading all of the instructions to fix it. Did you get yours fixed? If so exactly what did you do to fix it?
            sdetweil @Gomalley
            @Gomalley pm2 runs a script,
            installers/mm.sh
            It should read
            cd /home/pi/MagicMirror
            ...etc
            Change it if not.
            Then
            pm2 restart 0
            • G Offline
              Gomalley
              I tried it but I do not think that it worked. My code before I touched it read
              Now i tried two things both gave same output
              cd ~/home/pi/MagicMirror
              and
              It now says
              [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
              [PM2] PM2 Successfully daemonized
              [PM2] Applying action restartProcessId on app [0](ids: [ ‘0’ ])
              [PM2] [ERROR] Process 0 not found
              In my mm.sh the file currently reads this:
              DISPLAY=:0 npm start
              • G Offline
                Gomalley
                And I tried restarting the pi and the “Booting up” MagicMirror2 showed but it never actually loaded.
                  sdetweil @Gomalley
                  @Gomalley ok
                  pm2 list
                  If nothing
                  pm2 start installers/mm.sh
                  pm2 save
                    Detto65 @madoXX
                    @madoXX
                    just did a fresh install of my magicmirror, because the sd card went corrupt.
                    during the install procedure it somehwere asked me if i want to autostart MagicMirror.
                    after that it started automatically after booting into the desktop first.
                    When trying to use pm2, it shows me the process is already running, but it’s name is MagicMirror , not mm.
                    MagicMirror version 2.8.0
                      sdetweil @Detto65
                      @Detto65 yes, the install script uses a json file to configure the pm2 process
                      • G Offline
                        Gomalley
                        When i do
                        pm2 list
                        The "name, id, mode, status, cpu, and memory chart shows up. It is all in blue.
                        Below it, it says “use ‘pm2 show <id/name>~ to get more details about an app.’”
                        When i type in
                        pm2 start
                        The same chart above displays along with a message saying
                        [PM2] [ERROR] File ecosystem.config.js is not found
                        What does this mean?
                          Raksasas
                          I am having the same problem: I did what was mentioned above and after the reboot it stll did not start automaticly. Running “pm2 list” after the reboot shows mm.sh is not runnning.
                          permitted by applicable law.
                          Last login: Sun Jul 28 20:48:49 2019
                          pi@magicmirror:~ $ pm2 list
                          │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
                           Use `pm2 show <id|name>` to get more details about an app
                          pi@magicmirror:~ $ pm2 start installers/mm.sh
                          [PM2][ERROR] script not found : /home/pi/installers/mm.sh
                          pi@magicmirror:~ $ pm2 start mm.sh
                          [PM2] Starting /home/pi/mm.sh in fork_mode (1 instance)
                          [PM2] Done.
                          │ mm       │ 0  │ N/A     │ fork │ 718 │ online │ 0       │ 0s     │ 0%  │ 2.6 MB   │ pi   │ disabled │
                          pi@magicmirror:~ $ pm2 save
                          [PM2] Saving current process list...
                          [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                          │ mm       │ 0  │ N/A     │ fork │ 718 │ online │ 0       │ 44s    │ 0%  │ 2.6 MB   │ pi   │ disabled │
                          pi@magicmirror:~ $ sudo reboot
                          Connection to 192.168.138.28 closed by remote host.
                          Connection to 192.168.138.28 closed.
                          pi@magicmirror:~ $ cat mm.sh
                          pi@magicmirror:~ $ ls -lha mm.sh
                          -rwxr-xr-x 1 pi pi 45 Jul 28 20:14 mm.sh
                          pi@magicmirror:~ $
                            sdetweil @Raksasas
                            @Raksasas should be executing those while in the MagicMirror folder
                              Raksasas @sdetweil
                              Looking over the “Auto Start” page I do not see where it states that the pm2 commands are to be run while inside the MagicMirror folder.
                              With you stating that it seems to be saying that the “mm.sh” script needs to be ran from inside the “MagicMirror” too. Again the “Auto Start” page shows that it was created inside the ‘home’ (~) folder. So one would think/presume it can be ran from inside the “home” folder also.
                              Either way I will give it a go.
                              mumblebajM S 2 Replies Last reply Reply Quote 0
                              • mumblebajM Offline
                                mumblebaj Module Developer @Raksasas
                                @Raksasas My mm.sh resides in my /pi/ folder and not in the MagicMirror folder so should work. It might be that there was an error while you were setting up pm2 or setting up the autostart perhaps?
                                  sdetweil @Raksasas
                                  @Raksasas it was the
                                  That needed to be done from the MagicMirror folder.
                                  Cause I ‘ASSUMED’ if u were working on mm, you would always be in that folder.
                                  installers folder is in mm, not in user home
                                    Raksasas
                                    Part 1:
                                    Just tried the
                                    pm2 save
                                    From within the “MagicMirror” folder and no change. MagicMirror starts and at reboot it does not automaticly start
                                    See below for my fix
                                    Part 2:
                                    @mumblebaj
                                    This seems possible. So i re-ran
                                    sudo npm install -g pm2
                                    pm2 startup
                                    After running “pm2 startup” this time I noticed the following:
                                    To setup the Startup Script, copy/paste the following command:
                                    sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                    So I ran that and followed with the “pm2 start mm.sh” and “pm2 save”. Well now it is auto starting on reboot.
                                    S mumblebajM 2 Replies Last reply Reply Quote 0
                                      sdetweil @Raksasas
                                      @Raksasas great news!
                                        @Raksasas Exellent. Great it is working now.
                                        • T TDMPro2K referenced this topic on
